Question about Kenwood KAC-7202 Car Audio Amplifier
Battery hook-up RV application. 4 AWG power and ground wires with no inline fuses. I did not do the original installation. I was having trouble distinguishing power and ground lines when I inadvertently touched the positive amp wire to the negative battery pole and got a spark. The negative side of the amp was tied to chassis ground. I then went to install the positive wire from the amp onto the positive pole of the battery. When I did this, I got another spark. Don't want to secure the positive cable until I figure out why I'm getting a spark when properly installing the wires to the battery. Any ideas? Thanks
  • 631 Answers
You must have inline fuses at the point where the wire taps off of the power source. If you're tapping off a wire that has no fuse (like the starter solenoid), you must insert a fuse.
When making the connection to the amp, there will be a spark initially. If you hold it on for a second, pull it off and then touch it again, there should be little to no spark because the capacitors in the amplifier would have charged when you made the initial contact. If there is an intense spark each time you touch it and the amp is not on (no remote voltage applied), the amp may be defective.
Let me know if you have any other questions.
Posted on Aug 18, 2008
I have my cb grounded and a wire ran to the postive side of my battery terminal and the antenna wire ran and my cbs channels wont come up we thought it was jus my cb so we hooked another up and it did the...
Here is the deal, even with out antennas hooked up, you should get at least your channels on your cb showing, no of course you would have all noise and distortion with out antennas hooked up. And sense you hooked another cb up with same results it tells me, number one, it is not most likely your cb. If your channels are not even lighting up, then this tells me it is not getting power. I know you said that the cb is grounded, and there is a wire ran to the positive post of the battery. What I would do first of all make sure proper wire on cb is grounded and not reversed accidentally, but what i believe is your not getting power to the unit, if it was properly installed, there should be a inline fuse from the cb radio to the positive post the wire is connected to on the battery. I believe there is a inline fuse that is blow, or not a good connection on the post of the battery. To test this theory, take a long piece of same size wire gauge, and run direct from positive on battery to positive post on battery, of course making sure that the proper wire off the cb is grounded (must be grounded to something metal, might find different spot to ground the radio if not for sure on metal) If you get lights going on then on radio, then your problem, was not a good connection or inline fuse on positive wire that maybe you didn't see was blown. Let me know Mike
Aug 26, 2011 | Radio Communications
Just installed new steam shower, it produces steam for about 5 minutes and then blows the fuse
Based from your comments, a new steam shower that blows the fuse in five minutes. You could have installed a new steam shower that is much bigger than what you previously have.
1. For a 5000 watts steam shower at 220 volts
power must have a fuse rating of 40 amps, supply
wires of at least No. 6 AWG Type THW ; and at
110 volts a fuse rating of 80Amps, supply wires
of at least No. 2 AWG type THW.
2. For a 4000 watts at 220 volts, Fuse: 30 amps,
Supply wire: No. 10 AWG type THW. At 110volts
60 amps, Supply wires : No. 4 AWG Type THW
3. For a 3000 watts at 220 volts, Fuse: 20 amps
Supply wire: No. 10 AWG type THW; At 110volts
Fuse: 40 amps, Supply wire: No. 6 AWG THW
4. For a 2000 watts at 220 volts, Fuse: 15 amps
Supply wire: No. 10 AWG THW and at 110 volts
Fuse: 30 amps, Supply wire: No, 8 AWG THW
Nov 27, 2009 | Hammering
When i hook up my 750 watt inverter to my truck do i need to install a isolator or inline fuse? or just connect the 4 gauge battery cables directly to the battery and the inverter?
Yes, inline fuse as close to the battery as possible. If 4 gauge wire were to ground out without fuse, would most likely start a fire or at least damage other existing harnesses (depending on routing) before a person could disconnect battery.
Oct 13, 2009 | Whistler PI-1200W 1200-Watt Power Inverter...
Problem with power ausoutic 5500watt amplefier
With a 5500 watt amplifier you should be running 0 awg wire . You also need to be running an anl fuse holder with a 250 amp fuse underneath the hood by your battery. When the power light blinks like that it means that it needs more power - ie. that there is resistance some where in the system . With 4 gauge wire it just isn't getting what it needs. Make sure you upgrade the ground as well to 0 awg . If you have any other questions please feel free to contact me mmaudio545@yahoo.com
Aug 26, 2009 | Kicker KX1200.1 Car Audio Amplifier
4 AWG amp wire
For that amplifier you need to be running 0 gauge wire . Also check your ground to make sure you have the best connection possible.
May 16, 2009 | Power Acoustik A2400DB Car Audio Amplifier
No electric after turning key to start
im working on one of those right now ther are two inline fuses on the batt side, driver side they go to the firewall conector they should have a gray strip around them saying fusible link. test on conector side for 12v of both wires that will tell you if the link is bad sounds like the problem if no power is going inside to your fuse panle fusible links can look good if they havne melted through the insulation and still be bad the other thing is if you do have bad fusible links ther is a reason for it, most likley power to ground eather in chassis harnes or engine harnes being a coachman it could be anywhere
Apr 05, 2009 | 1983 Dodge Cargo
I bought a 2400 watt punch 801s amp that has two power out and two ground outs i've hooked up only one power and one ground and the amp comes on but as soon as i touch the speacker wire to it it hits one...
Check the gauge on the wiring. For that size amp you would need to use 0 AWG wire for the power, the speaker wire is just signal wire so you want to use regular speaker wire. (I have 12 AWG setup for speaker wires) What the two power ports (Neg and Pos) do is increase the amount of flow. Two power wires to distribute the flow of the current so you don't burn up your wires if your pumping too much juice. I started off with this exact amp running a single 8 AWG and split it into two and it burned up and blew a fuse after a couple of huge bass hits. So proper setup would be....
BAT(+)---FUSE HOLDER(60AMP+)---DISTRIBUTION BOX(30AMP+)====AMP
GND(-)===AMP
-- would be 1 wire pref 0 AWG splitting into more 0-4 AWG
== would be the 2 wires (Yes two ground points in separate locations would be better)
Thus finalizing you have a proper setup.
Be careful you don't burn out your alternator, this bad boy can cause some serious problems with a lower amp alternator. Let me know how it works out.
Aug 15, 2008 | Rockford Fosgate Car Audio & Video
Alpine pdx-1.1000
what is happening is the amp can draw the current. u need a capacitor
Apr 11, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Car amp
The 2 + and 2 - connections are the same, just split into two. This is usually because, for high power amps, it's easier to route two 4 AWG wires than it is one 2 or 0 AWG wire. Both "+" will go to your battery (through a fuse block, of course) and both "-" will go to a grounding point.
Mar 10, 2008 | SPL Phantom DK2-1000 Car Audio Amplifier
Kenwood KAC-7202 Car Audio Amplifier Logo
76 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
