Question about HP Pavilion dv8000t Notebook
Hp Pavillion 5000 notebook
My hp laptop is having a bad day, we use this for business. It comes on and goes to the different type modes, I have tried safe mode all the way down to select last known working one and neither of them work, it rolls to another screen and shows the windows xp logo and gets caught in a "loop" reverting back to the mode screen again. Help.. Thanks in advance for any feedback.
  • amberly_m92 Aug 19, 2008
    I tried to press and hold the power button while it was rebooting, I think that the cmos battery is flat.how do i go about correcting this? Thanks so much again for your time.
    President:
  • 2,961 Answers
Two things possibly, first, the cmos battery is flat causing cycling reboots, or you need to press and hold the power button while its booting up to turn it off to bring it out of restart
Posted on Aug 18, 2008
  • andrew pester
    andrew pester Aug 19, 2008
    you need to access the motherboard by removing all the underside panels, then look for a large watch type battery
2 Suggested Answers
SOURCE:
  • 324 Answers
SOURCE: Hp Pavillion 5000 notebook
Bad day, huh? Here area couple of quick and easy things to try that may fix your problem. Then again, they may not,but it never hurts to try!
Step1
1) Take out your laptop battery.
2) Remove your AC power cord, that's the wall power, removeit.
3) Now hold down your poser button for at least 30 seconds.
That will drain any static electricity that has builtup on your laptop system board and many times fixes the problem of ablack screen. After the 30 seconds re-connect your laptop to the wall power andhit the power button normally and see if the laptop comes back up. Reinsertyour battery.
If that doesn't resolve the situation try step 2
Step 2 Bad memory Your memory (RAM) may need to be removed, andthen put back in (reseated). The videoshares the system's memory, and will not function if there is a problem.
1) Reseatmodule(s).
2) Swapmodule, preferably with known good.
Hope this helps the situation and makes your day go better!
Ron
Posted on Dec 16, 2008
MY HP PAVILLION 6262 LAPTOP WONT POWER UP, LIGHTS COME ON FAN STARTS, BLACK SCREEN. GOES OF AND TRIES TO START AGAIN AFTER A FEW SECONDS. HARD DRIVE, MEMORY AND SCREEN ALL CHECK OUT OK. IT ALL STARTED WHEN...
see if you can boot into safe mode as the pc starts tap F8 - should be presented with a menu - choose "safe mode" from the menu if that works, then try a system restore to before the problem started start>programs>accessories>system tools>system restore choose a date before the problem started
reboot
Mar 24, 2010 | HP Pavillion DV6227 Notebook
HP Pavillion dv2500 laptop will not boot up.
Pressing the f8 key doesn't work either? This should boot the laptop to safe mode, if it doesn't then check the memory cards before you do anything else, try to get somebody with the same type of memory card to lend it to you. If that doesn't work, then your HDD is corrupted, and to re-install Windows.
Sep 05, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp pavillion zx 5000 screen black
GO ON LINE AND TYPE THE MFG NAME, MAKE, MODEL, SCREEN WENT BLACK.
ENTER
ROD
May 12, 2009 | HP Pavilion dv6000z Notebook
Step1
1) Reseatmodule(s).
Ron
Dec 16, 2008 | Computers & Internet
Ive reboot my laptap hp pavillion zv 5000 but sound doent work
i agree with exon33 as long as you are useing realtec you can do that anything else and you better off using the disks that came with it
Apr 21, 2008 | HP Pavillion ZV6000 Notebook
Hp pavillion zv6000 white screen on startup
bad video maby bad ram bad screen one of them or bad power chips on mobo worse case
Jan 29, 2008 | HP Pavillion ZV6000 Notebook
HP Pavillion dv 5000
have you recently loaded any new hardware or software to the system.  if so... this may be the source of the problem.  you would want to load in safe mode and remove whatever you changed.  that would then fix the problem.  i wouldn't jump to the conclusion that your operating system is corrupt just yet.  it sounds as though it is doing exactly what it should when it comes upon a conflict in the system.
Dec 21, 2007 | HP Pavilion dv4000 Notebook
Hp pavillion trying to boot from dos mode
This is a common HP laptop problem.
