Question about Brother MFC-9420CN All-In-One Laser Printer
Check tray#1 reinstall tray
Check tray#1 ,reinstall tray
  • Anonymous Sep 09, 2008
    check paper size reload correct paper
I took the printer back to Costco!
Posted on Aug 19, 2008
Printer has red light, I used samsung's diagnosis software and it said that "tray 1 paper missing" even though I have paper on it?
Remove the paper tray from the printer and check for any media stuck in the paper path. Once any obstructions have been removed, reinstall the tray.
Dec 24, 2015 | Samsung CLP-315W Color Laser Printer...
Dell 5110cn printer Tray Detached error 024-946
Cycle power on the Printer.
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
If tray 1 is being used:
  1. Remove and reseat the tray.
    To remove and reseat the tray, perform the following steps:
    1. Pull the 250-sheet tray out of the printer until it stops.
    2. Hold the tray with both hands, lift the front slightly, and remove it from the printer (Figure 1).
      Figure 1: Removing the Tray
Re-insert the paper tray into the printer and push it until it stops (Figure 2).
Figure 2: Reinstalling the Tray
Run diagnostics on the tray 1 paper size switch on the Dell 5110cn printer
http://www.smoothprinterservice.com/
Dec 18, 2012 | Dell 5110cn Laser Printer
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
When i m on printer inittilizeing sound came but but any one light on and like hang dont work again,some times paper error light ,some time toner error light,
You can test the printer by three ways,
1. Press and hold Green button for atleast 5 seconds it will take out the configuration printer, also the toner status page will come too
2. If the toner light is on , check the current toner status from the test prints taken before,
3. if the Error light is on, make sure there is no paper jaming in the printer, remove any paper stucked on the tray side, as well as check by removing the toner also
One thing more you can check the configuration for the Printer tray selected in the system,
Remove the Printer Drivers from the computer and try installing the software again, sometimes if you have selected manual tray feeding, or you have selected Tray 1 as default Tray and there is no page in the Tray 1 it will also, gives you the error on printer, 2nd thing you can check is the Paper size, both in computer and on tray 2 in printer, you take out a tray from the printer and adjust the nob to A4 . if you are using this printer on network, you have to reinstall the drivers for the printer, and it should give you the print,
If you require more assistance, feel free to reply to this post,
Thanks for contacting FixYA!
Regards-BA
Feb 02, 2011 | HP LaserJet P2015dn Printer
Paper does not feed from Tray 1.
Check your printer settings.
Sometimes if your printer or the program you are printing from has the paper source set to "Letter" it waits for you to press the continue key on the printer which allows you to insert headed note paper before printing.
If it is set to letter, change it to A4 and this should solve your problem
You may need to change this in both the printer settings and/or each program from which you are printing
Jan 12, 2009 | Lexmark C532dn Laser Printer
Won't print to right tray
I had this problem and solved it like this:
  1. Right click on printer driver in printers and faxes.
  2. Select printing preferences
  3. Choose paper quality tab
  4. Set paper size (A4 in my case)
  5. Set paper source to printer-auto-select. This is different from the default "Automatically select"
As long as tray 1 is empty, tray 2 should now kick in. Setting the paper source as tray 2 didn't work at all.
You seem to have to set this on each client computer though - even if you are sharing the printer over a network (4200n).
Sep 23, 2008 | HP LaserJet 4200 Printer
Error Message "Check Tray #1 - Reinstall Tray"
this is a hardware problem with there crappy printer .. and the fact is that it cost more ot fix it then to buy a new one ... I believe they set it to a certain amount of time and freeze up so ppl can buy a new on or the part or it
Jul 27, 2008 | Brother MFC-9420CN All-In-One Laser...
HP 4600n tray 1 greyed out
Put the labels in another tray.
Jun 11, 2008 | HP LaserJet 4600dn Color Printer
Brother MFC-9420CN All-In-One Laser Printer Logo
313 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
