D.v.d.drive My d.v.d drive won't open
    Novelist:
    Scholar:
  • 141 Answers
Take a paper clip. In every cd/dvd rom there is a very small hole on the front plate. You would probably never notice it. Stick the paper clip into the hole and the tray will open. Maybe you have a stuck cd in there. Hopefully it will work after that on it's own again.
Is the light on it working?
You didn't say if you have a pc tower or a lap top as further trouble shooting will require knowing this.
Posted on Aug 18, 2008
SOURCE:
Why won't my packard bell's cd disc or floppy disc drive won't open
CD / DVD and most optical drives - Manual eject by sticking a straightened paperclip in the tiny hole and gently push open.
Apr 02, 2013 | Packard Bell Computers & Internet
Cd drive won't open
Sometimes a bad disc can cause this. You can stick a paper clip in the hole by the eject button to open it. If it isn't opening with the button though I'd replace the drive.
Dec 25, 2012 | HP Compaq dc5000 PC Desktop
Dvd drive won't open on emachine el1333-21f
use a open paperclip and push it into small hole on the front of the drive its a manual release
Nov 16, 2012 | eMachines Desktop / AMD Athlon Processor /...
97 Mercury Mountaineer driver side door won't open. Outside handle flops around; inside handle won't open door
Try a slim jim first, down the side of the window. Or AAA or locksmith. If no luck, remove the seat first. Find the screws and bolts around the door handle and arm rest. Most Ford's have screws around the outer side of the panel. I don't believe your's does. The panel lifts or pops off. Once the panel is off, you can reach down and open the door. Just a note. I have done some to where the panel came out in pieces.
Mar 14, 2012 | 1997 Mercury Mountaineer
Cd drive won'tclose
i've already answered on your question "cd drive won't open"
solution is the same
Mar 12, 2012 | Gateway Computers & Internet
My dell 1645 disc drive won't open , I burnt a
There should ba a tiny hole on the front of the tray cover on the drive.
Switch off, get a paper clip or something about the same thickness and insert it carefully in to the hole, push it in until the tray opens.
Jan 08, 2012 | Dell Computers & Internet
My computer doesn't recognize my optical drive within the BIOS or windows (HL-DT-STDVDRAM GT31N ATA Device ) in windows7
If BIOS won't detect the Optical Drive, try reseating the SATA cable connection from the ODD to the mainboard. it might be have troubles detecting it due to a loose connection.
May 04, 2011 | Hitachi Computers & Internet
Toshiba Satellite a135-s2386 won't bootup and CD/DVD drive won't open. The power button, plug button and battery button all come on. I tried taking out the RAM and switching the 2 RAM sticks. I also took...
I assume there is a specific reason that you mentioned the DVD drive won't open. Is it because there is a disk in it that you are trying to remove, and you can't because the laptop won't boot? You can open the DVD drive with a pin or paperclip. There is a little hole in the drive near the eject or open button. Insert a small pin or paperclip straight into that hole and push. It should pop open.
May 01, 2011 | Toshiba Satellite A135-S2386 Notebook
Disc tray will not open. I've turned on &off several times and it won`t open the tray. tries to but won`t open
This problem is caused by a loose drive belt in the eject mechanism, you need to open the ps2 and replace the drive belt...
Take off the top cover, then take off the cover from the top of the dvd drive mech... then carefully remove the disc tray and you should see the belt near the front. Replace that belt and it should work fine again
On a couple of rare occasions the drive motor has been found to be faulty, but usually replacing the belt will fix it
Jan 25, 2011 | Sony PlayStation 2 (PS2) Console
Open Questions:
Computers & Internet Logo
43 people viewed this question
Ekse
Alun Cox
