Question about Pioneer PL-990 Turntable
Help need to replace beltplease help turntable
Pleae help The turntable belt came off...I tried to fix it but the belt seems like it's too long. I tried to figure out how the belt was connected to the motor...but I can't seem to get it....help !!
  • Anonymous May 17, 2009
    could you provide a picture link of what the rubber band is supposed to look like for future refrence?
FAIRLY SIMPLE...
1) REMOVE THE PLATTER
2) WRAP THE BELT AROUND THE INNER CIRCLE FOUND ON THE BOTTOM SIDE OF THE PLATTER, THE BELT SHOULD FIT PERFECTLY....
3) PLACE THE PLATTER BACK INTO PLACE...
4) THROUGH ONE OF THE SPACES ON THE PLATTER, TAKE THE BELT AND PLACE IT OVER THE MOTOR WHEEL...THAT SHOULD DO IT.
Posted on Aug 19, 2008
6ya staff
SOURCE:
My record player (Spirit of St. Louis CD/Cassette/Turntable) still works, but the turntable seems off. The speakers are fine so it's probably a problem with the needle, or the timing belt.
It's defiantly the belt. You can do it yourself. What you need to do is make a note of how it fits NOW - before you remove it (take photo's if you can. This will make it easy to replace it. You will find access to the belt most likely under the turntable matt. Just lift or peel it up. If it is glued you can re-glue it when you have finished, with some Bostick type glue.
When you have removed it take the diameter of the belt in MM and the thickness and search for it on Google. You don't have to be 100% spot on with the diameter measurement.
If you have any problems fitting the belt there are plenty of demonstration video's for belt replacement on YouTube.
Aug 06, 2015 | Audio Players & Recorders
I have a Crosley 3 in 1 turntable (not sure of the model but I'll include a photo). The turntable spins fine if it hasn't been in use for a while. But after I start to play a record, the turntable will...
Crosley Turntable Belt Replacement Video from Crosley Radio on Vimeo
Yes. Please contact Crosley Radio at 1-866-CROSLEY for assistance on replacement parts.
It sounds like the turntable belt has stretched . Replqacemnet belt can be purchased from Crosley. The number is above.
Jun 02, 2014 | Audio Players & Recorders
Speed seems a little slow on 33s. How can I fix this?
If the problem is encountered on both speeds, 45 & 33, then there is a high chance that you are in need of a belt replacement.
Here is a general guide on how to replace a turntable belt.
You can also use it to check the belt status.
Jul 23, 2013 | Aiwa PX-E860 Turntable
How do I attach the turntable belt to the Aiwa px e850
Lift the platter off the turntable. You can identify the motor spindle by using your fingers to turn the round shaft which rotates freely. Remove the rubber mat off the platter. Place the belt around the outside of the drum on the bottom of the platter. From the top of the platter, place your finger in one of the platter holes and tension the belt so it will not fall off or twist. Griping the platter trough the holes while keeping tension on the belt place the platter on the turntable aligning your finger with the belt to the motor spindle. Place the section of the belt on your finger over the motor spindle. Replace the rubber mat on the platter.
Nov 05, 2009 | Aiwa PX-E860 Turntable
Need to replace a turntable belt on a zenith
Try this company? email them at this link but remove the <remove> from the address?
service<remove>@turntableneedles.com
Oct 16, 2009 | Audio Players & Recorders
Hi, I have a technics stereo system from 1986.
If the turntable is belt driven you may have a stretched and slipping belt that needs replacement. This seems most likely and is simple to fix. You will have to lift off the turntable to see the mechanism beneath. It may be held on by a nut or clamp. A web search for the model name and "dirve belt" may yield a replacement.
If it is driven directly by a motor without a belt, the motor is probably dying. Replacement more involved, expensive, and hard to justify, unless you're really into vinyl.
Aug 06, 2009 | Technics Audio Players & Recorders
Jvc turntable
hi, please check first your fuse inside your turntable, replace it if possible
Apr 04, 2009 | JVC AL A158BK Turntable
Remove the turntable platter. Put the belt on the bottom of the platter. Put the platter back on, and then rotate the platter until the opening aligns with the brass motor shaft. Pinch the belt off the platter, so you can wrap it around the brass motor shaft.
Turn on and go!
- Davis
DIGITAL ANALOG THERAPY
www.REPAIRNYC.com
Jun 28, 2008 | Sony PS-LX250H Turntable
Belt off
Lift the platter. PLace the belt under the platter on the inside ring. PLace it back on the turntable, and you can stretch it back onto the motor with your finger or black stick through one of the holes on the platter, while the platter is positioned where it is accessible. if you need a replacement, try...
http://1200s.com/Store/PARTS-TECHNICS-TURNTABLES-Drive_Belts/c271_272_278_398/index.html
the technics belt #2 seems to be universal. The staff there is top notch and can get you the correct belt. Call them with your model.
Keep me posted.
Nov 03, 2007 | Pioneer PL-990 Turntable
Turntable rotating slowly or not at all
First and foremost, are you sure you installed the correct replacement belt, and installed it correctly? Just ruling out the obvious. Now, if you installed the belt correctly, then the only other thing that could cause this is a bad motor. Not an expensive part, but with labor, it might be cheaper to just buy a new one. Figure the part itself is about You will more than likely be able to remove the cartridge/stylus and use it on your new turntable, just make sure the tonearm is the same style as your existing turntable - P-MOUNT Tonearm. If you buy another belt drive, you might even be able to keep the belt you purchased as a back up - might fit! Here is some part info on your turntable: - Belt - Part #SJY90080-3 - $5.99 - Motor - MOTOR, 4 VDC, .2 WATTS - Part #SDMB5E - $19.99 Labor - 30min This is just to give you an idea of what it would cost to replace the motor. I put the belt part # on there, just so you could verify that you bought the correct part. Hope this helps some. - Justin
Aug 02, 2007 | Technics SL-BD22 Turntable
Pioneer PL-990 Turntable Logo
347 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
