Outside air conditioner unit won't stay on - Heating & Cooling
    Problem Solver:
  • 7 Answers
Thermostat may be getting cold air from behind through wall and maybe low pressure or head pressure switch is cutting unit off
Posted on Aug 19, 2008
SOURCE:
What will stop the fan to stop spinning on a goodman ac unit on the outside
If you are wanting to just get it to cut off because it won't do it on it's own, you can turn the a/c breaker off at the breaker box. I have seen alot of blower fan switches go out on older goodman units and the blower stays running all of the time. Get a technician to check it for you. Good luck .
Jun 18, 2011 | Heating & Cooling
Outside unit won't come on. Drain pas appears dry/.
if nothing comes on (on the outside unit) when you turn on AC (and the inside unit runs ok) I would check the fuses and/or the breaker for the outside unit. I would suspect a fuse blown or a breaker tripped. It's also possible that your 'low voltage' (24V) thermostat wire has been cut (by lawn mower) or chewed into (by dog). If the problem is the low voltage wire you can easily splice it back together - just be sure all power is off.
Jun 06, 2011 | Goodman CKL36AR36 Air Conditioner
The central air turns on, but does not cool. The fan outside of the house is not moving. Is there a switch I need to use to turn the outside fan on?
There should be an electrical box next to your exterior unit. Open it up and there should be a pull handle on an electrical bridge. Usually when it is turned one way it will make an electrical connection and if it is rotated 180 degrees and plugged in it won't make an electrical connection.
Jun 04, 2011 | Heating & Cooling
The unit won't cut off even after reaching the set tempature in the room. When I change the setting up or down the number 6 blinks several times before the temperature is displayed. It's like...
if the number 6 blinks 4 times it indicates abnormal operation of the outdoor unit.
the way this system gets feedback from the outside unit is via the thermistor i would start there.
here is a manual it might help you troubleshooting what the problem is with the outside unit.
Best of Luck
Jun 01, 2011 | AmcorAire UCHW-H12AF2 Split System Air...
What is purpose of pull lever on top right of decorative panel
It's an air intake vent damper. If you push it in, the unit won't pull any air from outside, instead it'll recirculate air from the room. If you pull it outward, it allows the unit to pull air from outside. During the day when it's hot outside, the lever should be pushed into the closed position to allow for more efficient cooling. At night, if you want to exchange air from outside when it's cool enough, pull out the lever to allow that to happen. The unit will exhaust hot air no matter if this switch is in or out.
Jul 05, 2010 | Maytag M7Q08F2ACOM Air Conditioner
On my window unit the compresser only runs for 15 sec. and shuts off for 4 min. the fan stays running.. its not cooling the room
possably a problem with the outside condensor fan motor. Pls check
1.) when unit is running is the outside fan motor also runnng. My guess is the outside fan is locked bad motor ect. Unit would only run maybe 30 seconds before cycling on its overload
May 04, 2010 | Whirlpool ACE244XS Air Conditioner
My outside unit is not actually working. It is
Hey, there. So, you have a hum outside, is your fan motor running outside? Does the compressor run and stay on, it is louder than the fan motor. The two pipes coming from the unit, the small one should be warm, the big one should be cold. Let me know what you got
Jun 20, 2009 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
