Missing connector Hi, I'm rebuilding an old Sony Trinitron KV-21LT1U. On the motherboard, immediately behind the tuner, there should be a soldered (three-pronged) plug that a black wire connects to (Sorry the description is so poor - I'm a relative beginner.) The plug is missing. Do you know where I can get one? Many Thanks, Bert at bert228@fsmail.net
  • 44 Answers
Boards are built with some or many spots left open because the same board is used on different models with different features.
That may be one of those and is unused for your model. The part on the board is the socket and the plug is on the wire bundle or ribbon cable. If you actually have something that should go there, you can skip the plug and socket and solder the wires direct (watch for polarity).
Posted on Aug 18, 2008
My 12 year old Sony Trinitron KV-32XBR200 still works pretty well except that it cuts off about 25 - 30 scan lines at the bottom of the screen when cold, then gradually improves somewhat to missing only 15...
No,tv have cold solders inside the tv like vertical IC or around the area.Have a soldering iron,a roll of solders,also know how to do basic soldering?Yes.Take the tv aparts,take a back plastic of the screw driver tabs all around the main pcb,will see the vertical changes,take out the a/c power sourced,resolders those area,will fix this problems.
Feb 10, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony Trinitron 32 color tv KV 2168MTJ (quite old - 10 yrs old), and the standby light blinks exactly 200 times (just over 3 mins) before it turns on. Once it is on, it works perfectly. What's...
A poor solder connection on B+ is the line, Horizontal drive transformer or at the base of Horizontal Output transistor can caused that. Re-soldering these section can fix it..
Oct 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sometimes the color stays, sometimes the picture is in black and white?Sony WEGA Trinitron with TimeWarner cable box.
that problem is very common in a sony TV the main cause of that problem is the video IF.you can replace it with a new I.F. just adjust the I.F. to do it open the back cover of your tv.you can see the tuner soldered on the pc board.using a soldering iron and a desoldering pump take out the tuner from the board..remove the stainless covering of the tuner and soldered it again to the board there are two IF(intermediate Frequency) on the tuner the sound I.F and the Video IF.After soldering the tuner to the board power on the tv and use a plastic jewelry screw or an alignment tools then turn clockwise/counter clockwise gradually and slowly untill you reach a good signal...be carefull when adjusting not to touch with your hand the high voltage section...good luck hope I helped you Please vote for my help.
Jul 27, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Hi...I have a problem with my Sony Trinitron 29
the power supply section should be resoldered....must be loose contact..in power section...
Jan 26, 2010 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Hi, I have an old sony trinitron ku27ts27 and out of the blue yesterday it went to snow on me it's not the cable system, how can I get to somesort of setup menu when there isn't a setup button? Thanks...
Try knocking on the cable connector whith the cable pugged in and the set on and also put the tv on a channel between 2 and 13, if the picture comes back then you have bad solder joint in or around tuner ***`y. you may also want to check you cable connectors. the tv setup won`t help you here. good luck
Oct 31, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Is my tv digital?
It is not a matter if your TV is compatible with a digital signal, it is the signal being offered to the TV.
Meaning, if you are using Cable TV, you are fine and need no further action because the digital signals are already converted by the Cable Box into either an analog TV (RF) signal, or a PBR (RGB or Comp.Video) signal which the TV understands via a separate input (external video input).
Feb 14, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Is this TV a digital tuner? or will I need a converter box
Hi, If you have an outside antenna you will need a converter box as this tv has an NTSC tuner which is analog.
Feb 02, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Hi, Sorry this tv has an NTSC tuner which is analog. But it will work if you have cable or satellite.
Feb 02, 2009 | Sanyo DS24424 24" TV
Sony tv kv-29F1U
tuner needs replaced or taken apart and cross your fingers soldering joints, use silver solder look hard with magifiers for solder cracks or bad joints and grounds inside tuner.
Jan 18, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Aug 29, 2006 | Sony KV-32S35 32" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
