Question about iZotope Music & Speech Cleaner Full Version for PC, Mac (IZ11095)
I just purchased and installed Izotope Music & Speech Cleaner and attempted to edit some wav files, but it says that EVERY file is either corrupt or is not supported. I know that the files are not corrupt and wav files are supposed to be supported, and the program is supposed to work with Windows 7. What can I do to make this work?
Tip
How to convert M4P music to MP3
The music and audiobook files you purchased from online stores are protected by DRM. But most mobile players doesn't support DRM format. However you can burn the protected music files to CD-R/RW disc to make an audio CD, then use CD ripper softwares to rip the audio cd track back to MP3, WAV, WMA etc.
There are two ways to convert M4P music to MP3. One way is to use itunes for sophisticated computer user, another way is to use third party program for beginner, which is much easier.Following the steps , then get your job one easily.
Part one: Using itunes to converting M4p music
Step 1: Run iTunes and set burner options firstly. You can choose
Edit>Preferences>Advanced>Burning menu and then select your CD burner.
Note: If you don't have a physical burner, you may use a virtual burner program, NoteBurner. Go to http://www.noteburner.com to download the program. After you install it, you can choose NoteBurner Virtual CD-RW as what you do in the first step.
Step 2: Create a new playlist in iTunes and add all m4p files you want to convert to this new list.
Note: If you use NoteBurner, you need to select the output format in NoteBurner. After you click Settings button, you can set the output as MP3, WAV and WMA.
Step 3: Click Burn Disc button in iTunes to starting the burning. If you use NoteBurner, this is the final step since the program can rip back the burned music automatically. The output folder will be open automatically after all music finishes encoding.
Note: If you burn the m4p files on real CD, you need to rip the music back in iTunes. Open iTunes Edit>Preferences>Advanced menu and click small Importing tab inside the Advanced tab to choose "WAV encoder" or "AIFF Encoder" in the "Import Using" dropdown. In the left-hand panel under "Devices", select the CD that you burned
Step 4: In the main window opposite, deselect any CD track(s) you do not want to convert. Right-click or control-click over them, and choose the "convert to AIFF" or "convert to WAV" option.
Step 5: After the conversion, you may find the converted file at C:Documents and SettingsAdministratorMy DocumentsMy MusiciTunesiTunes Music
Part two: Using third party program to convert M4p music
Comparing to the previous method, the following is more simple and easier, you can finish the job with just several clicks.
Step 1: Free download M4P Converter, install and run it.
Step 2: Clicking "Add" or directly drag-drop protected M4P files. Batch M4P to MP3 conversion supported.
Step 3: In the "Setting" button, choose MP3 format (*.mp3), you can also custom the music.
Step 4: Click the "Start" button to start converting M4P to MP3. After successful converting M4P to MP3, the result shall be stored on the "Output path" folder. Then you can use them for playing without any limitation.
on Oct 28, 2010 | Computers & Internet
Tip
How to convert m4p music to mp3
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Convert m4p to mp3,itunes to windows media, convert itunes music
The M4P file type is primarily associated with 'Protected AAC File' by Apple Inc. AAC is the audio layer from the follow-on format to MP3. The .M4P extension is AAC purchased from Apple's Music Store (iTune) and is protected by a Digital Rights Management scheme.
Most songs sold through the iTunes Store are encoded using FairPlay-encrypted 128 kbits/s AAC streams in an MP4 wrapper, using M4P extension. Apple has maintained tight control of its FairPlay encryption. Other online music stores cannot sell music files encoded with FairPlay. This means that consumers who want to listen to songs downloaded from the iTunes Store must either have an iPod or convert the files to an open format. There are two ways to convert M4P music to MP3. One way is to use itunes for sophisticated computer user, another way is to use third party program for beginner, which is much easier.
Note: If you don't have a physical burner, you may use a virtual burner program, NoteBurner. After you install it, you can choose NoteBurner Virtual CD-RW as what you do in the first step.
Step 5: After the conversion, you may find the converted file at C:\Documents and Settings\Administrator\My Documents\My Music\iTunes\iTunes Music
on Sep 19, 2010 | Computers & Internet
My Digital Wave player wont open up so I can access my recordings. Thanks.
If you can move the .wav file to the PC it should be able to play with all mediaplayers available (for example, Windows Media player). The .wav format is very well supported, but it takes a lot of disk space: a cd in .wav format is about 600 Mb for 1 hour of music. Speech might be smaller.
You can use CDEX or AUDACITY (both free) on the PC to convert the .wav file to .mp3 (which is much smaller).
What does the manual of your VN3100 say about connecting the device to the PC and copying the files? It could be as simple as drag and drop in My Computer if it gets a drive letter.
