Denon AVR-1508 Receiver problems - cuts off and goes into protect mode
I have this problem too. I disconnected all of the speakers. The receiver goes into protect mode after about 3 minutes. Also, I tried the reset routine (holding A and B speaker buttons while switching the device on) and it failed to reset. This is my second AVR-1508. I have double surge protection. All of my speakers are 8 ohm impedence and there is no short in the speaker wires (I checked with an amp meter.)
  • 1 more comment
  • dortmundb Aug 27, 2008
    Thanks for your response!!! Ok, so I've now tried the three experiments. The time to shutdown does not depend on the volume level at all. If unplugged overnight, I turn the AVR on and within 2-3 minutes, it shuts down, regardless of how I adjust the volume. There is no speaker hum and I've checked for voltage between the speaker lines. I now have the AVR on the floor by itself (not hooked up to anything but the wall) and I get no results. If left alone, the device powers up, works for 2-3 minutes and shuts off. If I try to then power the device back up, it goes directly into the shut-off mode with the red power light blinking. The device is under warranty, so I can ship it back, but since this is the second AVR to do this to me, I'm starting to wonder.
  • dortmundb Sep 26, 2008
    Dan,
    The place I sent the receiver said they don't furnish detailed reports. What I did get was this: "
    technical services rendered - PTEL IC 516 -15 volt regulator; replaced defective regulator IC. I called the place and asked about a lab report, and the guy said they don't do that??? I said this is the second one the went out on us, and we wanted to make sure it wasn't anything we should be doing differently, and he said they can't really speculate, but that regulators like this aren't really related to anything external...he said it's a good receiver, and not necessary to spend the big bucks..." I would be curious as to what this part does and if it is related to anything you can think of that I can avoid, or did I just get unlucky twice???
    Thanks!
    Craig
    Dan,
    Thanks again. Is there something in my set-up that could have contributed to this failed regulator, or is it simply a part that went bad in your opinion? I will definitely get both regulators fixed but I'd like to be on the lookout for whatever I need to change so this doesn't happen again.
    Thanks again for all your help!!!
    Craig
Sir,
I have some problem in my Danon avr 1508.
1. When i switched on the amplifier, there is some breaking sound in the speaker without any input, But when i played any input, it gets start with 23-24 volumn. I only worked hardly for few seconds. and den it goes to stand by mode(shows red light). There is hum after it goes to standby.
Please figure out my problem and help me with solution.
Posted on Jun 24, 2012
I have the same problem . denon had changed knob and circuits ?! one day later ... same issue !
i have 5.1 evo tangent 4-8ohms and 2 technics 8ohmsand i use frquently A+B configuration
Posted on Nov 08, 2008
  • 4,234 Answers
Usually when the unit runs for a while before shutting down there are two possibilities:
1) There is a small amount of DC current present that effectively heats up the speaker coils enough to cause a temporary short circuit that kicks in the protect circuit.
2) The output transistors or bias transistors are sensitive to heat and breaking down again causing the protect circuit to kick in.
A few experiments to try:
1) Does the time to shutdown change depending upon the volume level?
2) Is there any background noise coming from the speakers? Listen to a blank tape for example. Is there a hum or any other noise that you would not normally expect?
3) If you have a DC voltmeter, check for any voltage between the speaker lines.
Update this and we'll try to narrow this down.
Dan
Posted on Aug 19, 2008
  • 1 more comment
  • ABRsvcs Aug 27, 2008
    If it takes 2-3 minutes to shutdown, I'm guessing that there is some DC voltage floating around inside there somewhere. Since this is under warranty, send it out. I would request a detailed report of the repair though. Since this is the second tmie with a similar problem. Personally, I'm surprised at this too. I have been a Denon authorized service center and never had a recall for the same problem like that. I'm sure it happens rarely. I guess you are the "lucky" one. Keep me posted.
    Dan
  • ABRsvcs Sep 26, 2008
    A 15V regulator will be supplying the pre-amp section primarily. If one misbehaves, it will create a voltage offset that will be detected in the output stage as a problem and the unit will shutdown. If they only changed the +15V regulator, and the problem happened again, I would request that they change both the +15V and -15V regulators. This should be common practice, but at a warranty station, they try to change only the failed parts, not the ones that may have been stressed.
    Send the unit back and request that both be changed if they find that one is bad.
    Dan
    Nothing you could have done to create this problem. The service company, by not replacing both, may have caused the second one. By the way they probably saved $1.20 by not changing both. Send the unit back and request that if the problem is again a regulator that they replace both the plus and minus regulators.
    Dan
Red power light blinking on my denon avr 1907, tried reset procedure, no speakers hooked up now and it still goes from green light to blinking red light and shuts off...Any clues?
This is a protection mode. The receiver protection circuit detects an internal problem like missing power supply voltage or blown channel and shuts down the receiver. You need to bring the unit to a repair facility.
Sep 26, 2011 | Denon AVR-1907 Receiver
No Sound in Right Front Speaker- Denon AVR-1508
hi there,
have you check the system settings for each of the speaker..? should be set and balance all output of the speaker
`jack
May 24, 2008 | Audio Players & Recorders
My denon avr 1508 goes into protection mode after 5 minutes of play. i have 8ohm speakers.
I'm thinking heat.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 13, 2011 | Denon AVR-1508 Receiver
AVR-1508 7.1 Channels Receiver: My Denon AVR-1508 won't stay on. Once I try to tak...
Not familiar with this model but seems like the protection circuit is kicking in, this could be caused by an imbalance of Ohms between channels or a short. remove & check all speakers and cables for continuity or shorts, does the unit power on without speakers or in a different mode (surround off).
always add speakers in pairs (L&R) before testing to prevent possible protection circuit, test main speaker pair first then add surrounds (all according to the allowable Ohms range for the amp of course)
Nov 18, 2017 | Denon AVR-1508 Receiver
Denon avr 5600 waits a second and goes into protection mode what gives?
Disconnect all your speakers at the receiver then turn it back on. If it stays on, post a comment and I will walk you thru troubleshooting. If it still cuts out, it will need to be serviced. Hope this helps.
Aug 20, 2009 | Audio Players & Recorders
What is the master reset code for the denon avr 1508?
Turn the unit off by main switch (not a standby button).
Press and hold "Speakers-A" and "Speakers-B" buttons and turn on main switch.
Display blinks.
Release the buttons after 3 seconds.
Receiver is reseted.
Jul 20, 2009 | Denon AVR-1508 Receiver
I want to get full surround sound out of my Denon AVR-1508 w/sub
hi there might be some problem with the link that u have hooked up with the speakers.
Jan 18, 2009 | Denon AVR-1508 Receiver
Denon 1508- no sound but smoke.
perhaps u might consider going to a(n) (unauthorised) repair centre. just check with folks around u or maybe audio forums within your area. authorised agent doesn't always mean the best. i suspect they may have used reconditioned components.
Aug 31, 2008 | Denon AVR-1508 Receiver
Denon 1508
sterio wireing touching each other putting it in protect mode retrace all your wireing and redo this should clear up the protect mode if not return denon as manufacture malfunction to get replacement
May 30, 2008 | Denon AVR-2105 Receiver
3,377 people viewed this question
 Grubhead
Grubhead
