Question about Mitsubishi WS-55511 55" Rear Projection Television
Mitsubishi WS-55511 - No Power - No Blinking Light
I have read several posts in these forums, none of which give a blinking light. I can hear a very high frequency when plugging the cord into a power outlet, but I cannot get any power from the control panel...nor can I get the blinking light. Help?
  • 3 more comments
  • getsarge Aug 19, 2008
    Who would have a power supply? Is it something that a half-wit could install?
    Is there a way test to see if it's the power supply?
    I have access to an TV broadcast engineer, I'm fairly savvy myself and I can take instruction quite well.
  • getsarge Aug 24, 2008
    No rating on the meter, I reckon that's a great piece to replace. Looks like a simple cut, unscrew, put new piece on, solder, and screw back on. Who is a viable source to order the part through?
    - Thanks
    Sorry, my last comment was vague. The DM power board still shows the green light in the bottom...I'm guessing it's ok (not the blinking light, steady small green light).
    The Horizontal Output Transistor shows no activity when connected to a meter, which I'm guessing is the problem.
    Who is a viable source for parts?
    -Thanks EC
    Master:
  • 521 Answers
Http://www.asm-service-manual.com/List/Mitsubishi%20List%20ASM.htm
http://www.electronic-repair-kits.com/index.html
the above links will provide u with the manual for ur device plus a best sorce for any replacement of parts required.
pls do rate the solution
thanks.
regards.
fixya expert team.
Posted on Aug 24, 2008
  • Mitsubishi Master
  • 19,396 Answers
Try unplugging power for a couple of hour s before proceeding with anything else, I know it sounds silly but it is first thing to try.
If you get no light at all it is probably power supply fuse gone.
    Genius:
  • 1,011 Answers
Dear sir/madam,
Sounds identical to the capacitor problems. Check voltages are all ok on DM board power supply and standby power supplies.
thanks
good luck
Posted on Aug 19, 2008
    Master:
  • 623 Answers
T could be a coolant leak around the signal board that's causing your problem,
Look for a thin film of liquid or an oily substance on the board around the base of anyone of the CRT's and the 24 volt line is might be held low because of a bad vertical output IC or a convergence IC. you should take it to a repairman....
  • 4,234 Answers
The noise you are hearing is from oone or more parts in the switch-mode power supply that are oscillating. If this is all you get when attempting to startup the set, the problem is in the power supply itself or it is a dead short further along. The power supply it trying to work and failing. The first thing to check is the horizontal output transistor. This is a 3-legged part attached to a heatsink and shouldbe close to the flyback transformer (part with large red wire coming out of the top). Check this using an ohmmeter. You should read resistance when measuring between either outer leg and the center. If any of those read zero(0) in both directions, the part is bad and should be replaced.
Try that first. If that fails to resolve the problem, update this and we'll continue on to the next step.
Dan
  • ABRsvcs Aug 25, 2008
    Perhaps you mis-understood. Since the set is not powered up, there will be no voltage at the horizontal output transistor. You need to make the measurements I outlined above with the set unplugged.
    Second: If the power supply does not kick in at all and the transistor measures OK, then we need to look at the power supply area itself. Close to the area where the AC cord connects to the board you should see some capacitors that have a value in the 2.2-4.7ufd range with a working voltage of 200V or more. Try replacing those caps and report your results here.
    Dan
  • 10,594 Answers
High frequency can be hear when TV got problem of Horizontal Output Transistor short circuit. If you are not tech-person, please call tv repairman. If you are tec-person, let me know to guide you further.
Regards,
    Genius:
  • 1,011 Answers
Dear,
do a dusting and about the voice that u can hear, can be because of drysoldering.. sometimes it happens that due to drysoldering or cracks, noise feels from inside.
check carefully for any drysoldering, more prob. at the power supply section..check main filteration cap. ..
  • SALMAN NASEER Aug 19, 2008
    check it and give feedback. if u have already tested this situation then inform me the conditions so that i try my best to achieve the goal.
  • 6,487 Answers
This can be a problem with the powersupply of the television that's why you hear a high frequency noise and there's no power or any light coming on , the power supply may gone bad and needs replacement..
Good luck.......
  • 1 more comment
  • Mark Gil
    Mark Gil Aug 19, 2008
    You can buy it to a electronic store and if you have some knowledge with electronics you can do it by yourself but if not I suggest ask for someone who knows electronics and ask them to replace it for you or take it to a repair center and let them replace it...
    Good luck........
  • Mark Gil
    You can use a tester or volt meter hopefully you have a device like that to be use in testing the power supply...
  • Mark Gil
    Mark Gil Aug 24, 2008
    Yes, i think thats really the problem, you can get it to a electronic store near you..
    Good luck.........
I have a Mitsubishi WS-55515 that was unplugged, when It's plugged back in there is power but no picture and green light flashes then the power goes off. For reading other posts I believe it is th
if set has been unplugged plug it in and try to turn on===when power light goes off in seconds:
on the front of the set press and hold both the menu and input buttons for five seconds and release both.
power light will blink a two digit error code like 2 blinks, 2 blinks pause and repeat it several times.
what error code do you find?
Apr 11, 2012 | Televison & Video
Power button is not working travelmate270
Give us more details? What do you mean Not Working? Are you saying that when you press the Power Button, nothing whatsoever happens?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 06, 2012 | Acer TravelMate 2702WLMi Notebook
Easynote ls boot problems
What happens when you hit the power button? Give us more details if you want precise help.
Apr 05, 2012 | Computers & Internet
Dell OptiPlex GX620 no boot sometimes it appears black screen with a cursor blinking
Apr 02, 2012 | Dell OptiPlex GX620 PC Desktop
I have a new violation 9053 and first time to charge the green light blinks for about 10 seconds and then goes off and thje battery is now dead it seems, no lights, no power
Apr 01, 2012 | Computers & Internet
Hi i have an r630 desktop and it did work but now i have no power to motherboard no fans cpu but i do have power to the hard drives and rom replaced power supply same problem
Maybe your motherboard is toast.
Mar 30, 2012 | Computers & Internet
MODEL LT2016U WONT BOOT UP
Is it trying to boot up or is it doing absolutely nothing when you plug in the power cord and hit the power button?
My laptop shuts off after i turn it on.why
Does your laptop even begin the boot process where it displays stuff on the screen? Do you hear fans running, disk drives running, see lights, hear the cd drive click once and notice a light that comes on the cd drive door briefly when you press the power button? If not you computer either has a bad power cord, a bad dc power jack where the power cord plugs in, a bad mother board or static build up. 1) lets eliminate static buildup by removing the power cord and the battery then press and hold the power button for 30 seconds. Then replace the power cord but not the battery and hit the power button. If it boots up you had static build up. 2) Take an ink pen and put in in the slot where the power cord plugs into the laptop, if it wiggles loosely then your dc power jack which is soldered onto the motherboard needs to be replaced. 3) If the power jack is tight and when you plug in the power cord if you don't see any lights or hear a fan, disc, cd drive, then you can almost bet your power cord is bad. 4) If the power cord is ok then you have a mother board issue. Normally motherboards will give some beeps or constantly blinking lights when you plug in the power cord and try to boot up. These beeps or blinking lights will tell the technician what is wrong with your computer.
Mar 19, 2012 | Acer Aspire One Netbook 8.9" Notebook
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Mitsubishi WS-55511 55" Rear Projection Television Logo
126 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
