Question about Sony MHC-GS100 CD Shelf System
System hung up with "protect power msg"
Did you ever solve the "protect power message" problem. i have it also. thanks.
rob richardson
rob.richardson@att.net
  • joe_nand Dec 16, 2008
    yea i have the same problem what's the cause?
    Genius:
  • Sony Master
  • 1,550 Answers
The audio amplifier IC are damaged you need to replace him good luck
Posted on Feb 11, 2009
Sir my MHC-RV900D is disply shows push power protection again and again.plz solve my problem. thank u
There is most likely a short in the amplifier that will need to be repaired before the unit will power on normally.
Mar 12, 2013 | Sony MHC-GX40 CD Shelf System
Protect push power
audio amplifier IC fried need to be replaced
Jun 01, 2010 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Power Protect still comes on now and again
Amplifier output chip in stereo is defective and unit gives error message of push power protect.
You need to replace output amplifier IC and check supplied voltages.
Feb 28, 2009 | Sony MHC-RXD5 Shelf System
Protect power keeps coming on - rdx5 MHC
protect usually means a speaker wire problem. remove all connections and redo them making nice tight twists in the connections the spliced end should be no more than 1/4 inch long. make sure to do this for all speakers as well as on the back of the unit.
Feb 23, 2009 | Sony MHC-RXD5 Shelf System
Machine 'protect' msg
his appears to be a very common problem here on the board. It means the unit has shut off the outputs because of either a bad speaker or shorted wire, or some failed part in the amplifier. If the trouble continues after you disconnect the speakers, the unit will require service to diagnose and replace the failed part(s).
I've never worked on this model, but in many brands the amplifier integrated circuit is a common failure. They are often not properly mounted for efficient cooling and burn themselves out. Another typical failure is some power supply part that is under-rated and just goes bad, and this is showing up as the protect failure.
Without a diagram and no direct experience, I can't suggest any specific action you could take, other than checking with a local shop for a repair estimate. (You might try contacting JVC on their website or by phone to see if they have any service bulletins. If something becomes a chronic issue, the manufacturer sometimes extends warranty service to cover the repair. Never hurts to ask!)
Feb 12, 2009 | JVC MX-KA3 CD Shelf System
'PROTECT' MSG EVERYTIME TRYING TO OPERATE
This appears to be a very common problem here on the board. It means the unit has shut off the outputs because of either a bad speaker or shorted wire, or some failed part in the amplifier. If the trouble continues after you disconnect the speakers, the unit will require service to diagnose and replace the failed part(s).
Pushed power protect
speaker protection turned on.it can be happend because of bad power amlifire section.can you remoove the powe ramp board with large heatsink.its very easy to repair.and i can help.
nuwan
Jan 09, 2009 | Sony Multi-System Mini Hifi Systems / DVD...
"PROTECT" message
I've got a jvc hx-d7 i am working on for a friend, he had it repaired once at a shop with this same problem, they replaced two 42v 2200mf caps. and one A1273 this solved the problem for 8months now its doing it again. I am trying to locate the A1273 to repair it again. Hope this helps.
Dec 25, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Sony MHC-GS100 CD Shelf System Logo
315 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
