Question about LG LRE30451ST Electric Kitchen Range
Front side heat element with ring wont light on ( or heat up)
My front side heating element with ring wont light, just the ring will heat up but not the center area of the burner,
What could be the issue?
  • wathever Aug 19, 2008
    I just check there and find the part, you are right, the problem was the dual heting element assembly, I just got the part number and order the part.
    Thanks for your help!!!!!!!
  • 5,911 Answers
These type of elements are often known as dual elements. They usually have two separate coils. More than likely the center coil has failed. They cannot be repaired and, in the case with your range, cannot be replaced separately. You will need to replace the entire element. Searspartsdirect.com carries parts for your range. Just type in your model number and locate item numbers 5301 and 5302 under the "Cooktop" heading. I do not know which front element your are talking about, but there is a price difference. No, thay aren't interchangeable. They have different wattage ratings. You will need to determine which one it is that you're having problems with. Replacing a single element is not difficult. It can be accomplished easily by following these instructions:
1. Unplug the range before servicing. Even with the unit turned off, there are potentially dangerous voltages present on the wiring harness.
2. Open the oven door and locate the two screws that hold the cooktop in place under the front edge. CAUTION: Do not put any weight on the oven door. You can cause damage to the door springs. Once you remove the screws to the cooktop, close the oven door.
3. With the screws removed, the cooktop will lift up.
4. Use something to prop up the cooktop, or a second person to assist, and carefully remove the mounting bracket to the two front elements. They are assembled together on the same bracket piece.
5. Gently lay the entire assembly on top of the oven box, leaving the cooktop propped up. Disconnect the wires to the affected element and unscrew the mounting clips. NOTE: There are numbered mounting holes on the element, pay attention to which numbers the clips are screwed into.
6. Remove old element. Install mounting clips to new element and reconnect wires. Install new element in mounting bracket and carefully lift back into place on the cooktop and install. NOTE: Use caution when handling the elements, they are extremely fragile. DO NOT touch the ceramic material, or electric coils with your bare hands. Oil transfer form your hands can cause potential hot spots, leading to premature failure of the element.
7. Lower cooktop and secure back in place.
The repair procedures are pretty straight forward. If you have any questions, please let me know. I hope this helps you.
Posted on Aug 19, 2008
Does not heat
Hello there and thank you for choosing fixya
There are a few reasons why this is happening i have listed the most common items to check listed below
1st is the heating element this is the most common thing that fails
The heating elements are a common problem with dryers not heating and are an easy do-it-yourself repair. On the Newton style dryers, the heating element is located under the tub on the right in a round heater-can. To access it, first remove the front panel by removing the two screws on each side at the bottom of the front panel or if it's a newer model, prize the clips under the front panel. Then pull out the bottom of the front panel until the top clips release.This should release the top so that you can lift it up. Once up, you should see the heater at the back. Checking the heating element is the same for both styles. First disconnect power from dryer then unplug the wires going to the heating element. Next using your ohmmeter , check to see if you have continuity between the terminals on the heating element.
If you don't,have continuity the heating element is bad and needs replacing, if there is continuity the heating element is ok.
Mar 06, 2011 | Maytag MDE308DAYW Electric Dryer
Tip
How to Install the Heating Element of Maytag Amana Dryer?
The procedure is as follows:--- 1) First of all unplug the dryer from electric outlet for safety reasons.2) There are two panels in the dryer. One is top and other is front panel.3) Both the panels are secured by clips in between them.4) Take a putty knife and insert it in between the top panel and the front panel of the dryer. Press the retaining clips with knife and separate the top and front panel by Lifting up on one corner of the top panel to release the opposite retaining clip.5) After the clips are pressed both the panels will easily get separated. But take care there will be a connecting wires between the panels. You don’t have to pull that wire while separating the panels.6) You will see the door switch on the upper right side corner area of the front panel.7) Remove the wire harness from the door switch carefully.8) The remove the flange of the front panel to the side panel on each side by removing the screws.9) The front panel will get separated from dryer after removing the screws.10) Now with the help of screw driver remove the screws holding the drum bulkhead of the dryer.11) Now push the idler pulley between the drum and the motor assembly with you hand to loosen the belt tension.12) The belt will easily come out one you loosen the belt tension.13) After the belt is out. Carefully lift and remove the drum. Now on the lower rear side you will see the heating element.14) There are wires connecting on the sides of the heating element terminals. The wires are connected by removable connector.15) Remove the connector carefully from heating element with the help of needle nose plier.16) After the wires are removed from heating element’s terminals.Remove the screws holding the heating element.17) The heating will have to be moved a bit to come out easily. Before removing the heating element out.Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.18) Remove the old heating element and insert the new heating element.19) Connect all the wires as it were connected before.20) Refit all the parts which you removed while removing the old heating element in reverse method. Take care you don’t miss any part fitting.
