Question about DeLonghi Heating & Cooling
What size tubing is needed for condensation drainage?
    Problem Solver:
  • 7 Answers
2 drains main and secondary at 3/4" pvc with p-trap at air handler drain. If in attic also needs pan switch.
Posted on Aug 19, 2008
Why is water leaking from inside?
If your refrigerator has automatic defrost, condensate drains to the bottom, then through a plastic or rubber tube into the evaporation pan underneath. Sometimes the tube becomes clogged, causing the condensate to accumulate in the bottom and leak out. The tube should be unclogged to restore normal drainage.
Sep 21, 2015 | Refrigerators
How do I remove water and ice collecting under the bottom drawer?
Defrost cycle condensate is supposed to drain through a tube at the bottom rear and into the evaporation pan underneath. The tube can become clogged, preventing drainage. Also lack of drainage can be caused by the refrigerator being out of level.
The answer provided by GE is lame.
Sep 07, 2015 | GE Refrigerators
We have a hotpoint RLA 34 ( MICROBAN ) FRIDGE . water keeps seeping into the bottom , under the crisper box tried turnining temp down , made sure it's level , no blocked drainage hole . door shuts tight...
You said no blocked drainage hole, where was the drainage hole that you checked located? Did you pour water down this drain, and furthermore did you check that the water you poured into the drain flowed into the condensate pan on the outside of the fridge? Unless you have a problem with an ice maker leaking water, it sounds very much like you do have a blocked drainage hole, otherwise known as a defrost drain. the drain system begins underneath the evaporator coil inside the freezer, this is where the water that is collected in the defrost cycle flows into a drain tube that leads the water down to the condensate pan. The best and safest way to clear out this drain is to blow it out with compressed air, after you remove any and all ice at the beginning of the drainage system, in other words, the hole located underneath the evaporator coil.
Nov 09, 2010 | Hotpoint RLA31 Compact Refrigerator
Leaking water on floor, even without water hooked up. Seems to be coming from under the fridge
Your freezer defrost drainage tube may not be routed to the evaporator tray under the refrigerator. If this is the case, humidity condensed from the freezer, then drained down the tube will be dripped onto the floor.
The second theory is that the drainage tube could be blocked. Humidity in the freezer is removed from the air sent to a drainage tray, at the rear of the freezer, which has a drainage tube which carries the water to an evaporation tray at the bottom of the refrigerator unit, on my GE. if the drainage tube is blocked, the water will find another route. Check the drainage tube after you find it. First try inspection. if there is standing water in tray in the freezer, use a flexible wire to clear the tube.
Oct 04, 2010 | GE Profile TPX24PBDCC Side by Side...
2004 mitsubishi endeavor where is drainage tube located, condensate is leaking into driver floor compartment?
do you have a sunroof?
if not is your heater working? busted heater matrix otherwise
drainage tube should be located behind the drivers side kick panel
Sep 18, 2010 | 2004 Mitsubishi Endeavor
Went on 1.5hr trip when I noticed water dripping down on the pass side floorboard. Pulled the glove box and noticed a ton of condensation on the a/c box (condensing coil?). 2005 Exp V8. About at the same...
There is a condensation drainage tube that runs from the condenser to the bottom of the vehicle. I would assume this tube was clogged by somthing and the excess water was building up and decreasing the efficiency of the a/c. I would remove the drainage line at the bottom of the ac condenser and make sure nothing is blocking the drainage. Hope this helps!
Jul 30, 2010 | 2005 Ford Expedition
Air Conditioning water leak inside
The drainage tube for the evaporator case is plugged causing the the condensation to drain inside instead of outside the car. The car will probably need to be lifted to find the drainage tube. Use a pick to gently remove the debris blocking the tube. You must be very careful as not to puncture the evaporator core.
Jun 04, 2010 | 2003 Chevrolet Impala
Condensation tubes clogged and leaking into house
there usually blocked at the trap ,hook up a shop vac on the line outside try to **** it through if this doesn't work blow it back to the inside evap unit
Apr 10, 2009 | Mitsubishi Heating & Cooling
Ge profile refrigerator mod# tcx18paaarbb
drain tube is blocked .....you need to thaw it and after thawing clear drain tube all the way to condenser water tray in back
Apr 02, 2008 | Refrigerators
Heating & Cooling Logo
62 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
