Question about Texas Instruments TI-83 Plus Calculator
How to reset my TI-83
I have the mirageOS application and i set a password on it. i cant remember the password either. problem is i blocked memory access through the MirageOS app
So is there a way to reset my calculator?
  • 1 more comment
  • s_p_ritenu Sep 03, 2008
    is there a reset that I can try for the TI-83 Plus Calculator?
  • jeffbuscher Dec 10, 2008
    replaced batteries - blank screen - is there a reset?
  • domwrx Feb 10, 2009
    new batteries blank screen
Yes, hit 2nd then hit the plus sign for mem.. then hit 7.. then 2 then hit 2 again... so do a system reset
Posted on Dec 03, 2008
Hallo,
Some people are asking how to ''fix'' their calculator. Becaus the screen is blank after replacing the batteries.
This is simple, because the calculator is not broken. You can make the screen darker and lighter as you wish, and in this case the machine makes it all light. solution:
-press 2nd and than press arrow up (keep presssing it).
The screen will now slowly become visable again.
Posted on Apr 03, 2010
Well, i dont know if its the same for TI-84 silver, but try 2nd, +, 2, scroll for App , find MirageOS, and delete it. Sorry if it doesnt work...
Posted on Feb 15, 2009
Http://www.fortlewis.edu/academics/school_arts_sciences/freshman_math/math_help/TI83Plus_Guide.pdf
Posted on Aug 21, 2008
Ti 83 will not power on replaced all batteries
When you clear memory, the contrast sometimes changes. If the screen
is faded or blank, adjust the contrast by pressing 2nd and up- arrow or down- arrow keys .
Resetting RAM restores RAM system variables to factory settings and
deletes all nonsystem variables and all programs. Resetting defaults
restores all system variables to default settings without deleting variables and programs in RAM. Resetting RAM or resetting defaults does not
affect variables and applications in user data archive.
Tip: Before you reset all RAM memory, consider restoring sufficient available
memory by deleting only selected data.
To reset all RAM memory or RAM defaults on the TI-83 Plus, follow these
steps.
1. From the RAM ARCHIVE ALL menu, select 1:ALL RAM to display the
RESET RAM menu or 2:Defaults to display the RESET DEFAULTS menu.
2. If you are resetting RAM, read the message below the RESET RAM
menu.
• To cancel the reset and return to the home screen, press .
• To erase RAM memory or reset defaults, select 2:Reset.
Depending on your choice, the message RAM cleared or Defaults
set is displayed on the home screen.
Mar 25, 2012 | Texas Instruments TI-83 Plus Calculator
steps.
menu.
I have attempted to transfer an inequalz app from on TI 84 plus calc. to another TI 83 plus via the black serial cable. I get the following on the screen of both calculators. ERR:memory 1:Quit 2: Goto...
The problem may be due to a lack of memory in the receiving calculator. Check size of the Inequalz application, the size of the archive memory left on the TI83 Plus, and the number of application spaces that Inequalz requires. An application may require 1,2 or more application spaces. You will have to go to education.ti.com to get the information.
Also, make sure that the batteries are good in both calculators.
Sep 23, 2011 | Texas Instruments TI-83 Plus Calculator
I need to clear the memory on my TI-83 plus, but when i hit "2nd +" the memory screen does not come up. I have to show my professor the "MEM CLEAR" screen in order to take my exam!!
If you have MirageOS installed under the APPS button on your TI-83 plus, it may be blocking your memory menu. Enter MirageOS and press the ALPHA key. It may ask for a password which will have been set by the user. If so, you will need to enter it in. Go down to the option: Tasker and Key Hooks. There is an option that says: "Block the memory menu from access". Disable this, and you should be able to access the memory menu.
Feb 13, 2011 | Texas Instruments TI-83 Plus Calculator
How can I back up the memory of my TI-83 plus ?
Connect it to the computer with the USB SilverLink cable. Run the TI Connect software and click the BackUp icon in the application main window. The memory dump will be saved in you (computer) user profile in MyTIDdata/Backup.
Mar 04, 2010 | Texas Instruments TI-83 Plus Calculator
Random symbols and/or dots all over the screen, cursor in middle of screen an turns off randomly
1. Press [2nd][QUIT] to interrupt any program that may be hung in memory such as games run under MirageOS.
2. Clear the screen by pressing [CLEAR].
3. Reset memory [2nd][MEM][7:Reset][1:All Ram][2:RESET] [ENTER]. ram cleared appears on screen.
4. Press [CLEAR] to go to Home screen.
Hope it helps.
Sep 30, 2009 | Texas Instruments TI-83 Plus Calculator
Can you delete ram with ti connect?
This is your question which I think is the solution for this question!
I downloaded Mirage OS, and now I can't download any of the games. I downloaded tetris before, and then I came back and can't download anything through TI connect.
Obviously, at times ti connect is going to be worthless to you if you have OS Mirage. So, that's correct! Plus, it didn't cost me a calculator to find that out!
For you to get it off? I can think of a few, I glad I don't have too..
May 26, 2009 | Texas Instruments TI-84 Plus Silver...
I cannot access my memory
"How can i delete this program without using memory?"
By that I am assuming the memory key on the TI, the only other way to remove applications is through the TI connect software which will require the use of a USB cable in the case of the TI-84.
TI connect will also let you backup anything important you may have on your calc. Good Luck:
Download TI Connect
Dec 16, 2008 | Texas Instruments TI-84 Plus Silver...
Ti 83
2nd MEM RESET DFLTS This should restore your calculator to orriginal default settings. No offense but even the manual does not recommend wiping the memory, i would avoid this step in the future Get the TI-83 for dummies book It really helps d.l.l.
Mar 13, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
2,604 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
