Proper proceedure would include a 17 or 19mm allen socket for the end of the axle, but normally you can get the axle nut loose by leaving the 2 pinch bolts tight in that end of the axle. So, in order-
1-remove axle nut. 2-remove 2 bolts holding the brake caliper to the fork and tie it back out of the way.3 loosen the pinch bolts at the bottom of both fork tubes, this will allow the axle to slide out. There will be a spacer on the rotor side of the wheel for the bearing, remember this when you reinstall.
Installation-1-clean and lightly grease the axle and inside the bearing seals. 2-install spacer on rotor side of the wheel. 3-reinstall wheel onto the forks,tighten axle nut,leave the pinch bolts loose. 4-with the pinch bolts loose, compress the forks down-this insures that they are parallel to each other. If they forks aren't parallel, they will wear the bushings and fork seals prematurely. 5-tighten the pinch bolts to about 15NM. 6-torque axle nut to 40NM. 7-reinstall caliper.
