Question about Whirlpool LER5636P Electric Dryer
Dryer Timer I took my dryer timer apart and now I can't get it back together again. Do you have any ideas?
  • JMS32CANDO Aug 22, 2008
    I eventually did get it back together again correctly. It just took alot of patience.
  • 706 Answers
Order a new one from any number of suppliers such as http://www.mcmelectronics.com/ they carry a full compliment of replacement parts. You will need to provide them with the brand, model number etc.. Hope that helps... ( I've doen the same thing myself and it was easier just to replace it than to try to reassemble it correctly)... Enjoy !
Posted on Aug 19, 2008
  • Rick Gelin
    Rick Gelin Aug 23, 2008
    Lesson learned to be patient.. Glad you were able to get it together !
The dryer keeps stopping (the timer skips from 50 mins to 10 mins in secs) AND what worries me the most is, I haven't needed to empty the lint trap.
Well, well.
Am I to understand the timer dial is going really fast as you watch it?
I didn't know that was possible, but maybe the wiring has been compromised (shorted out) somehow. If so, you would need to take it all back apart and look for a wire that is pinched or incorrectly hooked up. Some Whirlpool dryers have numbers on the back of the timer that are supposed to match numbers that are actually printed on the wires themselves.
As far as the lint trap, perhaps one of the "pipes" inside the dryer is unhooked or loose causing the hot air to miss the screen.
Be blessed.
Aug 27, 2012 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
Dryer will not turn off after cycle is complete
You Have a Broken Timer... There are metal points inside the Timer and can melt together so when the dryer reachs its end cycle they should come apart to leave the circuit open but wont since they melted together and continues to run. Also if the dryer has a computer board controling everything that would have to be replaced if it dosnt have a timer.
1. You will have to replace the timer if your going to accomplish this on your own you will need the model number which is located on the inside of the door opening will say mod or model.
2. You will need to find a appliance parts house in your area and call them to find out how much the new timer will cost plus to make sure they still make them and if on there shelf.
3. Once you have the new timer you will need a small flat head screw driver, 1/4" - 5/16" socket and a Phillips head screw driver to remove back panel bolts.
4. (WARNING) Unplug the dryer always make sure its unplugged or you risk being severly injurded or possible death the dryer has 220 volts running thru it!
5. Remove the back panel on the dryer where the dash is once removed you will see all the wires connecting to the timer. This is where the 1/4" or 5/16 socket comes in unless its a phillips head screw driver should be 1/4" some models will require a specail star bit normally on GE Dryers
6. Remove the timer knob should slide right off then remove the 2 1/4" screws holding the timer to the dash.
7. With new timer in hand make sure it lines up with the old one so you can put the wires back where they go (IMPORTANT THERE WILL BE 2 BLACK OR BROWN WIRES GOING TO A METAL LOOKING ROUND THING THATS THE CLOCK IT DRIVES THE TIMER LEAVE THEM WIRES WHERE THERE AT) now slowly remove 1 WIRE AT A TIME off old timer and connect to new timer where they go so you dont get wires hooked up to wrong post and fry the new timer if wires wont pop off yous your flat head screw driver to gently pry the wires off the post.
8. Place timer back where it goes there are aligment holes to help and replace the 2 screws you took out earlier from the timer.
9. Replace the back panel to the dash once completed plug in your dryer and replace the timer knob and set it to 5 mins let the dryer run till it shuts off to make sure its working properly.
If your dryer has a Computer Board the new board you order will have instructions for installing it alor the them are different on how the go in.
If unsure or dont want to fool with it call a qualified techinician to service your dryer for you but hopfully this will get you back going again have a good day.
Jan 05, 2011 | Dryers
Whirlpool electric dryer - looks like a WED5200T but no model number on the unit. The drum turns and air blows from the vent, but the timer has stopped working and there is no heat.
you have a white strip on the back of your dryer un plug your dryer first.....then un plug the strip and hook the two wires together that will allow the heat to start again.....the timer shouldnt have anything to do with the heat....turn it on and put your ear to the knob and you should here a clock sound if not your timer is bad
Nov 10, 2010 | Whirlpool WED5200T Electric Dryer
Timer
I have seen a similar question before. Look up the wire schematics and see what that wire is for. The sire schematics usually come with the dryer.
Apr 27, 2010 | Roper REX4634KQ Electric Dryer
I have a roper dryer. I took it apart today
Remove all duct work connected to this dryer. Clean thoroughly. You will find amass of lint inside of it causing your problem. If not the moister sensor is not working properly and needs to be replaced.
I do hope you will find a clogged vent tube for it is easier to clean the tube than to replace the sensor. The sensor is a fail safe part. It keeps the dryer from catching on fire when the lint tube is clogged up
Hi, I have a Kenmore Dryer Model 100.96591240. 15 years old (approx). Problem just started - I have to wiggle the Timer knob after pressing the Start button (sometimes I have to push the Start buttom and...
i took apart a dishwasher and in the timer switch there were some electrical contacts and over time they get a black burnt build up on them and need to be cleaned or replaced .might need a new switch
price one on ebay . or look at sears.com for a new part
Jan 10, 2010 | Kenmore 73952 Gas Dryer
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Element heats, dryer tumbles, no heat in drum, never shuts off
Hi, If the dryer heats but will not advance in either time or auto cycles, you need to change the timer.
You can test to see if the timer is getting voltage. Remove the top rear panel and locate the two wires going to the timer motor. There should be 120V when the dryer is running in time dry.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
I took apart timer cant out it back together
IF YOU DID THAT, I SUGGEST YOU GET A NEW ONE CHANCES OF YOU GETTING THIS BACK TOGETHER THE RIGHT WAY ARE NOT GOOD
Apr 11, 2009 | Dryers
Maytag PYE3300AZW Dryer ran great shut off after 10 min.Willnot start again. Power to dryer is there. Took it apart,brought the door switch in to test it works. There is a live wire on the Timer Wire...
you have an open thermal fuse la1053 located on the right lower side of the heating element housing, it opens when the temp reaches 300 degrees f . this is telling us that the air flow is not good, lint buildup inside the filter housing in the door is a good place to start and or kinked vent hose or venting problem
Apr 10, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