May 10, 2011 | Olympus VN-3100PC Digital Voice Recorder
I try to add music to my picture movie through windows movie maker but each time error:0x87160129 keeps popping up.movie will play but without music.Please help.
Program requirements before music, videos are displayed together on a computer
1. A music editing software separaly installed on the computer
a. the music files would be extracted from disk mediums by music editor software.
b. a versatile music editor software would provide format conversions
c. a music editor software that makes possible clip extractions to be integrated onto another program
2. A movie editing software separately installed on the computer.
a. a software that recognise verious file format in music and videos
b. a versatile video editor software would intergrate music from another software
Important notes
1. Music file formats are selected compartible to the video editor software on which to be integrated
2. Files have to be edited and stored at a separate computer folder like my documents, my briefcase, or personal file folder
Initial diagnostic checks
1. The music file is in an incompartible format, performing a file format convertion should resolve such an issue
a. software multimedia converters are acquirable to be installed separately
2. the music file is corrupted, selecting another would resolve the issue
3. performing the video creation precess altogether would fix any error. Discard the video created, and rebuild a new compilation of music and videos.
a. notice any file errors requiring fixing
Dec 20, 2010 | Computers & Internet
Is it possible to import MP4 files into Windows Movie Maker 6.0 without having to convert to a different format first? I have a Pinnacle Video Transfer device that creates MP4 files, that I want to...
Windows Media Player 11 recognizes and plays MPEG-4 just fine but WMM doesn't recognize them. I would like to import some MPEG-4 files into Movie Maker and work with them - is there a codecs or something that allows this?
I'm sure I can find a program to convert MP4 into a format MM will recognize but if possible I'd like to just skip the conversion step and work with MP4 directly in MM.
Thanks!====================================================
Movie Maker is not compatible with MP4 files...
best bet would be to convert them to .wmv.
The following freebie might be worth a try:
Format Factory
http://www.pcfreetime.com/
All to MP4 / 3GP / MPG / AVI / WMV / FLV / SWF.
All to MP3 / WMA / AMR / OGG / AAC / WAV.
All to JPG / BMP / PNG / TIF / ICO / GIF / TGA.
You need some software to convert the protected M4P music file to unprotected MP3, WAV etc first, then you can import the mp3 files into Windows Movie Maker as background music.
TuneClone is such a software to convert the M4P music file to MP3, WAV easily. You can click here to download TuneClone and convert them to MP3 files and then import the music files into Windows Movie Maker project.
TuneClone uses a virtual CD burning technology to simulate the burning and ripping process and can convert M4P files to MP3 without any CD-R disc and do this work quickly. TuneClone installs a virtual CD-RW, it helps you burn any unprotected or DRM protected M4P, M4a, WMA music files onto the virtual CD, rips tracks on the virtual CD, encodes tracks onto MP3, WAV or WMA music files. It can repeat this audio converting procedure until your whole music collection is done.
Since the virtual CD emulates your computer RAM and hard disk as erasable CD-RW drive (Virtual CD-RW), the converting speed is faster than any other m4p to mp3 conversion programs.
Windows Movie Maker is video creating/editing software that is included in recent versions of Microsoft Windows. It contains features such as effects, transitions, titles/credits, audio track, timeline narration, and Auto Movie. New effects and transitions can be made and existing ones can be modified using XML code.
Jun 01, 2010 | Microsoft Windows Vista Home Premium with...
WAV Files seen on MP3 player but not able to hear them
Hey generic2008,
According to information provided by the manufacturer, the only file formats that this player is able to support are MP3 and WMA audio file formats. This unfortunately means that while you may be able to transfer WAV files to the unit's hard drive, it will not be able to play those music files.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 10, 2008 | Creative Labs Muvo V100 MP3 Player
DENPA WAV FILES CORRUPTED!!
Hi Guys,
I have the same corrupted file, but you can recover it by using the GoldWave software. Just type"Goldwave" in google, follow the link and download the software, install it. From that software open the corrupted file, and then save it as a new copy. ( It will fix the problem when opening the file, where you can see it). They try to play the new saved file, shld be fine.
all the best.
Oct 30, 2007 | Denpa USB-24 Digital Voice Recorder
RCA RP5022B voice digital recorder
http://dinhe.net/~aredridel/devoc/ -- online converter to .mp3.
Oct 13, 2007 | Audio Players & Recorders
iZotope Music & Speech Cleaner Full Version for PC, Mac (IZ11095) Logo
73 people viewed this question
Top iZotope Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an iZotope Computer and Internet Expert? Answer questions, earn points and help others
