Question about Microsoft Xbox 360 Console
XBOX 360 RED RING OF DEATH ! HOW TO FIX IT
3 FLASHING RED LIGHTS ON POWER BUTTON
  • Anonymous Sep 16, 2008
    You can easily fix the 3 Red Light error, and just about anything else on an xbox 360 with a downloadable repair guide. Here are the best guide on the internet:
    www.BestXBOX360RepairGuides.info
    I've fixed and sold dozens of xboxes using my repair gude.
  • Anonymous Jan 14, 2009
    wont turn on
    wont load games
    wont eject games
Wrap it in towels. the reason is because sometimes you get the 3 lights because something is touching the data board but not communicating. let it sit in the towels and overheat for about 30 minutes. keep in mind leave it on!
In some cases this can also fix the four lights which means the xbox isn't able to communicate with your television. If it doesn't, get new xbox cables.
Posted on Aug 18, 2008
SOURCE:
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
How can I fix "Red ring of death" on my XBox 360
Three flashing red lights around the Xbox 360 power button (nicknamed the "Red Ring of Death" or "Red Lights of Death" or "Red Ring of Doom"), instead of the one to four green lights indicating normal operation, represent an internal problem that requires service. Warning signs may include freeze-ups, graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, and sound errors, and the console only responds to pressing the power button to turn it off. These events may happen once or several times until the hardware failure occurs, or not at all. If the console freezes occasionally, the error will not necessarily follow. The technical problems seem to affect some generations of consoles more than others. e.g. Xbox 360 60GB This error code is usually caused by failure of one or more hardware components, although it can indicate that the console is not receiving enough power from the power supply, which can either be due to a faulty power supply or if the power supply cable is not fully inserted into the console. The 3 flashing lights can also be caused by power surges; if the console is connected to an outlet that receives a power surge, it may have a failure and the 3 lights will appear as long as the console is plugged into the outlet. Turning off the console, unplugging all power cables and plugging them back in, and restarting the console will fix the issue in this case. hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
Three red lights flashing
If this is your Xbox 360 console you are referring to, then you need a repair. If you are under your 3 year warranty from MS go to www.xbox.com/support to fill out a repair request, otherwise look for someone in your area that has experience repairing the Red Ring of Death.
Jan 03, 2010 | Microsoft Xbox Console
My xbox 360 elite has red flashing lights
http://en.wikipedia.org/wiki/Xbox_360_technical_problems damn ur xbox is in bad cond if u didnt open ur xbox u shuld have warranty send it back to microsoft
Dec 24, 2009 | Microsoft Xbox 360 Elite Console - Black
I have 3 red lights flashing and my disk tray gets stuck
when u have 3 red flashing lights its called RROD or red ring of death. u have a 3 year warrenty on that so just sent it in and for the disk problem, if u still have ur warrenty , you can just send it in so they can fix it.
Dec 08, 2009 | Microsoft Xbox 360 Console
Red flashing lights
If you have 4 lights, check your A/V cord. 3 lights is the Red Ring of Death. Call Microsoft. They have an extended 3 year warranty for this problem. hope this helps AJ
Nov 16, 2009 | Microsoft Xbox 360 Console
Power button is blinking red
if 3 of 4 lights are blinking red, you have a red ring of death and need to contact microsoft. this is distubingly common on some of the older 360 models.
Jul 11, 2009 | Microsoft Xbox 360 Console
3 red lights flashing and no repsonse
That is called the red ring of death...if you enter that into a search engine, you should come up with the solutions to fix the problem.
Jun 01, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 3 red lights can anyone please help?
That has absolutely nothing to do with the Hard drive. The red ring of death is a standard misfunction with the Xbox 360. You will have to contact your local game stores to see if they do Red ring of death fixes, send it in to microsoft, or attempt to red ring fix it yourself.
Dec 12, 2008 | Microsoft Xbox 360 Console
There are three red lights flashing
Hi
That is affectionately know as the Red Ring of Death!
Never fear, Microsoft provided an extended warranty on this fault! On the rear of your Xbox there should be a label with a date on, this will tell you the manufacture date.
Goto Xbox Support
and follow the link on the right for the repair process.
Mar 23, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
29 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
