Question about NEC Dterm DTP 16D-1 Corded Phone
How to change the number of rings on an NEC Dterm80 Phone.
I just called our telephone service company to find out how to change the number of rings on my phone (currently 2, ideally 3 or 4). Apparently, they want a minimum of $120 to come out and change this. Is this completely ridiculous?!? Does anyone know how or if a technically savy person like myself, could do this and not have to incur such a ludicrous charge?
Thank You!!!
SOURCE: NEC Dterm 80
Press feature; press 9; press #; use key pad to change time; press recall to change am/pm; press feature again to when time correct; new time should show.
Posted on Mar 24, 2008
SOURCE: Change time on nec dterm80 phone
Press the "Speaker" button and enter 728 on the key pad. Then enter the correct time in 24 hour format. For example at 2.56 p.m. type 1456. Then press speaker again and you're done
Posted on Apr 22, 2008
  • 149 Answers
SOURCE: Headset for NEC Dterm80
Do a search for a plantronics headset. All of theirs work well with NEC
Posted on Nov 13, 2008
  • 149 Answers
SOURCE: NEC Dterm80 Telephone
If it stays on till 10 than the clock on the voicemail is wrong. it is still an hour behind.
access system manager mailbox enter password
listen for manager options 1=yes 2= no
listen for schedule changes 1
listen for time, would you like to change it 1
enter new time.
ldtsnj.com
Posted on May 15, 2009
  • 3 Answers
SOURCE: NEC Dterm80 ring tone
To here ring types hit speaker then 711, then 1 for internal rings (select 2 for outside ring selection) then 1-8 the ring type.
To set ring type hit speaker then 720 (follow all the steps above).
Posted on Jul 28, 2009
How to disable do not disturb on NEC Dterm80 phone?
Have a coworker call your extension to see if DND is on, they will go straight to voicemail or get a fast busy. Speaker 42 may be the default cancel DND code, depending on your system and whether the codes were changed. Anyway, ringing is set up in system programming. If someone calls your extension it will likely ring, but outside calls have to be assigned to ring in system programming. Usually need a tech to do the programming since it gets complicated very quickly.
Sep 09, 2014 | NEC Dterm DTP 16D-1 Corded Phone
Nec dterm80 how to keep the voicemail from
Check the controls window and recheck your settings. Set as you like.
Oct 03, 2013 | Mrv new 8000 40 port term server dc power...
I have nec dterm80 phone system and was not here when they set it up. How do I get the the main greeting that everyone hears when they call into our company. I need to change it!!!
This is a transaction box (like mailbox but does not take message)...You need the mailbox number & pass word. If you do not have notes on the system configuration you will need to get support from your vndor
Sep 09, 2010 | NEC Dterm DTP 16D-1 Corded Phone
I am trying to change the name displayed on my nec i-series phone. How do i do this?
Assuming you are not an NEC trained Tech and your system is on a IPKII, You will best served by acquiring the IPKII Instalation manual and the Feature and services Manual.
This is not the kind of simple change that the average end user should attempt although I would agree that it is a feature that should have been made availiable to the average user because of occasional movement in
any office environment.
Jul 22, 2010 | NEC Dterm DTP 16D-1 Corded Phone
DTerm80 phone, how to get language on display back to english
The keyset’s display provides a 3-line, 24 character per line alphanumeric
display that displays various information for the telephone
either while on a call or while idle. You can change the contrast of the
display as well as the language used when displaying the prompts.
1.On an idle telephone with no BGM,
or .
Pressing either volume key adjusts
the LCD display.
If BGM is enabled for the phone, in
order to change the contrast, it must
first be disabled (CALL + 825) or it will
adjust the speaker volume.
1. Press + + the language
number to be displayed (00-12).
0 = Japanese 1 = English
2 = German 3 = French
4 = Italian 5 = Spanish
6 = Dutch 7 = Portuguese
8 = Norwegian 9 = Danish
10 = Swedish 11 = Turkish
12 = Latin American Spanish
To change the
displayed language:
To adjust contrast:
58
Jul 28, 2009 | NEC Dterm DTP 16D-1 Corded Phone
May 20, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Line rings does not fo to voice mail
The call forwarding was canceled; try this
1. pick up handset or press speaker
2. dial the code for call fwd busy/ no answer (default code is 744)
or press the forward function key
3. dial 1
4. dial the extension (lead number of your voice mail)
5. press speaker or hang up
May 20, 2009 | NEC Lands Phones
I have a NEC Dterm80 phone system
you need to program call forward all to outside number
speaker, dial 42, enter 9 plus phone number
speaker
it must be allowed in class of service though
Apr 07, 2009 | NEC Dterm DTP 16D-1 Corded Phone
NEC DTerm80 phone
I have the 8 button phone and if you hook up your headset the right way you just have to press the line/feature access key all the way to the right instead of picking up the receiver. Keep the headset on all the time and just press that button to answer or hang up the calls. It works great! ( I have the Dterm80 telephone)
Jun 30, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
537 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
