I have a 20" rca truflat tv with the fpl on and can't get the tv to turn on
  • 44 Answers
Too general. Does in make any noises (like a click or high pitch squeal)? When you say "fpl on" is that a fromt panel light? Does it change color or flash?
Many "shutdown" or "dead" problems can be solved by unplugging the unit for an hour and plugging it back in causing a reset to the system.
Posted on Aug 18, 2008
Turn off fpa lock without remote
Install an IR Remote App in android phone. The app link below worked for me to remove the fpa lock on. Configure the App for your RCA TV. Set TV as Device type, RCA as the brand. and choose the model (e.g., TV 20 F420T) also, select the Alternate IR Driver.
All the options of the command may appear in a list form. Close that and an actual remote with buttons should appear.
Then Power your tv will turn ON. Press the Menu. Pressing the Channel Down/Up Button to navigate to Preferences. Press OK button on the screen.. Then Navigate to FPA Lock. Press OK again. THis will turn the FPA Lock to Off.
Then you could use your on-TV buttons ZappIR Universal IR Remote Android Apps on Google Play
Nov 23, 2011 | RCA TruFlat 27F520T 27" TV
I have an 20" RCA TruFlat Digital SDTV that is
The problem sounds like a problem with a power supply or a power chip. These can be a cheap fix if you can find a cheap TV repair man, but expect to pay hundreds at a TV repair shop.
Mar 03, 2011 | RCA Televison & Video
I have a RCA Truflat tv model 20F420T and serial number H494E2526 and accidentally hit a button on my digital cable box remote which sent the tv into a mode showing FRNT. In trying to solve the issue, the...
Using the remote control hand unit that came with the TV turn on TV. Then go to the set up menu. Locate the entry for Front Panel Lock (FPL) and select no. Once you have done that exit the set up menu then on the same remote push the "input" button while watching the screen. Push button once wait a few seconds for a picture to appear, if not then push the button again, continue until you have selected the input that provides a picture. Right now you are in the Front inputs you should look for Video 1 or 2.
Feb 18, 2011 | RCA 20F420T 20" TV
Rca 32in TV Product serial#f483ceok5 RCA 32in
try unplugging the tv from all imputs and power and let set over night then plug everything back in.
Feb 10, 2011 | RCA TruFlat 27F520T 27" TV
Hi my rca truflat 20 inch tv stays on for about 30 mins then displays an analog clock and turns off
Your sleep timer is on. Hit menu, and poke through that and find the sleep timer settings. Sleep timer is something that turns the TV off after an amount of time that your do not interact with it.
Sep 17, 2010 | RCA Televison & Video
I have an RCA Truflat that began turning itself off today. Sometimes it will last 20 minutes, sometimes a few seconds. I'm way can I get it repaired..any ideas as to what's going on?
possible cold solder joint(loose connection). try the old method of picking it up and slightly moving it. hit it. if it seems to affect operation, just simple soldering on power supply and deflection will fix it. 50/50 chance
Nov 14, 2009 | RCA TruFlat 27F520T 27" TV
20" TruFlat cuts on and off on it's on
This is power supply issue! a defective parts need to replace. like power oscillation. here in the philippines the cost is about 750.00 php.
Dec 29, 2008 | RCA 20F420T 20" TV
RCA TruFlat 27F520T 27" TV Reset
Buy a new remote.
Look around the tv and find the menu button.
Generally there is a separate power button.
You can also download the manual:
Dec 02, 2017 | RCA TruFlat 27F520T 27" TV
i would honestly suggest if you still have the receipt return it back. dont forget your rating thanks.
This is a very common problem for RCA TV. I have one as well. or go to there are free manual there
Jan 25, 2008 | RCA TruFlat 27F520T 27" TV
Turns off by itself
Ours did that too after 2 years of faithful service. We got a quote for repairs equaling around $200 USD when the tv only cost a little over $100. You can price-check to see how much repairs are for places, however, it was just best for us based on retail price paid to get a new one. ... and sometime we shall get one!
Oct 04, 2007 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
