Question about Sony KDS-50A2000 50" HDTV
Color issue My Sony 50" HDTV has a color issue. There is a green tint on everything that should show grey or black. I've tried to adjust but no go. Even when I reset to factory default there is no change. How can I fix this? Martin
  • Gayle Ashbach
    Gayle Ashbach May 11, 2010
    How long have you had your TV? Did you have the technician come out and do the dsolor adjustment that is recommended after about 250 hours?
  • 876 Answers
Excuse me I meant COLOR adjustment.
Posted on Aug 19, 2008
Screen is green
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
The screen has a reddish tint to it. Seems like a color issue and not sure what to replace. The picture works fine but everyone is red. Not sure if there is a bulb to replace or what? Any suggestions? This...
You need a simple color adjustment. (Color Calibration)
You don't need to spend money on this. Try it for yourself.
Your main problem is that your color temperature is set to warm.
You need to change temperature to COOL or 6500K depending, on how it is labeled.
You will see improvement, but there is a little more...
Move "Color" DOWN from it's current position (probably at 50) to somewhere between 30 and 40. (Just a couple of clicks above where the color rapidly washes out.)
At this point there will still be slightly unnatural color to skin tones, but all the artificial "sunburn" and blaring red will be gone.
Last (as far as color goes) move the tint 2 to 4 clicks toward green. This added green tint balances the color so that the flesh tones become completely accurate and realistic.
For even better detail, continue your home calibration here:
http://www.wowvision.tv/main.htm
Jun 13, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
I just replaced the bulb in my Sony 55'' Grand Wega. the picture looked fantastic the first day. turned on the TV the next day and everything that should have a ''white color'' looked pink. the blues...
Please adjust TINT control of Video Settings in Menu that will adjust color tone of TV. I do not think this problem is related with Lamp because TV screen does not have any color blobs or spots.
Above solution is for Sony KDF-55WF655 model TV, if your model number is different, let me know.
Thanks.
Nov 29, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Green tint on Siny 50" DLP
Most likely a defective Light Engine Assembly. They normally cost about $800.00, or in that area.
Aug 14, 2009 | Sony KDS-R50XBR1 50" HDTV
Green tint to sony kds-a2020
NOT ON THIS SET YOUR LIGHT ENGINE IS DEFECTIVE CALL sONY AND SEE IF IT IS ON THE EXTENDED WARRANTY LIST.
Aug 08, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Green Tint
bad optical block call sony they have a recall
Jun 01, 2009 | Sony KDSR50XBR1 50" Projection HDTV
KDS-R50XBR1 50 in. HDTV Television: I can't get rid of the GREEN
Its another instance of the optical block (light engine) failure these TVs are known for. Heat from the lamp has damaged the LCD panels in the light engine. Sony has been directed by the attorney general's office in New York to warranty these TVs going back 4 model years. Call Sony at: 1-800-222-SONY for assistance.
michtech
Jan 24, 2009 | Sony KDS-R50XBR1 50" HDTV
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Sony KDS-50A2000 50" HDTV Logo
136 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
