Question about Maytag Washing Machines
MAHW2000AWW washer front load washer leaks. Leaks from the front door.
  • 706 Answers
Some of the new front load washers develop damaged hinges from too much laundry detergent..With that said, when you close the door..does it close easily or do you have to work it in? Try using your knee against the hings side to 'nest ' the door when you close it.. .. Also.. take a good look at the gasket material for any abnormalities or tears in it.. Hope that helps...
Posted on Aug 19, 2008
Whirlpool duet washer leaks but not every load
Pull the kick panel under the door and when it leaks, you will be able to tell where from. Hopefully not the tub.
Oct 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
I have a LG front load washer seem to leaking front area. Hoses OK Need o see what causes it to leak
you will need to narrow down where the water is leaking from. under the door...? behind the bottom drain door..? underneath machine..? behind machine..? leaks can be found in many areas.
May 16, 2011 | LG WM-2277HW Front Load Washer
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Hole Rubbed in Bottom Door - Leaks Through Front
If you can get to it you can use an epoxy made for metal or something like jb weld to patch the holes.
Sep 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
LG front load washer leaks from door gasket
This is best left for a proffessional to repair
Affordable Appliance Repair
LAke Forest, CA. 92630
Aug 21, 2009 | LG WD-3274RHD Front Load Washer / Dryer
Torn door seal on front loading washer
My husband used super glue on the tear and for now the washer is not leaking.
Mar 25, 2009 | Kenmore HE2 Plus Front Load Washer
Ge front load washer leaks from bottom
full display
And for the part numbers look here
Have fun with it and please rate me on this site
Apr 19, 2008 | GE WSXH208A Front Load Washer
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Water leaks through bottom of Front door
The manufactures suggest putting washers on the back side of the hinge to draw the door tighter to the seal, otherwise you may have to replace the seal.
Oct 30, 2007 | Kenmore 44042 Front Load Washer
Washing Machines Logo
76 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
