What slot does the audio card go in? ASUSp3v4x
    Novelist:
    Scholar:
  • 141 Answers
A white pci slot. There's usually 3 as the last of the slots, with only one notch in it. Either of these won't matter.
Posted on Aug 18, 2008
Why aark24 audio card does not fit into PCI slot of Lenovo i3 processor ( windows 8 ) ?
If it does not fit in the slot, it's the wrong slot! It may be a PCI-e slot you are trying to insert the audio card into. It is very similar, but will only accept PCI-e cards. If your computer has a PCI-e slot, it should at least have one PCI slot as well (but, not all do).
May 02, 2014 | Computers & Internet
I have an older Gateway PC. Model 703GE that has always worked pretty good. Two days ago, out of the blue, the audio quit. I checked Sounds and Audio devices and see the message that the Audio Device
it would seem that your audio card or audio processor chip has died. If this is a desktop (or tower) pc, you may have an audio card plugged into the motherboard (mainboard). This can be removed and replaced. If the audio plugs come directly out of the motherboard you should still have open slots on the motherboard where you can plug in a new replacement sound card. what you need to do is determine what type of slots you have open, they are most likely standard PCI slots. You would need to go to a computer store like Best Buy and ask them to point out a new audio card to install in your system it should come with a disc which includes the drivers needed and installation instructions.
Dec 03, 2013 | Computers & Internet
I have a sound blaster audigy 24 bit 7.1 sound card . it worked fine on windows xp but when i inserted the card in the slot for my new computer on windows 7 it says that no card was found :/ when i install...
Move the card to a different pci slot on the motherboard. It may have a conflict with another device. Make sure there is no power to the pc when you do this. If you still have the problem after trying all the slots then i suggest you empty all of them and just try the audio card on its own. If it works then fit the card/s you removed into other slots. good luck.
Apr 27, 2011 | Creative Labs Sound Blaster Live 7.1...
How to install a sound card
1. Locate na expansion slot in your computer that will accept your sound card.
2.Gently place the sound card on top of the slot. Line up the pins on the sound card with the slot and push the card down so that it sits in the slot. Be sure that the card is securely in the slot and pushed all the way in.
3.If your computer has an audio cable that connects the CD-ROM drive directly to the sound card, locate it and plug it in to the card. Consult the documentation that came with your sound card to determine the location of the CD-ROM audio connector on the card. This cable is rarely necessary with current audio hardware.MORE INFO.IN NEXT SLOT
Apr 04, 2010 | Creative Labs Sound Blaster Live! 5.1...
I want install my sound card by net c97 now
Hy i'm Kabeer Khan for installing sound card it is first required AMR(Audio Modem Riser) slot on your motherboard. AMR slot is 64 pin very smal slot is like as PCI(Peripheral Compnent Interconnect) If it avialable then open your sound card and try to set your sound card. Remember one thing during installing card it must be considered that the cuts of slots should be matched according to your card alignment. After installing card bind you CPU and install driver that would be given with your sound card packet for this open conrol panel and found add hardware icon and double click on it then install driver from CD option would be selected and click next. When wizard is finished you will be able to use your sound card.
Thanks.
Regards
Kabeer Khan
Apr 20, 2009 | M-Audio Audiophile Sound Card
AUDIO CARD LYNXTWO-MAINBOARD DG31PR INTEL CONFLICT
Try installing the audio card in other PCI slots.
Also check to see if the PCI gold connectors are not damaged. Do you have another PC to check this audio card out? Perhaps there may be a misalignment on the PCI connectors. Check to see if the card lines up correctly in the PCI slot.
Mar 16, 2009 | Intel DG31PR Motherboard
Sound lost on DFI Lanparty 875
do you have another PCI slot you can remove audio card and try another slot.
If your audio still does'nt work you may need a new audio card
Jan 27, 2009 | DFI LanParty PRO875 Motherboard
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
