Question about Fedders AED24E7F Wall/Window Air Conditioner
Remote control The remote control stopped working. I replaced the battery and it still doesn't work. Are there tricks to installing the battery? Could the remote be dead? Can it be replaced? The window unit is so high we have to use a ladder to turn it on. Help!
  • Timothy Aug 30, 2013
    If you took the board out make sure you put it back in where the coils to connect to the batteris are inside the plastic not outside. You can get a remote at: http://www.electronicadventure.us/Mercha...
    My batteries had dripped corrosion on the chip. I took the board out and used a toothbrush and WD40 to remove the corrosion of the chip. Re-inserted the board, put the batteries back in and it work just like new.
  • 236 Answers
First you have confirm what really the defects is, is it the remote control or the control board.
HOW TO CHECK THE DEFECTIVE REMOTE CONTROL:
Check if the remote control if still good, using the camera of your cellphone point remote control to the cellphone camera and press the "on" button of your remote and you can see the light emitting from your remote control transmitter. If the lights emits that means your remote control is good, if not means the remote control is defective. If the remote emits light it means that the receiver at the control board in the indoor unit is defective.
Posted on Aug 29, 2008
Vizio remote xrv1tv doesn' t work. it doesn't do nothing. i replaced batteries.what can i do? used to work perfect almost 2 years. do i need to set up the control? how? thanks
Check the remote control for its infrared emission. If found no infrared emission, check its battery compartment, and clean the battery contacts. If battery contacts have been accumulated with dust or dirt, the remote won't work, as there will be no supply to its internal circuit. http://electronicshelponline.blogspot.com/. Check this link. It has one post, that describes how to check and repair a remote control. Pull up older posts there.
May 05, 2013 | Televison & Video
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Can't get tv remote to work
does the remote controller that you have been use is the original remote of the tv?. if yes tried to replace the battery, if still doesn't work tried with camera trick just to ensure if the remote controller work or the IR sensor of the tv was not working. just let me know if you know how to test the remote controller. now if you are using the universal remote controller make sure it was programmed properly with in the tv unit.
Sep 02, 2012 | Televison & Video
My remote will not work anymore.would stop every once in a while now not at all. Put new batteries in it and nothing in the way. My cable remote will not work as far as volume and power. Is it the remote...
Your need to replace the TV remote receiver. PN: 72795949. It will be located in the front of the chassis along and the control button board. This part is about $1. If you need a basic soldering tutorial, I have one in my Tips & Tricks. I hope this helps.
Mar 17, 2010 | Toshiba MW20FN3 20 in. TV/VCR/DVD Combo
My remote control I bought for my Sanyo TV stopped working I replaced the batteries and still did not work. I cannot find the code number to enter.
Please check & ensure the infrared is emiting from the remote control. Though we cant see this infrared beam with bare eyes, there is a trick to do so in http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html Most of the problems is weakened infared beam. Replace the batteries when needed. Hope this fix the remote control problem.
Jan 21, 2010 | RCA Universal Remote Control
Philips hts 3544 remote control not working. it just stopped working, I changed the batteries but still nothing. please help.
Jan 01, 2010 | Philips Universal PH301S Remote Control
Remote not working at all, do I have to re-program
Dec 21, 2009 | RCA RCR311S Remote Control
Remote control for garage door suddenly stopped working.
Press and hold for 3 seconds the button on the wall control with the lock icon. There you go.
Nov 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote control has stopped working
If you have replaced the batteries with KNOWN GOOD ones, observed the proper polarity when re-installing the batteries AND made sure the remote is in DVD "mode" (if it is a multi-remote) when trying to use it, the remote is bad. Replace the remote.
Mar 25, 2009 | Panasonic DMRES15 DVD Recorder
Remote Control stopped working
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
Otherwise the problem will be with the remote sensor or related components of the device.
Aug 27, 2006 | Toshiba SD-H400
Fedders AED24E7F Wall/Window Air Conditioner Logo
2,012 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
