Question about Soundstorm F200.4 Car Audio Amplifier
Soundstorm F200.4 troubleshooting
Have this amp in a boat . No green power lite , or red lite when powered up . Outside fuse intact . Is there another fuse someplace ... help
  • phanssen7 Aug 19, 2008
    checking all connections was first step after checking fuse , is there only one fuse on this amp
  • phanssen7 Aug 20, 2008
    answer did not help me , but thanks for the input ,can you suggest an amp for damp conditions
    Brigadier General:
  • 6,966 Answers
To my knowledge, there is only one (1) fuse, external 40Amps. The absence of the green light on standby is significant, this would mean that the unit is not receiving main B+12. With the use of a voltmeter, were you able to check for the presence of +12 on the appropriate terminal/fuse? If yes then it is an internal problem and would strongly suspect possible corrosion on the connections/wirings inside. It is also possible to have cold solder.
Further diagnosis and repairs would of course require opening the unit, familiarity with electronic components and circuitry, use of a DVM as earlier stated and a soldering iron. Foremost to check would be the supply input to the DC to DC converter. Should you be uncomfortable going this route, perhaps your next best move would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 19, 2008
  • Louie  Role
    Louie Role Aug 19, 2008
    Hi again,
    If I may add, often in a marine environment, voltage check would not be sufficient, it must be done under load, meaning voltage should be checked (+12) with a load connected.
    Genius:
  • 1,056 Answers
Agreed, check connections, but how did you check them?
I would suggest a multi meter to check the + side voltages, and also check for good ground to the unit. If the ground is bad, everything else can be good, but you'll get the same results as you are describing. That can be with the multi meter, or a simple circuit tester. At least re-ground it to take that unknown out of the equation.
There is only the one fuse in the unit, and I would also check that beyond a visual, and for the price of a fuse, I would just stick a fresh one in. Sometime a visual check won't reveal if the fuse is good or not.
If that all checks out, it is time to replace that unit.
The F200 is no longer produced, and at what it would take to take it to a shop to have it repaired it's really not worth it.
I would start looking for a replacement.
    Sergeant:
    Champion:
  • 298 Answers
There may be one internal it will be a glass tube type.
if not you need to take it in for repairs. it might be cheaper to buy a new one if that is the case.
please rate thanks
Posted on Aug 18, 2008
    Master:
  • 623 Answers
Check all connections
All the lights are not working found 2 blown fuses / replaced still not working the power lite flashes red then turns to green
When a fuse blow suspect an overload. In an amp this old it will certainly be one (or more) of the main output transistors that has shorted.
Sep 25, 2013 | Sansui 1976 9090 Receiver Amp Vintage
This is not a car question. I have a boat (Ford Escort Diesel engine) that uses a separate voltage regulator. My alternator has not been charging properly and there is a 5 amp drain in my system that I...
You can take your voltage regulator and alternator off and take to most auto parts store and they can test them to be sure.
A 5 amp drain is significant if it is a constant drain. You might want to use an accurant clamp on amp meter to troubleshoot it. I assume you installed a fuse panel, so start by pulling all fuses, and then putting them in one at a time - write down your readings. The one that is highest is probably the line you need to troubleshoot.
But before you go through all that, do you have a refrigerator on your boat that is DC? If so, I would make sure that it is turned off before spending time troubleshooting.
Jul 01, 2011 | Ford Escort Cars & Trucks
ONE OHM STABLE 2500W MAX POWER AMP DIAGRAM ON 2
For a 1ohm load it's positive to positive and negative to negative run 1 wire from one speaker to the other. Positive to positive neg to neg. Then 1 wire from the speakers to the amp. The amp will have + - + - on it's inputs for left and right speakers (if stereo) Use the outside positive and outside negative. If there are any switches on the amp that say "mono" "stereo" switch to "mono". Hope this helps
Jun 20, 2009 | Soundstorm 500.2SL Car Audio Amplifier
4000.1 soundstorm amp
Hello GregV24CHOPP,
The Soundstorm products are in about the same category as Boss, Visonik, Pyle, and Lanzar to name a few. Somewhere between overrated and definitely overpriced for the quality you get.
Look into the Alpine MRP-M1000. RMS = 1kW into 2ohms (600 into 4ohms), YES 4 OHMS(!), real power. No, it WON'T do one ohm. But most of those claiming to are not CEA2006 compliant anyway and can claim any power at any load and advertise for whatever buyers they can attract for their bottom-of-the-barrel products.
The MRP-M1000 is currently on sale at Crutchfield for only $347. Awesome power, and very good sound quality, too. I'm currently running 2 4ohm MTX Thunders off of "little brother", the MRP-M500, and they really shake the pavement.
You have to spend good money to get good power, there is no way around that.
The only wiring configurations for 2 2ohm DVC subs result in 0.5ohm, 2ohms, and 8ohms impedance. Check the Rockford-Fosgate "wiring wizard" for the different diagrams.
Hope this helps.
May 13, 2009 | Soundstorm CR4000.1 Car Amp
Can u help me
The amp probably has shorted outputs. Do you want to try to troubleshoot it and repair it yourself?
Nov 22, 2008 | Soundstorm D500.4 Car Audio Amplifier
My "Power Acoustik OV2-420" has a problem. Some advice please!!!
It appears that the output transistors have failed. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Oct 04, 2008 | Power Acoustik GOTHIC OV2-1200 Car Audio...
I dont know how many watzz is my amP!
200 X 4 does mean 200 watts times 4 channels. In other words each channel pushes out 200 watts. I believe u have a total output power of 800 watts but check with ur manual and if u do use that much power make sure you check for overheating, specially if its used for bass. Soundstorm amps cant take much of a beating so be careful.
Jan 27, 2008 | Soundstorm F200.4 Car Audio Amplifier
Amp has Red LED light on.
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 05, 2007 | Soundstorm F2600 Car Audio Amplifier
Soundstorm F200.4 Car Audio Amplifier Logo
49 people viewed this question
Top Soundstorm Car Audio & Video Experts
Coss
hoyzee1
Are you a Soundstorm Car Audio and Video Expert? Answer questions, earn points and help others
