Question about Goodman CLQ36AR49 Air Conditioner
Hvac problems i have a trane commercial aircondioning unit am getting power after the fuses nothing esle works
  • Sam Gibson
    Sam Gibson Jan 28, 2017
    I'm sorry to hear that you're having issues with your Trane commercial AC unit. It sounds frustrating that you're getting power from the fuses but nothing else will work. I would imagine that an HVAC professional who specializes in industrial or commercial units might be able to help. http://www.aeheatingandair.com/commercia...
Jump connections at the stat. if it runs replace stat .. switch fan to on if fan blows you know 24 v is arriving and leaving stat to power blower. jump red to yellow to make compressor section run. jump red to green to make indoor fan run. in an emergency jump red to fan g and red to yellow and let run till cold then turn off breakers to outdoor unit till hot then on again. NOT recommended unless its deathly hot etc or system is hopelessly beyond professional repair
Posted on Oct 12, 2008
    Problem Solver:
  • 7 Answers
Control board low voltage problem
Posted on Aug 19, 2008
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Hi :) I have the Trane Furnace that just turn on
on older tranes if 120v power is reversed it would do that try switching leads on pigtail to board. make sure to unplug first!
Oct 31, 2013 | American Standard Trane Ge Gas Furnace...
HVAC Blower stopped working
The fuse you replaced powers the hvac control. The run relay is powered by a 30amp fuse in the fuse box near the battery.
Is the relay getting power from that 30amp fuse ?
Jul 10, 2013 | 2004 Saturn ION
I have a Trane gas furnace with White Rodgers 50A50-474 board is flashing a 2 flash code which is a system lockout-no flame/Check line polarity message. The furnace blower contines to run, but the gas...
Sounds like your ignitor is bad, not lighting the gas. If this happens 3x, then controler goes into lockout and induced draft motor continues to run to extract the gas fumes as a safety.
Either replace the HSI (Hot Surface Ignitor) or sand down the end of the electronic spark ignitor and it's ground rod (they work like an exposed spark plug) to remove the carbon buildup on it so it can spark again. All with the power off, of course!
If you need more help, please ask, I'm glad to help! 25 year HVAC service Tech- residential & commercial systems.
Apr 05, 2013 | Heating & Cooling
I had a power surge on my 15 year old HVAC residential Trane Unit. I can either have my insurance repair it or I can pay the difference to replace. I do have coverage to pay for Alabama state building...
13 seer minimum for new installs. I have seen ratings as high as 18 or more on
some units (410A systems)
I recently replaced my system with a 13 seer R22 system, since they are
more easily serviced and I am very familiar with them. Given the average lifespan of
a system before major service is around 10 years depending on model.
I have worked on Trane, Carrier, Intertherm and Goodman units and prefer the Goodman
units, as they seem to be much quieter running and are built in America.
Jul 15, 2011 | Heating & Cooling
Danby standup aircondioner ( 3 in 1) , does not MODEL APAC9030
If you receive an answer to this I have the exact same problem... dougakers at msn dot com
Jul 13, 2010 | Danby Heating & Cooling
I have just replaced my HVAC Control board &
Once you have installed the jumper, you will need to kill power to the furnace for about a minute to reset the board. Make sure the the jumper is making good contact. Sometimes they appear to be plugged in but still are not making contact.
Oct 04, 2009 | Heating & Cooling
Blower fan has no output. Temp guage not working
for blower motor check fuse hvac 20a int.panel and hvac 30a fuse in elect.center eng.compartment,if ok,check for 12v at blower connector if power is there fan is defect..temp.gauge check connection at unit if ok check resitance if it varies when engine warms up,if it doesnt vary replace unit,if it varies check wiring circuit,unit is place at drivers side of eng.block near sprk plugs.for hard to start;if check eng.light is not on could be in need of a tune-up depending on how long ago it was done,if check eng light is on or was on scan ecm for trouble code.
Oct 03, 2009 | 1999 Chevrolet Blazer
Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Jun 30, 2009 | Honeywell Electronic Programmable...
Commercial fridge is blowing the fuse in panel all of  a sudden. Nothing has changed. Is it the fridge or panel?
unit could be using more power then normal if it needs cleaned, next time it blows fuse find and outlet that is still working (and not overloaded with other products) plug refrig in that outlet with extention cord and see if it blows that fuse.
May 16, 2008 | Everest Refrigeration EMGR24 Commercial...
Goodman CLQ36AR49 Air Conditioner Logo
152 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
