2006 Hyundai Tucson Logo
Posted on Jun 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
About to purchase 2006 Tucson 4 wheel drive with 105,000km, leather seats,loaded. 4wheel drive can be switched off. asking price $12,500, would u recommend buying this vehicle? I have never owned a Hyundai of any kind before. Does this yr & make have issues? Thanks, Linda
PAUL MC G
Level 3:
President:
  • Master 1,280 Answers
  • Posted on Jun 11, 2011
PAUL MC G
Master
Level 3:
President:
Answers
1280
Questions
Helped
702216
Points
2440
This particular vehicle is one of Hyundai's Top Sellers. I'm a Service Technician and can tell you I haven't seen any 'MAJOR' problems with the Tuscon -- just minor stuff.
I have a 2006 f350. Ford will not go into 4wheel
Which 4X4 system does yours have ?
Four-Wheel Drive Systems The mechanical-shift 4-wheel drive system consists of the following components:
  • Transfer case (For transfer case repair procedures, refer to Section 308-07B ).
  • Transfer case shift lever
  • Manual locking hubs
  • 4x4 indicators
  • Shift linkage (hub locks)
The electronic-shift, 4-wheel drive system consists of the following components:
  • Four-wheel drive (4WD) control module (For 4WD control module installation, refer to 4WD control module in this section.)
  • Mode select switch (MSS)
  • Gearmotor encoder assembly
  • Automatic locking hubs (hub locks)
  • Pulse vacuum hub lock (PVH) solenoid and vacuum lines
How to shift into 4 wheel drive
make model year, locking hubs, 2 wheel to 4 wheel drive,
is on demand, full time 4 wheel drive.
owners manual mite help, service manual, going on line,
www.youtube.com
www.howto.com
www.info.com
www.wiki.org
www.wikipedia.org
www.about.com
www.hwinfo.com
www.ask.com
www.askives.com
go to browser and ask the following ways:
year make model how to use 4 wheel drive
year make model operational manual 4 wheel drive
year make model owners or operational manual
year make model service manual
you could go to a dealer of the makers showroom go to service and ask for help, off road shop, 4wheel club, look up local 4 wheel shops or off road accessory shops, big tire shop may help. jeep shop
local library, on line, dealers cars, off road, 4wheel parts and accessory shop, shocks store, auto parts store, your local or friend that works on your family car or truck. jeep and off road specailty
shop
i hope this was helpful and good luck
thank you rod
1helpful
4wd do not tuen on, Hyundai Tucson 2006, V6, G6BA, 4wd
Check the relay first then the fuse. If they are not bad then it might be that the switch is burned out after that it will be in the shift modulator for the 4 wheel drive. If it is the modulator then you will need a new one.
4 wheel drive
Could be the switch/valve in the front differential.
1helpful
Does a 2006 Toyota 4Runner Sport need a 2 or 4 Wheel Alignment
There is nothing to adjust on the rear because it is a solid axle, most dealers and alignment shops do a 4wheel alignment anyway and they don't charge less for a two wheel alignment. A 4wheel alignment also reveals any possible bent suspension components or frame misalignment..
1helpful
No light on 4wheel dr control
There are a few things that would cause this problem.
The first and most common would be the switch itself is bad. the next would be a bad 4wheel drive encoder motor, this is the motor on the transfer case that is used to operate the 4wheel drive. The last would be the 4 wheel drive module.
You will need to do some testing, if the four wheel drive is working and goes in and out of 4 wheel drive then i would say it the switch. if it does not work correctly it may still be the switch or one of the components i listed above.I have enclosed a wiring diagram, you will need to do some testing to check system, first make sure all fuses are good. the fuses that operate the 4wd are listed on diagram, it will also tell you the location of each part. you will need to test front axle actuator and selector motor and switch, you will need a test light and a meter. hope this is helpful, good day.4_26_2012_10_13_14_pm.gif
2answers
I have a 2006 tuscan with 27000 miles on clock.changed front tyres recently but they keep going down.went back to tyre shop & was told due to alloy paint coming off wheel, it is not allowing new tyre...
Doesn't sound right, unless wheel is damaged bent/cracked. A cheap fix would be "fix a flat" (sealer in a can) in each tire just as a safety precaution. Also check your tire valves sometimes tire shops don't get the valve cores tight.
4wheel drive light is blinking
there is NO '4wheel drive emergency' light on a 2006 Tucson.
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
