Question about GE Profile JB968 Electric Kitchen Range
F7 display For no discernable reason, this afternoon when we got home from work, the display read F7 and was beeping continuously. We pushed the clear/off button and it stopped, but in about 4-5 minutes the display read F7 again. After repeating this process, we turned the oven on, as if to preheat, and then turned it off. This seemed to solve the problem but we are wondering what might be the issue? Any help would be much appreciated!!
  • howaidnm Dec 29, 2008
    Greeting all, I am having the same problem and I call the services and the told me it is the dashboard need to be replaced!!
Good news
The problem was solved by disconnecting the power supply for three minutes and power up again and F7 diaper.
Thank you all
Posted on Dec 29, 2008
My frigidaire oven model es400 while cooking in oven, it started beeping and a code of f7 flashed on all control panel Windows. Not oven is higher temp than listed
Hey Scott, thank you for your inquiry!
Based off the information you have provided your Frigidaire range is displaying an error code of "F7" and it is beeping. Typically, "F7" stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If you continue to have issues with the "F7" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
Apr 29, 2016 | Frigidaire Kitchen Ranges
Displays "F7" and a continuous
If your Maytag range displays the "F7" error code, it means that the programmed fault error 7 occurred with the range. Luckily the error is easily fixed in most cases and requires no new parts.
Identification:
Once the error appears on the range it is usually followed by seven loud beeps to represent the number. Clear the error by holding a button down for a minute. The LCD will flash and the code will disappear.
Effects:
The most common cause of the "F7" error is a stuck button on the LCD panel. Look around the range control panel and examine to see if any buttons appear pushed in, stuck or out of place.
Prevention/Solution:
Take a damp rag and light wipe around the buttons to clear out any grease, food particles or sticky substance that may have built up around the button. Attempt to use your range and see if the error appears again.
Considerations:
If the error continues to appear, there could be permanent damage to your electronic range control. Contact your Maytag dealer for warranty information and replacement parts.
Keep us updated.
May 24, 2011 | Kitchen Ranges
The oven is randomly beeping and the display is reading f7
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic oven control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Apr 10, 2011 | Jenn-Air WW30430P Stainless Steel Electric...
Beeping with f7 display
HI this is a touch pad or key pad issue. In most models, the touch or key pad are integrated. In this case, you will need to replace the entire control board or EOC(clock).
Now, if the touch or key pad is separate from the main control board, and linked, via linking ribbon, i would advise to use the procedure below to isolate the problem area.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Oct 03, 2009 | GE Ovens
F7 appears on GE double oven JT950SA
f7 is a stuck keypad or overlay all you can do is replace it
Jun 30, 2009 | GE JTP45 Electric Double Oven
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
Constant beeping and F7 is displayed
Hi tahitian,
The error code F7 means that the Function key is shorted or stuck. To fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Dec 16, 2008 | Magic Chef 31000 Gas Kitchen Range
The lcd scrren on my range displays F7 in red and flashes d6 in g
The code is because of bad keypad/the control panel.Have it changed.It probably non-functional and constant beeping sound is followed as you mentioned.Theres a link to explain more about this for reference.The only solution is to replace the control panel.
http://www.askgene.com/2007/06/23/oven-error-codes/ge-oven-error-code-f7-and-how-to-fix-it/
Dec 13, 2008 | GE Spectra JBP78 Electric Kitchen Range
Kenmore electric built-in oven control panel beeping
Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
Aug 08, 2008 | Kenmore 42161 / 42169 Electric Single Oven
GE Profile JB968 Electric Kitchen Range Logo
262 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
