Question about Kitchen Ranges
My gas oven won't heat ,it ignites,but does not light. The igniter glows but the gas does not turn on. I have a caloric Model RSS359-UL-OF Serial number F9599925621
  • umil4 Aug 19, 2008
    My husband will try the solution, and I will let you know how it works out, Thank you very much! Milli
  • 25 Answers
It is a bad thermocoupler.
Posted on Aug 19, 2008
Oven,broiler won't light
The igniter is the most commonly defective part for a gas oven that won't turn on. The igniter has two main functions. First, the igniter draws electrical current through the oven safety valve to open it. Second, the igniter gets hot enough to glow and ignite the gas in the burner assembly. If the igniter gets weak, it will fail to open the safety valve correctly. If the valve does not open, the oven will not heat. To determine if the igniter is defective, observe the igniter when the oven is on. If the igniter glows for more than 90 seconds without igniting the gas flame, this indicates that the igniter is too weak to open the valve. If the igniter is weak, replace it. If the igniter does not glow at all, use a multimeter to test the igniter for continuity. If the igniter does not have continuity, replace it.
Kenmore Oven Won Turn on
Jan 20, 2016 | Kenmore Kitchen Ranges
Oven and broiler won't work surface burners ok
Troubleshooting Why Your Gas Oven Won Ignite or Heat PartSelect com
Gs773lxss0 will not light
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start
Oct 21, 2013 | Whirlpool Ovens
Roper gas range. Oven glow coil comes on but has no gas to heat?
if the glow igniter is on and it doesnt light its probably the gas valve
Feb 12, 2012 | Roper FGP300 Gas Kitchen Range
Oven takes too long to heat up sometimes wont even go to the temperature ignitor is working well can see the glow magic chef model 3488vvv serial 13368882kz
Hello there:
When you turn the oven on, open the oven door and look down at the bottom and see if its glowing red, it should glow red for about 45-60 seconds then you should hear the gas ignite. If the gas doesn't ignite, then your igniter glow bar is bad.
Here's the oven glow bar igniter for your model:
Manufacturer's Number: 74007498
show?id=yo6223wzsty&bids=142421.661381148&type=10&subid=
partimage.aspx?imgid=z3bqljbfbxnfodk0nzawndcvq0fnl3nvdg9ochryyxav
show?id=yo6223wzsty&bids=142421.661381148&type=10&subid=74007498
Sep 28, 2010 | Ovens
My gas stove model # 790.77471792 does not heat up past 100 deg. The broiler and the the top burners light. can someone tell me what the problem could be? i did notice that when I turned on the pre heat I...
The orange glow you see is coming from the oven igniter. The igniter needs to glow white hot in order to light. You need to replace the oven igniter. Hope this helps.
Nov 19, 2009 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Oven doesn't heat up
Hi, Even though your igniter is glowing it's bad..A igniter should glow brillient yellow for it to be able to light the gas...basically whats happening in your case is although the igniter is drawing the correct amps to open the gas valve it is not getting hot enough quick enough to light it..change the igniter and you should be good to go. Good Luck!!! Mike
Aug 17, 2009 | Ovens
THE OVEN WILL NOT HEAT
How old is the unit? Sometimes the igniter can glow but if it isn't drawing the right amount of power to open the gas valve then that is the safety that is built into the oven... So unless the power requirement is meant gas valve will not light. Even though the hot surface igniter is glowing red hot. chances are the igniter is bad. Let me know what turns up. ken
Dec 03, 2008 | Magic Chef 9112 Gas Double Oven
Caloric oven does not completely light
i would replace the ignitor, although its glowing its not glowing strong enough to allow gas to release, simple repair, part numbr 31939701
Nov 22, 2008 | Kitchen Ranges
Kitchen Ranges Logo
193 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
