Question about iLO DVDR05 DVD Recorder
Hooking it up correctly
I dont have an instruction manual and Im not sure what needs to be plugged in where. I have a 37" flat screen hdtv. And I also have a dvd player which I believe has to be hooked up with this to record from a dvd. Can you help me please?
If you hook up using the tuner in ILO you will lose digital signal to the HDTV (it will still go thru but only as analog) so... Use a splitter from the antenna coax to the "antenna in", then you can hook Ilo output to the tv inputs. You can watch/record analog through the ILO and still switch back digital non recording on HDTV thru its own separate tuner. Hook up the dvd player outputs to the ILO inputs(use the front ones is easiest) and then select SOURCE, pick corresponding inputs and enter. You can watch/record from other dvds that way but not from copyrighted ones, It will say protected content. I would only hook up dvd player temporarily to record from dvd player, then to watch dvd's just hook it up to HDTV. If you can select progressive scan on player to HD it might be even better picture but I don't have HDTV so I'm not sure how that works. Maybe more at this site: http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/ Someone says they are very similar recorders. The front covers are alike i know. Hope this helps.
Posted on Aug 26, 2008
No picture
check if all the plugs on the back of the set (red, yellow and white ) are inserted correctly
Apr 01, 2010 | Insignia 37" LCD Flat-Panel HDTV
I need an owner's manual for samsung 37" 1080p lcd hdtv.
Have you gone to the http://www.samsung.com site and hover on SUPPORT and select DOWNLOADS. Then enter your model and see what manuals are available.
Mar 07, 2010 | Samsung 37 in. Flat-Panel LCD HDTV
Screen went blank after hooking computer to it
Let's cover the obvious.
The TV works fine with other inputs (cable TV), right?
The laptop is plugged into the VGA port on the TV and the input setting is set to "VGA", right? (or does toy computer have an HDMI port that you are using?)
Is it a laptop or a PC?
If it's a laptop and the TV is connected correctly and functioning otherwise, you need to turn on the remote display port of your laptop. It's a key sequence that toggles from laptop -> external -> both.
If it's a PC, it might be a signal incompatibility. Try different resolutions or refresh rates.
Good luck.
Aug 09, 2009 | Insignia 37" LCD Flat-Panel HDTV
I am not sure of the location of the hd port on my magnavox 37 inch hdtv. i am hooking up my dvr and am not sure where to start looking.... it is hanging on the fireplace.
You should have a Component Input with Red-Green-Blue, those three plug into Comp1, if not used. If they are then use Comp 2 .Dont forget your red and white audio, that goes into Audio In. If you use just the Yellow lead that will not give you HD.
Apr 15, 2009 | Televison & Video
Does anyone know how to program a 37' olivia with out rem.
You need to get a User's Manual. Go to http://www.retrevo.com/samples/Olevia-LCD-TV-manuals.html and download one. If it is not the exact model, the programing info show be very similar.
Mar 09, 2009 | Olevia LT37HVS 37 in. LCD HDTV
When in HD entire screen is solid green
Many products have HDMI incompatabilities causing this symptom. I recommend hooking up with component cables instead for much more reliability and comprable picture.
Dec 07, 2008 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Phillips 37 HDTV, have audio but no video.
check all the cables, are they plugged in correctly. if so its broken im affraid.
Dec 07, 2008 | Philips 42HF7444T 42 in. Plasma TV
Replace fuse for flat screen 37 sylvania flat screen
i have a black cloudy area about 2 inches wide and 14 inches long at an angle onmy 37 ninch sylvania hdtv
Nov 02, 2008 | Televison & Video
Toshiba 37 inch TV
do you have the satellite hooked up through the coax cable if so that could be the problem you will have to manually set the settings with the remote. always make sure you have only one thing hooked up at a time. if you have cable and satellite dont hook up both it makes the picture lousy see the owners manual i think its page 58 or somewhere close to there.some times if both are hooked up it will not work at all.
Dec 10, 2007 | Toshiba 37HL67 37 in. LCD HDTV
iLO DVDR05 DVD Recorder Logo
164 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
