Hi I cannot get my d.v.d drive to open and close. What do I do?
  • katyliz54 Aug 18, 2008
    Yes it helped for most of the time. It still sticks. Can I spray air in to clean possible dust out? It still hesitates to open.
  • Anonymous May 11, 2009
    My toshiba drive does not eject and I did the manual eject thing poking a paper clip in the hole. I do notice the drive light blinks 3 times pauses 3 times and then quiets. still no eject control. I will take the side off and try the power thing. THis is on xP Pro, P4, Asrock MB.
  • 125 Answers
  1. If the keyboard has a CD/DVD Eject key, press it. The Eject key is usually placed by the volume knob and is marked by a triangle pointing up with a line underneath.
  2. Double-click My Computer .
  3. Right-click the icon for the CD, CDRW, or DVD drive that is stuck, and then click Eject.
  4. If the CD or DVD drive door button is a long clear plastic bar on the front of the PC, press firmly on the right side of bar. Some models have a button on the front panel of the PC to the right of the hinged door. Press the button to eject the drive.
  5. If the drive door button is part of the PC case and is covering the actual drive door, open the door that is part of the PC case and press the Eject button on the faceplate of the drive.
  6. Restart the PC and press the Eject button on the front of the drive when the first screen appears (before Windows launches). If the drive door opens this way but does not open in Windows, another software program is taking control of the CD driver. Try shutting down or configuring any software programs that create discs or monitor the CD or DVD drive.
  7. If the door still does not open, do the following:
    1. Close all programs and shut down the PC.
    2. Unplug the power cord from the power outlet.
    3. Look for the small hole on the faceplate of the CD or DVD drive. This is the manual release. The location of the manual release hole will vary
  1. Straighten the paperclip and insert it into the manual release hole until resistance is felt.
  2. Once the resistance is felt, keep pushing the paper clip until the drawer opens a little.
  3. Remove the paper clip and gently pull out the drawer until the disc is accessible.
  4. Remove the CD and turn on the PC.
If the tray still does not open, do the following steps to check the power cable for the drive. Work on a hard flat surface over a non-carpeted floor:
  1. Turn off the PC.
  2. Unplug all power cords from the back of the PC.
  3. Press and release the Power button on the front of the computer.
  4. Remove the side panel.
  1. Unplug the power cable and wait five seconds.
  2. Find a different power cable that is not being used, plug the different power cable into the back of the drive, making sure that it fits firmly into the socket. If a different power cable is not available, replug the original power cable into the back of the drive, making sure that it fits firmly into the socket.
  3. Replace the side panel and plug in the power cord.
  1. Turn on the PC and press the eject button on the front of the drive.
If the optical drive does not have the manual eject feature and the CD tray will not open by using the steps in this document or if a disc has shattered inside the drive, the CD, CDRW, DVD drive may need to be replaced.
Posted on Aug 18, 2008
  • 2,961 Answers
If you look on the drive tray you will see a little pin hole, insert a pin into it and it will eject.
Restart the pc and it should be back to normal.
The motor runs but it only opens a few inches and slowly goes back down its a chamberlain whisper drive model HD900D
Hi. I have seen this before, although usually not from chamberlain garage door openers.
Pull the release cord that unlocks the door from the opener, and manually open the door ALL the way open.
Then lock back in place in the open position.
Then use automatic opener to shut door.
It will close very slowly, but should close all the way.
Then, open the door again using the remote, and the door will once again open slowly, this time it should open all the way.
Then close door with remote, and door should now close as it is supposed, with the proper speed.
The slow opening and shutting is the system position sensor resetting itself.
This is why your door is acting up.
I would also look up by the belt drive connects to the front of the garage door opening, to make sure there isn't any dirt, cobwebs, or other obstructions on the sensor that may cause it to re-close the way it does.
Jan 24, 2011 | Chamberlain 1/2-HP Whisper Drive Belt...
Code 39 dvd drive wont even reconize but will open and close
Hi. This is a registry problem which pertains to DVD/CD ROM drive. Please follow the troubleshooting procedure below.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Jul 29, 2010 | Computers & Internet
My cd drive on my compaq laptop is stuck open a lil and will not fully open or close
Nov 04, 2009 | Compaq Presario 700 470024-192 Notebook
Hi everyone. I just got my Eclipse spyder 08 and after shipping for few weeks, i have some problems with the top. when opening the top' the rear window does not goes up fully before the cover gets up and...
Run the top so the decklid opens, and down inside the top stow area there is a ~3" square access door for manual operation of the pump. Make sure the valve is tight!
I have seen many many 2008s that were never tightened enough from the factory.
Aug 29, 2009 | 2008 Mitsubishi Eclipse Spyder
HP DVD 635 - auto tray open
no ghosts, you either have something jammed up inside of the drive which is keeping the door from closing properly all the way or the door itself is defective.
Either way you would be better off replacing the drive with a new dvd-rw cause the drive would be up to date and the problem with the opening door would go away.
Mar 21, 2009 | HP Pavilion a810n (PP164AA) PC Desktop
Cd drive opening and closing on its own
You never should have pried it open. Only use the manual eject pin-hole with a paperclip. Noe it seems the drive tray is damaged and will not close properly so it is constantly opening and closing trying to find home. The drive will need replaced.
Jan 02, 2009 | Dell INSPIRON 6000 CENTRINO...
Xbox 360 starts up randomly, tray opens and closes spontenaously
I have the same Problem my X box came on spontaniously and the DVD tray opens and closes non stop till I get the RROD code. it will play games and DVDs only if it stays closed long enough to start then it opens up and starts the cycle all over. I opned up the DVD drive and can't see any thing blocking any thing I even used a Q tip to pit a little oil on the screw meckanisim that opens the drive and blue it out with compressed air. and it did not fix the problem I am going to have to buy a new drive my Drive is a Philips drive.
Nov 21, 2008 | Microsoft Xbox 360 Console
52-32-52 CD Internal Drive Tray Opening And Closing Problems
Since the CD drive still reads the disc, then repairing the unit is to your advantage. Repair involves, removing the drive from the desktop and removing the 4 screws underneath. The two halves/covers could now be separated and removed. Under the tray would be a gear mechanism that slides the tray in/out. it is powered by a motor through a small rubber belt. It is likely that the belt has deformed and would require replacement. This belt is similar to those used in audio electronic equipment and therefore would normally be available from your friendly neighborhood electronics parts store.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 18, 2008 | Samsung Computers & Internet
My cd/dvd opens then closes
> I've already replaced it once
Well, I've seen CD-drives that would re-open, when you try to close them -- it is _falsely_ detecting a "jam" as the tray is closing, and then just re-opens the tray, rather than "forcing" itself to close.
Replacing the CD-drive is the only way to fix that type of "false-positive" jam-detection conditions.
But, since you've done that, either you were unlucky-enough that the replacement drive was also "defective", or, you have a computer-virus on your computer that is maliciously issuing commands to the CD to "open-the-tray".
Sep 20, 2007 | Compaq (224130-001) Internal 4x CD-ROM...
Computers & Internet Logo
354 people viewed this question
David Payne
David Payne
