Samsung Silver Care washing machine
The washing machine keeps on filling up with water, even when the power is off. It filled so much while I was at work that it broke open and flooded my washing room.
Help please.
Marise
  • 706 Answers
Sounds like your inlet valve is stuck Open ( meaning it wont shut off incoming water ) That may be defective or the control to it may be at fault.. Try unplugging the washer ..and see if the water still continues to fill up the drum? If that happens, then your valve is probably in need of replacement.. Typically, when de-energized..they close and stop water from entering the system.. Hope that helps
Posted on Aug 19, 2008
Hot water keeps filling tub and does not quit
the washing machine is designed with a timer limit switch have the switch checked.
Oct 19, 2012 | Samsung WF448AAW 4.5 cu. ft. Front Load...
Machine not filling up with water
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Mar 19, 2011 | Samsung WF218AN Front Load Washer
Washer does not fill with hot water
heatman101
Feb 03, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Not filling with water. everything else works. it will agitate without the water in the tub. it thinks there is water in it
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Aug 30, 2010 | Maytag Dependable Care LAT9706
Help! My fisher paykel washing machine won't stop filling up!
If the water continues to fill even if unplugged the water valve is sticking and needs replaced. if removing power turns the water off the water level pressure switch is bad or there is something plugging the sensor tube somewhere.
Eric
Nov 22, 2009 | Washing Machines
Samsung silver care stopped spinning
could be (most likely)
motor brushes
belt off
motor wires disconnected
motor u/s
motor control pcb faulty/
Mar 16, 2009 | Samsung WF337AA Front Load Washer
Whirlpool Ultimate Care II keeps taking water.
ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
194 people viewed this question
Top Washing Machines Experts
