Question about Audiovox FR530 (14 Channels) 2-Way Radio
Audiovox FR530 cannot receive or transmit from either of the two radios i have. transmission indicator displays when ptt button is pressed. all other functions seem to work ok. any ideas anyone??
  • twistedsi Aug 19, 2008
    both radios on same channel, but what is sub-audible tone? cant find anything about that in manual. although i have been through all menu systems and set each radio to the same settings. thanks again
  • Patrick Patterson
    Patrick Patterson May 11, 2010
    Have you looked at the user manual to make sure that each radio is on the same channel and sub-audible tone? Once this is done then the radios will work properly.
    New Friend:
  • 109 Answers
Follow instructions on page 13 of your manual "using monitor button" place receiving radio in monitor and key up other radio. It is better if you have someone help. have another person take the radio to another room away from you to complete test. sometimes if the radios are two close too each other they will cancel each other out.
Posted on Aug 19, 2008
Will not Transmit.Display Indicates "release mic button" and radio buzzes
The PTT button is probably stuck and your radio is already transmitting.
PTT = Push To Talk
Sep 09, 2014 | Boating
When i push the ptt button on my audiovox radio it shutsthe radio off
Commonly this can be a sign of a low or bad battery. It takes more power to transmit than to receive, so when you press the PTT button on a radio with a poorly charged or bad battery it will often fail. The same radio will run in standby mode (receive only) for long periods of time.
So before looking for a more complex problem, you might try swapping your battery with another radio's known good battery to see if it solves the problem.
Best regards.
Apr 22, 2014 | Radio Communications
Tk 2200 ptt button not working. when the button is pushed, the light come on momentarily then goes off
Hi Benjamin,
Kenwood TK-2200. The light comes on when you press PTT button, indicates you are transmitting.
The light goes out when you release the PTT button, if itgoes out during transmission, but your message gets through to your contact, then I don't see the problem.
If the light goes out during a transmission and you are still able to communicate, Don't worry, be happy, it's just a minor glitch with the light, no the radio.
As you haven't given me the details that I have guessed for you, I hope I have been helpful.
Nov 01, 2011 | Kenwood TK2100-TK2200-TK3100-TK3200-TK3101...
My walkie talkies arent communicating when i press the ppt button. it transmits too fast before i get a chance to talk into it. what can i do to fix them? is there a reset button? they are the motorola...
The ACTUAL problem is your rechargeable batteries have most likely depleted over time, and since it takes more batterie power to transmit than to receive it can appear that your batteries are fully charged and you can be receiving but due to the batterie it will be unable to transmit
Jul 26, 2011 | Radio Communications
In order to get the most out of your new radio, read this reference guide completely before attempting to operate the radio.
Turning the Radio On and Adjusting the Volume
1) Press and hold the key to turn the radio ON.
2) To change the volume level press the volume/monitor up or down key to increase or decrease the volume level.
3) Press and hold the key to turn the radio OFF.
Adjusting the Sound (Key Beeps)
Your radio emits a beep each time one of the keys (except for the PTT button and call key) is pressed.
The sound of the Key Beep will increase or decrease depending on the volume level setting.
To turn OFF this beep:
Press and hold the call key while turning ON the radio.
To turn ON this beep:
Turn the radio OFF and ON again.
Choosing a Channel
Your GMR325-2 radio has 22 channels you can use to talk to others. In order to speak to someone,
each of you must be set to the same channel.
To choose a channel:
Press the channel/scan up or down key to increase or decrease the channel number displayed.
Channel Scan Feature
Your GMR325-2 radio has a channel Scan feature that allows you to easily Scan all 22 channels. When an active channel is detected, the unit will pause on that channel until the channel is clear. Then after a 2 second delay, the unit will continue scanning.
Pressing PTT button while the Scan is paused on a channel will allow you to transmit on that channel.
To turn ON channel scanning:
Press and hold either the channel/scan up or down key. The channel number on the display
will rapidly cycle through the channels.
