My TV's convergence went out and I'm ready to fix it but I need some assistance. What IC's do I need to replace along with which resistors? I need to know part numbers to order.
(2) STK392-110 Convergence Amp ICs
(3) 220 ohm 2watt metal film resistors
(3) 150 ohm 2watt metal film resistors
(2) 1.5 ohm 1watt metal resistors
(2) 2.2 ohm 1watt metal film resistors
(1) 1.8 ohm 1watt metal film resistor
(1) 3.3ohm 1watt metal film resistor
You can get the entire convergence repair kit which contains all the parts listed at the following link its called the AV48WP30 Convergence repair kit , but it applies to your model as well, and they include free installation instructions.
http://servicemanuals.vstore.ca/
SOURCE: Convergence IC,s overheat
Make sure there is enough heat sink compond between the IC's and the heat sink itself. These IC's do usually run fairly warm to hot but that heat should be disapated onto the heat sink.
All the colors in my tv are out aligment what part a need to replace?