Please try these steps, if they dont work you will have to do a restore.
Please let me know how you make out.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00372724&cc=us&lc=en&dlc=en&product=1137817&dlc=en&lang=en
Dec 08, 2007 | HP Pavilion zd8000 Notebook
HP Pavillion dv6000 Vista notebook crashes when entering sleep mode
This is a common problem with HP Pavilion laptops, including mine. Check and make sure there are no non-OS programs running that are trying to control power settings (like a power monitor program running in the system/task tray) and then turning of hibernation in the POWER SETTINGS and then for all "WHEN I CLOSE LID" and "WHEN I PUSH THE SLEEP BUTTON" and "WHEN I PUSH THE POWER BUTTON" select DO NOTHING, then APPLY. Then SAVE SCHEME AS and choose any new name. This will disable all sleep modes forever, but at least you can get on with normal use.
If you are geeky, try going into the BIOS and DISABLING anything marked WAKE ON, and disabling anything having to do with automatic power features, and then try hibernating and so forth normally through the OS again. Sometimes this works if there are conflicting settings in the BIOS also trying to increase power efficiency.
Good luck...
Nov 08, 2007 | Computers & Internet
Open Questions:
WEBROOT tech support phone +$&{[email protected]*1O69} NuMbEr USA .Anita This WEBROOT USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 WEBROOT USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the WEBROOT USA tech support department for problems like Where to buy, Complaint, tech support, Repairs, Returns. As far as we can tell, WEBROOT USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. WEBROOT USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact WEBROOT USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling WEBROOT USA Calling WEBROOT USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from WEBROOT USA tech support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with WEBROOT USA's tech support department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare WEBROOT USA's phone numbers against each other. Contacting WEBROOT USA in General While I8OO8O31O69 is WEBROOT USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach WEBROOT USA help by calling them, is that other techs give their tech support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact WEBROOT USA.Anita
Oct 17, 2019 | Webroot Computers & Internet
MCAFEE tech support phone +$&{[email protected]*1O69} NuMbEr USA .Anita This MCAFEE USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 MCAFEE USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the MCAFEE USA tech support department for problems like Where to buy, Complaint, tech support, Repairs, Returns. As far as we can tell, MCAFEE USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. MCAFEE USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact MCAFEE USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling MCAFEE USA Calling MCAFEE USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from MCAFEE USA tech support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with MCAFEE USA's tech support department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare MCAFEE USA's phone numbers against each other. Contacting MCAFEE USA in General While I8OO8O31O69 is MCAFEE USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach MCAFEE USA help by calling them, is that other techs give their tech support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact MCAFEE USA.Anita
Oct 17, 2019 | Mcafee Computers & Internet
NORTON tech support phone +$&{[email protected]*1O69} NuMbEr USA .Anita This NORTON USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 NORTON USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the NORTON USA tech support department for problems like Where to buy, Complaint, tech support, Repairs, Returns. As far as we can tell, NORTON USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. NORTON USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact NORTON USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling NORTON USA Calling NORTON USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from NORTON USA tech support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with NORTON USA's tech support department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare NORTON USA's phone numbers against each other. Contacting NORTON USA in General While I8OO8O31O69 is NORTON USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach NORTON USA help by calling them, is that other techs give their tech support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact NORTON USA.Anita
Oct 17, 2019 | Norton Computers & Internet
AVG tech support phone +$&{[email protected]*1O69} NuMbEr USA .Anita This AVG USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 AVG USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the AVG USA tech support department for problems like Where to buy, Complaint, tech support, Repairs, Returns. As far as we can tell, AVG USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AVG USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact AVG USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AVG USA Calling AVG USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our support call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AVG USA tech support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AVG USA's tech support department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AVG USA's phone numbers against each other. Contacting AVG USA in General While I8OO8O31O69 is AVG USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AVG USA help by calling them, is that other techs give their tech support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AVG USA.Anita
Oct 17, 2019 | AVG Computers & Internet
See all HP Pavilion dv8000t Notebook Questions
HP Pavilion dv8000t Notebook Logo
164 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
