Question about Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony trinitron kv-20fs100
I had the tv for about 4 yearrs and one day i whent to turn on the tv and it made a click sound like it was coming on then it clicked agin as to cut off the stand by timer then cuts on blinking 4 times. some times i can still get the tv on but every time its cut off after that its hared to get it on some times taking hours why is this?
    Problem Solver:
  • 25 Answers
Maybe theres a cold solder in the vertical section.resolder it.take a lot of care when doing this if you dont have experience.
Posted on Aug 31, 2008
Sony TV turns off immediately after turning on
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Check this link to get more details about Sony Blinking codes.
Jan 13, 2013 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Sony KV-20Fs100. Same problen as #4620488. TV
4 blink of power led shows problem in vertical deflection section and most probably vertical output IC is defective, replace it to fix the issue.
Regarding .rar file type of service manual files, download winrar software trail version from internet, install it and use it to unzip .rar file to get pdf manual file.
You wont get +B volts because tv switch to protection mode and power supply shuts down. Service manual has blinking standby led error code details as well.
Thanks.
Jul 25, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY KV-20FS100 does not turn on
The standby light should be blinking a repeated count with a pause between counts. Can you post that here please? That will indicate the cicuit in which the problem was found that casued the shutdown. Armed with that info, I should be able to indicate the most probable defective parts and how to resolve the problem.
Thanks,
Dan
Feb 13, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Apr 07, 2007 | Sony KV-27FV16 TV
Sony 32" wega tube
plug out tv and start over by then the tv will reset itself.if that does not work call in a tech to solve,your problem.good luck/
Apr 01, 2007 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Sound Problem
There's a possibility that you may be experiencing problems with the audio output IC -IC404 - All serial numbers produced until July 2003 might use one of these defective IC's. So if your set was manufactured before this date, that is probably the culprit. If not, and you have it connected to a cable box that has its own volume control, it could be that its volume is turned down and by turning up the TV's volume too high that you are getting this distortion. Hope that helps.
Jan 20, 2007 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Sony Trinitron KV-27S46
There is a problem in the sweep section of the set. The Horizontal sweep power supply most likly. there is nothing a layman can do as it will involve troubleshooting the solid state circuit. please find a trainded tech to assist you in this repair.
Sep 22, 2006 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Tv has a mind of its own
Just had the TV repaired for the same issue. According to the shop it was a bad channel up/down switch. That impacted the other functions (menu not working, remote malfunction) because they're all intertwined. Only about a $75 fix here in the DC area, so maybe cheaper elsewhere.
Sep 02, 2006 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Sony FD Trinitron WEGA KV-20FS120 20" TV Logo
137 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
