Question about Coleman Mach III Air Conditioner
Problem with heat pump
We have a 2008 Phaeton, with a coleman heat pump, airconditioiner combo, with a coleman mach hp thermostat. When we turn on the heat pump the fan comes on for a few seconds, then the gas tries to ignite, then it turns off, then the blower turns off. Any ideas
  • renden Jan 19, 2009
    I have two Coleman AC units in my Seville 5th wheel. When I first turned them on, both units put out heat. Now they only blow cool air when set on the electric mode. I have checked connections, fuses, breakers and the units themselves. Any ideas. They are brand new.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
This sounds like a 4--step furnace. Step 1 ,the small ven fan turns on and proves it turnning thru the small air tube that sucks a switch close . Step 2 the spark igniter lights the pilot ...Step 3, the main gas valve opens up and dump gas in the venture tubes to heat the box up, Step 4 theres a swith in the box the when heated closes and turn the fan on! Thank-you-very-much!
Posted on Aug 28, 2008
Series 48000 with heat pump we don't want this to run all the time will the heat shut off when it reaches a certain temp also if the power goes out does it come back on automatic we want to heat our place...
Not sure about your particular make and model, but air conditioners are designed to work with a thermostat to control the functions. A properly functioning thermostat will stop the compressor when the set space temperature is satisfied. When the space temperature falls below (heating) the set temperature, the thermostat should turn it back on. In the event of power failure, an electronic thermostat probably will not operate at the previous set temperature when power is restored, but maybe at a higher temperature (but will work).
Dec 05, 2013 | Coleman Mach 15 Air Conditioner
Replacing a Coleman with a Duotherm, can the same thermostat and controls be used?
Hi, yes you can use the same thermostat if you are replacing the unit that has the same sequence of operation. What I mean is, if the old unit is a gas fired furnace and outdoor condenser split system for the a/c you can use the same controls, or if its a package unit. Now, if you are installing a heat-pump unit in place of a gas fired central unit, you will need to pull more stat wire and buy a heat-pump thermostat to make it run.
Shastalaker7
A/C, Heating Contractor
Oct 12, 2010 | Coleman Mach III Air Conditioner
Coleman roof top a/c, is the heat controlled by thermostat
hi
on the new colman units (trane) the heat is control only from the t-stat.
i will reccomand a programble t-stat for the new unit.
thanks
Nov 02, 2009 | Coleman Mach III Air Conditioner
COLEMAN MACH 3 MOUNTING ON INSIDE OF CAMPER NOT ALIGNING WITH MY
Did you purchase a new Ducted Ceiling Unit with the Upper Unit air conditioner? If you are replacing an older mach 3, the ducted ceiling packs are not compatible and you will need to purchase the ceiling pack as well. The ducted ceiling pack part number for the 8333 series Mach III AC is below.
1. Heat/Cool Air Distribution Box - 8330B735
2. Cool only ADB - 8330A733
3. Wall Thermostat (if needed) - 7330G3351
Hope this helps.
Jul 01, 2009 | Coleman Heating & Cooling
Coleman mach chill grill - heat turns on whether we have it programed or not. have heat off, ''I feel'' off, can be 80 outside we can be gone and come back to 110 degrees inside and heater on. When it...
Sounds like you have a bad thermostat or a short in the wiring. The clicking that you are hearing in the ceiling is a relay in the control board. When this happens, remove the face plate from the thermostat and check for 12VDC between the Blue and the White wires. If there is power then you have a bad thermostat. If there is not power there, then the problem is elsewhere. However, it sounds as if you have a bad thermostat.
Jun 03, 2009 | Coleman Mach 15 Air Conditioner
Coleman Mach III Air Conditioner Logo
221 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
