Sanyo 32 in. ds32424
No color,menu is in color.inputs have blue background but tv is in black and white.
thanks
Check cap around ic101 c256,c253,c252,c258,also c211,c212 &x251 if good replace ic101 la76835n
Posted on Sep 25, 2008
SANYO REMOTE MODEL: FXWD - PROGRAMMING MANUAL
The Sanyo FXWD remote was used with the Sanyo DS27930 and DS32424 TV. The manual for the TV is available at manualslib.com. The instructions for the remote are on pages 7 thru 11 of the TV manual.
Mar 28, 2012 | Televison & Video
Hi gud noon.just want some advice i have a problem with our tv sanyo flat screen if we try to turn it on it only appears blue screen theres no picture....thats our problem... we try to call already the...
  1. Try changing the input on the TV to see if the Blue screen goes away. Can you access the TV menu on the screen? If so, try running a channel scan until it is complete. Then check if the blue screen is still there.
  2. Disconnect any RCA cables, or other input cables from the back and see if you still have a blue screen.
Here is the link to Sanyo's Support site: http://us.sanyo.com/Customer-Support
E-mail: support@sanyotv.com
Phone: (800) 877-5032
Fax: (870) 630-4223
Feb 25, 2011 | Sanyo DP32648 32 in. LCD TV
LT32HVE only in black and white with component inputs...definitely the proper red is plugged in because we swapped it just in case and it did not change the problem. Also when trying to bring up the menu...
On component inputs the color is carried by the green connection. I would check your green cable. It also carries the video which you seem to have. Since the menu comes up black and white also does it do this in composite also? If it does it is most likely your main board. If your green blue and red cables are ok and you still have black and white it is also most likely your main board. Component uses digital portion of main board. Composite does not
Oct 22, 2010 | Olevia LT32HVE 32 in. LCD Television
LG tv shows av inputs as black & white
you need to plug all three colors in not just yellow
red blue green need to be pluged in their respective colors
Nov 28, 2009 | LG 27LC2R 27 in. LCD TV
RCA TV lost Color
It sounds like your grandson found the "monochrome" setting in the menu on your remote. It may be in the "picture settings", "set-up" or "advanced" setting.
Sep 10, 2009 | RCA 32F531T 32" TV
A/V in black and white
good day,
what video device do you plug in to your TV screen, DVD player/VCR or game console?
If you still have the owners manual of your TV screen, look for instruction regarding Color system or video system. this menu will allow you to change color sytem from PAL to NTSC or AUTO system.
most likely the reason why you have a black and white color from vidoe input is because of system color compatibilty from your input device to your screen.
Or if your using a dvd player, you can also try accessing the "setup" button and look for video setting. from the video setting there will be selection to choose from: PAL , NTSC, AUTO . always select "auto"
so that the color system of your DVD player can change from PAL to NTSC deffending on your TV screen system setup.
cheers,
mark
Feb 01, 2009 | Sanyo Over-the-Ear Sleek Boom Microphone...
Sanyo DS32424 can't hook up PS2
Some of the inputs will be below channel 2. Just channel down below channel 2 and see if it finds them..
Feb 24, 2008 | Sanyo DS31590 31" TV
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
