Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Where do i plug it into my tower?
I have the cord plugged into the machine but i dont know where to plug it into my tower!?!
  • 876 Answers
Does it have a large wide plug with lots of little prongs or a small one? If it is a large one, there will only be one place that it will fit on your tower and it will screw down. If it is a small one you can plug it into a USB port that has a little symbol on it to match your symbol either on the front or back of the tower.
good Luck
Thank You rating this solution!
Posted on Aug 18, 2008
I want to clean the dust from my tower and blow canned air, but does the blue plug on cord pull straight out ?
Dear bonnie,
Years ago, on a computer tech help site, I read a posting warning against this unless a last resort? It said that if all was well - leave it be! as moving dust from where it has settled could possibly cause a 'short-circuit' & burn out components. Also do not know which cable is "blue plug on cord"? Make sure power is off at wall. The power plug pulls straight out from computer. Other plugs have obvious screws/screw-posts. If you are going to fiddle around inside your box, best practice is to wear an anti-static wrist band attached to metal screw/frame with power OFF at wall but leads still plugged in - (this will ensure that the computer is earthed & your body static - up to 50,000volts! - will not fry any components). I hope that this helps - kind regards - 'b'ye - Bruce.
Jan 01, 2014 | E-Machines eMachines Desktop PC
How do i unplug big blue cord on tower emachine
You do have to unscrew the two screws on either side of the plug to remove the cord. Hope this helps.
I have a Sharper Image Power Tower 200 and I don't know where to plug in the power cord. Thank you.
On the same side were the turning knob is located, all the way down under the base there is a very subtle slot to plug in your cord.
Aug 13, 2011 | Sharper Image Power Tower Motorized DVD...
The power button came unplugged from the tower i need to know the order they go in so i can put them back in.
EVerything should be color coded. The big black cord for power has to be plugged in last. all other plugs can be plugged only in one spot. here is a link for reference of what the jacks can be used for
http://support.gateway.com/s/Manuals/Desktops/8511862.pdf
Mar 03, 2011 | E-Machines W3410 PC Desktop
No monitor display when machine is turned on.
Well first two questions and my apology if this sounds elementary but I need to ask. First, is the monitor plugged in to the back of the computer (the tower)? Second, is the power plugged in to the monitor? Just because you have power to the tower does not mean the monitor has power. So at a minimum you must have two cords running to the monitor for it to function properly.
Dec 23, 2009 | Dell Dimension 2400 PC Desktop
I dont know where the Dell 725 Printer Power Cord goes into the tower Which outlet on the tower
The Dell 725 printer power cord does NOT plug in to the tower. The Video Cable, on the other hand, plugs in to the tower's video output. Look for a connector like the one from the printer (often USB these days) to plug it in to the computer. There was a diagram that came with the computer that showed how to do all the connections, and the Power Cord does NOT plug in to the tower. USB connections are in various locations on your computer's tower, in the back and sometimes in the front too.
Nov 09, 2009 | Dell 725 InkJet Printer
How to load mp3
You need a cord that goes from your phone to the pc. The end that goes in to the pc is a USB connection. It is wide and thin and you will see the slots (usually in back). There may be slots in front depending on your tower. That's it.
Dec 29, 2008 | Nokia 6600
Presario s4020wm tower
start with the power supply and verify that it working if not replace the power supply with one that is known to be good then if you still have no power check to see if the voltage selector is set to 115 not 220 if this all checks out good than you will need to verify that all the connectors to the motherboard and all drives are secure i have got a lot of dead computers to come alive just by unhooking the power cord to the computer and opering up the tower and 1 by 1 unplugging and replugging in all the wires to the board and harddrive and cd rom and dont forget about the cmos battery and than pressing the power button for 3 seconds than plug in the power cord to the computer and try to restart ok good luck !!!!
Aug 07, 2008 | Compaq Presario 5000 PC Desktop
It wont stay on
probably bad memory, 256MB DDR (PC 2100)
Jan 21, 2007 | E-Machines T2642 PC Desktop
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
51 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
