Question about Sport & Outdoor - Others
Wiring diagram for ford 9n tractor
I need a wiring diagram for my tractor.
  • Larry Major Dec 22, 2008
    I have a 1940 9N with a 1 wire generator. I need a wiring diagram that shows the proper set up. The only electrical is on/off switch, gen., ampmeter, voltage reg, and a terminal block with resisret, and coil. I'll gladly pay someone for the proper diagram.
  • Anonymous Mar 19, 2009
    I am rebuilding a 9N tractor and need a wiring diagram to complete the job. I already have a new harness.
    New Friend:
  • 182 Answers
You can purchase a manuel for your tractor at Tractor Supply or at tractorsupply.com for about $25-$30.
Posted on Sep 11, 2008
Don't know how to read the hydraulic dipstick for a 1944 ford 2n tractor
Ford Tractor Hydraulic System - My Ford Tractors
www.myfordtractors.com/hydraulics.shtml
All N-Series Tractors - Ford-Ferguson 9N, 2N, and Ford 8N ... 6 - How long has it been since you changed the hydraulic fluid? ... If that didn't do it, read on. ... then remove the bottom bolt from the inspection plate that has the hydraulic dip-stick.
Yesterday's Tractors - Fifty Tips for Ford 9N, 2N and 8N ...
www.yesterdaystractors.com/articles/artint268.htm
I'd like to say that the reason I have an 8N Ford tractor is because that's the tractor ... The N tractors have a common sump for the rear end, hydraulic pump andtransmission. ... (Read the label.) .... Take the inspection plate with the dipstick off.
Ford 8N, 9N, 2N, NAA Tractors Information - SSB Tractor ...
www.ssbtractor.com/wwwboard/messages15/
Helpful information and resources on Ford 8N, 9N, 2N, NAA tractors from SSB Tractor, a leading provider of tractor parts, manuals, implements ... 1944 ford 2n: What type of oil to use? and whats the oil pressure should be? ...... N Series Trans/Hydro Fluid - Interesting To Read ... Ford NAA/Jubilee Hydraulic dipstick location?
Jan 01, 2016 | Ford Cars & Trucks
Diagrams_For ford 2N tractor starter
If you have not already found the info, I would suggest visiting the following website for some detailed help:
mytractorforum.com
No cost but will have to join to post questions. Likely all info can be had simply by searching the Ford "N" section. Good Luck!!
Oct 29, 2011 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford 9N problems; Changed plugs, wires, cap, rotor, points, and ignition coil. Point gap at .015, new condensor. 6 V battery fully charged. No voltage drop to ignition coil. Results, no spark.
You might check ground. some of these units were ground positive. did you switch the posts?This would cause problems since the electrons are on the inside of the condinser.
Good luck
Joe
Feb 11, 2011 | Ford 8n,9n,2n, Tractor Starter With Drive
Looking for a wiring diagram for a ford 9n tractor, Messed up wiring on old tractor when trying to tune it up. Now may have the wiring messed up at the fuse link on the back of the dash
Try this website if you do not get help here:
mytractorforum.com
You will have to register to ask questions, but there is a good chance that you will be able to find what you need already posted there. Good Luck.
Aug 15, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
My 9N Ford Tractor won't start with a new 6volt battery.
No water in the distributor or wires ... right? Spray with a popular water inhibitor and/or dry with a rag and or air pressure.
Sep 07, 2009 | Ford Garden
Sport & Outdoor - Others Logo
1,799 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
