Question about Maytag Atlantis MDE7400AY Electric Dryer
Hard to turn dryer on
On drier large button to right side once i pull button out to turn dryer on i have to pull button out while at the same time moving it around trying to make connection. seems to have a shortage inside of button
  • econiglione Sep 23, 2008
    i have trouble turning the dryer on. i too have to try and make whatever connection needs to be made and wiggle the knob around
  • Anonymous Oct 14, 2008
    I had the same problem until I pulled the whole knob out, now I need to find the replacement knob.
  • 4 Answers
If the button makes clicking sounds while turning then it is attached to the timer replacing the timer is not that hard make a picture of all the wires what color they are and where they attach on timer be sure an unplug unit from wall before working on this usually there are about four to six screws that hold that cover that the large button is located when you get those out then pull the cover backwards that button is on an the timer will be exposed right behind button you can pull off one wire at a time an place it on the new timer by laying them side by side once again be sure that electric has been disconnected
Posted on Nov 01, 2008
My Bosch Nexxt 500 dryer is TOO HOT.
You need to take care of this right away. Too many houses catch fire from lack of maintenance on dryers. Pull it away from the wall and unplug it. Check the inside of the duct work and clean it out. Then check the inside of the drier connection too. Run it without the duct connected and see if you have good air flow.
Jun 16, 2013 | Bosch Nexxt 500 Dryer
My hotpoint aquarius tumble drier is making a very lound griding sound as it turns. What can it be and can it be repaired by myself? the drier is over 8years old is it time for a new one?
This is the plastic "wheel" on the motor that drags the drive belt to spin the dryer. you will need to push back into place with something thin. under the right hand side of the dryer there will be a grill under the motor. look for a black plastic "wheel" and move it away from the casing with something that can fit through the grill.
May 16, 2010 | Dryers
JUST RECIEVED A NEW COMPRESSOR FOR A REFRIGERATOR mod#MTB2176HR. Along with the compressor came a dryer. The packing list does not mention weather its a discharge or suction side dryer. Do you have any...
Look at the size of the drier holes. Just to mention driers always go on the discharge side, normally just after the radiator. Any driers normally found on the suction side are actually" burn out driers". Applicable to large cooling systems..
Sep 14, 2009 | Refrigerators
Amana electric dryer will heat but only when.../ LEA60AW
It seems there is some wire loose, check on the both side of heating element points.
The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter.
Good Luck!!
Thanks
Jun 22, 2009 | Amana Dryers
Drier button does not work when push it to start machine
You need to check the dryer door switch. I may be bad. If the timer is clicking it is probably working fine. Also you need to check that the dryer is getting power to the unit. Check your breakers and also pull the unit out and look at the dryer cord. Check the terminals for a short or burnt looking one. Once you have established you have power going to the unit, you can find where the comunication stops within it.
Apr 09, 2009 | Kenmore Dryers
Roper Drier no heat and continuous run for two hours
Your drier heating elements operates on 220 voltage, the drum and clock operate on 110, so you either have a blown fuse in one side of the fuse box ( easy fix )some time the circuit breaker will just need to be reset by turning it off and back on, or your heating elemant has opened up and will be more expences to fix, or it could just be a wire end has burned off. unplug plug from outlet remove back from drier and have a look see, and if bychance you have forgotten to clean your link trap if could be a high temp safety that has open and sometimes can be reset by pushing the reset button, all this is inside the back of the drier, if after that it may be time to call your friendly repair shop
Oct 20, 2008 | Roper REX4634KQ Electric Dryer
New dryer belt configeration
loop belt around drum gather belt at bottom feed left to right through bracket opening pull up and fit belt around motor shaft flat side of belt will be on bottom side of pulley doward pressure of pulley will put tension on belt
Jun 18, 2008 | Whirlpool LER5636P Electric Dryer
Dryer belt replacement
facing the drier get a small putty knife come about 1 inch from the edge of the drier and push in with the putty knife to release the plastic clip some times this can be difficult pull up on the top at the same time do that on either side till you get the top up then tilt the top back against the wall disconnect the door switch wires look in the drier to the front panel on either side you will see two 5/16 screws remove them tilt the front panel toward you and remove the panel put the belt around the drum slide it back to where you can see the old one has been running pull the idler wheel back hold tension on it and put the belt around the motor pulley let the idler pulley up till it engages the belt and reverse dissemble don't for get to plug the door switch back upimage3.gif
Jun 17, 2008 | Dryers
Dryer is sparking
first turn the breaker off like now pull it out from the wall about a foot facing the drier take a small putty knife and insert it about 3" from the edge push the knife in till you feel the spring clip push in on it and lift the top then repeat that on the other side fold the top back till it leans against the wall look in the drier on the front edge of the front door panel there are two 5\16 in screws there remove them and un plug the light switch and the door switch assembly .grasp the front door panel and give it a quick snap forward to disengage the retaining clips and the door from the drum remove the door .Lay on the floor reach in and remove the belt from the idler pulley and blower motor pulley .Then while standing at the side of the drier grasp the belt with one hand and the front of the drier drum with the other and **** up sharply on the belt to release the drier drum from the rear drum bearing then remove the drum out the front that will let you replace the screws
Mar 28, 2008 | Dryers
I'm tring to put a belt on my World pool, Iperial series heavy duty dryer.
afacing the drier get a small putty knife come about 1 inch from the edge of the drier and push in with the putty knife to release the plastic clip some times this can be difficult pull up on the top at the same time do that on either side till you get the top up then tilt the top back against the wall disconnect the the door switch wires look in the drier to the front panel on either side you will see two 5/16 screws remove them tilt the front panel toward you nd remove the panel put the belt around the drum slide it back to where you can see the old one has been running pull the idler wheel back hold tension on it and put the belt around the motor pulley let the idler pulley up till it engages the belt and reverse dissemble don't for get to plug the door switch back up
Mar 12, 2008 | Dryers
Maytag Atlantis MDE7400AY Electric Dryer Logo
73 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