This will help. Thanks.
on Mar 20, 2010 | Dryers
I think that the heating element has burned out and I want to replace it. How do I dismantle the dryer so I can inspect the heating element.
Open door. Remove phillips head screws at 5 and 7 O'Clock positions. Close door. Use putty knife to push in clips (2) relaeasing top. (located in seam where top meets front panel) Swing top back. Remove two phillips head screws at top of front panel. Unplug light and door switch. Tilt front panel forward and lift off bottom tabs. Unplug moisture sensor wire near bottom. Set front panel to the side. Look at the small thermostats on the left side of the burner cone. The one toward the front side is a manually resettable one (on gas models), reset by pushing in the little plunger in the center of the thermo. If this was tripped, it means your vent is not adequate.
Sep 25, 2010 | LG DLG5988 Gas Dryer
I have a Whirlpool Electric Dryer that is running but will not heat up. I suspect the heating element has failed. The Model Number is LEQ9508PW1. Please detail for me the location of the heating element...
unplug unit remove front lower panel . on the right side you will see the heater box element is held in place with a small screw on front left side and friction hold outer housing with hand and pull out element with a pair os pliers.
Aug 02, 2010 | Whirlpool Dryers
How do i change the heating element.
The heating element is accessible through the lower front access panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the two screws attaching the bottom of the lower front access panel to the cabinet then slide the panel down then off the cabinet. The heating element can now be accessed and repalced.
Remove the screws securing the heating element to the heater box then pull down the heating element to remove it from the heater box.
Disconnect and label the wires for the heating element and the components. Remove the components from the old heating element then transfer it to the new heating element.
Slide the new heating element up into the heater box and secure it in place. Align the slots on the top of the lower front access panel with the locating tabs on the front access panel then slide it into position and secure the bottom of the lower front access panel to the cabinet.
Apr 13, 2010 | Amana DLE330RAW Electric Dryer
Dryer wont heat
First you have to determine whether you element is in the front or the back of the machine this is done easiest by looking at the front of the machine and seeingif its one complete piece or two. If its one, the element is in the back, if two its in the front. We'll start if its in the back first. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced. Now if the element is the front everything is the same with the exception of you have to remove the lower portion, usually held on by 3-4 screws located underneath.
Apr 03, 2010 | KitchenAid Dryers
Dryer wont get warm figuered was heating element where is it? i have the front off and all i have is the blower and motor. i dont understand where th element or thermotats are,
Without the model number off of the machine I can't give you the exact location of your machine heating element.
I can give you common places. The rear of the machine facing the back on the right side is a common area.
Yours also could be at the front top rear.
Jan 12, 2010 | Washing Machines
FRONT HEATED SEATS
you need to check the resistance in each of the heated seat elements in the seat. There's a two wire connector under the back of each front seat. The connector should be green. disconnect it and measure the resistance along the circuit going into the seat. if it isnt .1 - .3 ohms, replace the appropriate heated seat element
Jan 04, 2010 | 2004 Cadillac Escalade
Dryer does not heat and continues to run/will not shut itself off
This is probably due to a faulty heating element, something the average do-it-yourselfer can replace. Disconnect the power supply, then refer to the owner's manual for procedures to remove the front panel from your specific model. If your dryer has a toe-kick plate in front, that's all that needs to be removed.
1)Locate the heating element heat shield, a box on the lower right side of the dryer.
2)Using a screwdriver, pull the two screws at the front of the heat shield. Remove the front of the heat shield or, if it is on a hinge, flip it down.
3)Remove the wire leads from the heating element terminals by pulling on the leads. To avoid damaging the wires, do not grab them when you pull off the leads.
4)Remove the holding screw on the side of the heat shield that connects to the heating element.
5)Remove the heating element by sliding it out of the heat-shield box. Install a new heating element and secure it to the heat shield with the holding screw on the side.
6)Reconnect the wire leads to the new heating element by pushing them onto the terminals. Place the heat shield front cover back into position and secure it with the mounting screws.
7)Replace the front panel or toe-kick plate and reconnect the power supply to the dryer.
Aug 28, 2009 | Frigidaire Dryers
Sears Dryer 110.66962500 Does not Heat.
depends on where the lint filter is at.
a top lint filter has the element behind the rear panel and a front filter has the element behind the front bottom panel at the right of base.
be sure to remove the element and look to see if it is broken. elements are like light bulbs, if they break then it wont heat. if its not broken then you might have an open thermal fuse. they are also on the element housing and have 2 wires on them. they are about 1 inch in diameter and need to be checked with a continuity meter.
if you can, remove the housing, then mark the wires, and take it to a local parts house and they will check them for you for free.
Jan 06, 2009 | Kenmore 62602 Electric Dryer
LG LRE30451ST Electric Kitchen Range Logo
506 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
