If you are talking about a BIOS password, information is here
http://www.fixya.com/support/r3656360-dell_portable_computer_bios_hard_drive
Testimonial: "You put me on the right track. All of my other options were not helpful to me. Again, thank you so much !!!"
SOURCE: How do I unlock my dell inspiron mini???
Hi
can you please explain what it is exactly that you want to unlock
is it a password or the keypad or the number lock or the scroll lock
or even the pad lock that some laptops have lots of these unlock keys are on the top row
of the keyboard sometimes they work if you press the desired key or sometimes you need to press the FN+ the required key
please post below it this information has not answered your question telling us what operating system you are running
many thanks
SOURCE: loud beeps at start up dell inspiron mini
Beep codes for the Inspiron Mini are as follows:
Beep Code Possible Problem
One Possible system board failure — BIOS ROM checksum failure
Two No RAM detected
NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
Three Possible system board failure — Chipset error
Four RAM read/write failure
Five Real Time Clock failure
Six Video card or chip failure
Seven Processor failure
Eight Display failure
SOURCE: about the normal temperature of dell mini inspiron 10
you can use a external fan designed for notebooks, there a syte,
http://www.dmail.pt/prodotto.php?cod=180634-107&np=1
SOURCE: fomating dell inspiron mini 10
Does it make any difference which order i put them on the computer, i have an operating system disc and a resource cd
Thank you
SOURCE: how to unlock dell inspiron mini laptop notebook
Resetting password & user name on Windows:b>*Start your computer
*Keep pressing "F8" as the computer starts.
*This will enter the computer in Safe Mode.
*(When the window "Advanced Boot Options" opens, choose "SafeMode" with arrow key and confirmby pressing the Enter key, then computer enters Safe Mode.
*Once you are in the Safe mode Click "Administrator" on the Windowslogin screen.
*Take note that you have set the Administrator password before, you need toinput the changed password instead of leaving "Password" field blank.
*Then click Start > Control Panel > User Accounts > Select the accountthat is locked and change the password.
**Restart computer and login into the account you just created using your newpassword.
what kind of lock in ur dell inspiron lap?