To turn OFF channel scanning:
Press either the channel/scan up or down key.
Talking on Your Radio
To talk to others using the radio:
1) Press and hold the PTT button and speak in a clear, normal voice about 2-3 inches away from the microphone.
While you are transmitting the tx icon is displayed. To avoid cutting off the first part of your transmission, pause slightly after pressing the PTT button before you start talking.
2) When you are finished speaking, release the PTT button.You can now receive incoming calls. While receiving, the rx icon is displayed.
Transmitting a Call Alert Tone
Your GMR325-2 radio is equipped with a call tone that will be transmitted when the call key is pressed.
To transmit the call alert tone, press the call key.
The tone will automatically be transmitted for a fixed length of time.
Auto Squelch Feature
The GMR325-2 is equipped with an automatic squelch system which shuts off weak transmissions
and unwanted noise due to terrain conditions or if you have reached your range limit.
Monitor Mode Feature
Your GMR325-2 radio allows you to listen for weak signals on the current channel at the press of a key.
To turn ON monitor mode:
Press and hold the volume/monitor up or down key. The rx icon will blink.
To turn OFF monitor mode:
Press the volume/monitor up or down key. The rx icon will stop blinking.
Automatic Power Save Feature
Your GMR325-2 has a unique circuit designed to dramatically extend the life of the batteries. If there is neither transmission nor an incoming call within 2 seconds, your radio switches to the Power Save mode. The radio is still able to receive transmissions in this mode.
Press and hold the call key until the "L" appears. After 1 second, the LCD will return to the channel display.
To exit Keylock on mode, press and hold call again.
Note: While in keylock on mode, it will still receive transmissions.
Roger Beep is a BEEP that is sent to notify the end of transmission.
Roger Beep can be heard through the speaker when Key Beep is on.
Roger Beep is transmitted even if key beep is turned off. However Roger Beep will not be heard from the speaker.
To turn OFF Roger Beep: Press and hold the channel/scan up Key while turning on the radio.
Jun 21, 2011 | Motorola Walkie Talkies 2-Way Radio
We have a set of 6 XTR446 about 2.5 years old. 3 of the handsets are (for no apparent reason) displaying the little handset icon permanently and not operating (either to receive or transmit). One of the...
In order to reset the radio, power on while pressing both volume buttons (+ and -) together with the PTT (speak) button, until you year a high-pitched tone.
But I have found that the "stuck on receive" problem is related to the battery voltage: non-rechargable AAA or incorrectly charged batteries can give 0.2-1.0V above the nominal voltage. Try to leave the radio on for a few hours or replace some of the four AAA batteries with slightly exhausted ones and see if that helps.
Jan 11, 2011 | Motorola Walkie Talkie 2-Way Radio
Radio stuck in RX mode.
Your PTT button is possibly at fault. It may be partially depressed, leaving your receiver open. Behind your PTT button there is an internal PTT button on the componet board. It may be stuck or defective.
Feb 28, 2010 | Radio Communications
Cx80 stuck in rx mode , power cycled, swapped batteries, changed channels, will only swtich to tx when ptt button pressed, otherwise always in rx mode, other radio from package works fine
But thats how a walkie talkie works, it stays in Receive Rx mode UNTIL you press the PTT button,, then it Transmits Tx, and when released it goes back to Rx, receive?
Feb 18, 2010 | Radio Communications
How far does the audiovox fr530 transmit?
The Maximum range is two miles and I stress that this is only under direct line of sight communications. walls and hills will reduce your communication range.
Aug 12, 2008 | Audiovox FR530 (14 Channels) 2-Way Radio
Audiovox FR530 (14 Channels) 2-Way Radio Logo
200 people viewed this question
Top Audiovox Radio Communications Experts
john milligan
Computer Repairing
Computer Repairing
Are you an Audiovox Radio Communication Expert? Answer questions, earn points and help others
