Question about True Freezers
True freezer Freezer model T-23 f serial # 1-3120564 & unit serial # T2168GK has stopped cooling. I lost all items in freezer. Unit is at room temp and will not cool. Shut unit off for 24 hours and re-started. Same problems. Coil behind lower bezel was plugged with lint. I cleaned it before turning power back on. What can I do?
  • Anonymous Mar 18, 2014
    Had a power outage, went to check on freezer when power came on and no power to unit. tried different power source, checked the fuse nothing
  • 876 Answers
Just to make sure--is the freezer plugged into a GFI outlet and is the little red button pushed in? Is it on it's on circuit and has it thrown the breaker?Have you tried a different outlet? Do you have any lights at all- showing power? did you have a power outage? If you had apower outage and it ruined your freezer, your homeowners insurance may cover it. I would have it looked at for an estimate.Ask ahead what a service call costs, and make a decision from there.
Posted on Aug 18, 2008
    Master:
  • 623 Answers
Check the condenser and freon
Hi.. I have a defy upright freezer.. it is currently displaying an error "c2 !". Defy say this is because of the change in outside temp. Is this true, how long is it supposed to last? Many thanks.
If unit is not in a controlled environment yes temp will be confused and will take 24 hour to correct but if outside temp is changed it will do again and again all units designed for controlled temp room not outside in garage or out buildings with no heat or cooling controled room
Feb 28, 2017 | Freezers
Hello my freezer is not cooling properly and the defrost timer is . making a loud buzzing noise. Please help
Your freezer compartment will freeze up and not cool properly if the defrost timer does not allow the unit to go into its self defrosting mode to get rid of the ice that serves as an insulator.
Replace the timer.
Jan 19, 2015 | True T-23F 23 Cu. Ft. 1 Door Freezer
Our True Freezer quit cooling properly. I'm not sure which model it is. Serial # is 10883769-6876. It is at least 13 years old. We would like to know who we could call to service it. Our location is...
Use this link for the True website fill in your zip code
http://www.truemfg.com/ServiceCoLookup.aspx?language_id=1&event_id=401&from=food&Country=USA
It may be more cost effective to find your local reputable fridge guy, True are a standard refrigeration unit and most parts are generic
Hope this helps
Gordon
Apr 12, 2011 | True 35 cu. ft. / 991 liter Commercial...
Regarding replacing the temperature control on the True t-23f freezer, I can't find it.
As soon as you open the freezer door the temp control is at the upper right of the freezer.
Mar 20, 2011 | True 23 cu. ft. / 651 liter Commercial...
I don't have the model number. Fridge/freezer five years old with an electronic control panel on the freezer door. Freezer temp not showing, nor can it be adjusted. Freezer temp lowering, but appears to be...
Well, its good that it is still cooling, however since you cannot adjust the temps, you do still have a problem, and one that may include the unit fails to cool properly.
Oct 04, 2010 | Whirlpool Freezers
My freezer does not work all of the time. I HAVE NOTICED that the freezer get very hot at the top of the unit, I have measured this with a digital therm.and temperture was reading 136 degree F. and,the...
The first thing to check is the condenser coil at the bottom of the freezer. Take the slatted front cover off at the bottom where the compressor is located. You will see the conderser coils. This looks like a radiator with aluminum fins, about 16 by 16 inches square. Be sure the coils are clean. Since the compressor is close to the floor it pulls a lot of dust into the coils. You may need to take a long stiff bristle brush to get as much dust as possible off the coils. If this is stopped up, the unit will definately overheat very quickly. While you are down there make sure the fan behind the coils is running. There are several reasons the fan might stop running. The motor can burn out, something can impede the fan blades such as paper, or sometimes rodents. If the fan isn't running the compressor will overheat and shut off. Once you check these basic things, you may then have to address the problem of dissapating the heat. The answer to your question is yes, it will shut down if it gets too hot. You need plenty of air space behind and over the unit in your situation. The air needs to flow into the front bottom section of this unit and flow freely out the back. All commercial refrigeration is designed to operate in 75 degree areas. As your room temperature increases the efficiency of the freezer will decrease. It is not uncommon to find these units in kitchens where the temperature is 85 even 90 degrees. They will continue to work, but will probably run all the time. I would think if you could get 3 to 4 inches of space at the back of the unit and the two feet above the unit with clean coils and properly running fans, you should get better results. You MUST have free flowing air to keep the unit running. The ideal situation is to have the air flow directly through from front to the back of the compressor compartment. In your case, you may have to move the freezer away from the back wall and allow the air to flow up the back of the freezer and out over the top into the room. 2 inch holes are not enough.
Sep 23, 2010 | True 23 cu. ft. / 651 liter Commercial...
My freezer will freeze for about 2weeks then it starts to get warm when I turn it off for about 6hrs it will refreeze
It sounds to me like the defrost isn't working somewhere.It freezes for 2 weeks until the evaporator coil freezes over and you lose your airflow, hence, your cooling. Then when you shut the unit off for 6 hours it thaws out enough to get you cooling again for 2 weeks.Check your defrost timer and see if it is going into defrost and if your defrost elements are good. Both will be located on top of the unit. Good luck!
Nov 12, 2009 | True 23 cu. ft. / 651 liter Commercial...
I have a True Freezer Model T-49. It works fine but every 3 or 4
This sounds like a stuck relay to me. I have seen this problem before. The defrost clock kills power to the compressor relay coil during defrost. If the contacts in the relay are welded together the compressor runs while unit is trying to defrost. On newer units this relay is mounted in base of unit on the side or back of the electrical box near center bottom of unit. The compressor relay is a small rectangular box with 4 wires attached. It can be replaced with a single pole 20 amp contactor with a 120 volt coil/ or 240 volt. Check the units name plate voltage rating and ratings on old relay! ;)
Mar 14, 2009 | True 49 cu. ft. / 1388 liter Commercial...
True commercial freezer
The ice could be preventing the freezer from freezing properly, try defrosting the unit. if this does not help then this could indicate a more serious problem like a bad temp sensor or refrigerant leak.
Apr 27, 2007 | True 52 cu. ft. / 1472 liter Commercial...
Freezers Logo
254 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
