Question about Acer Aspire 3690-2196 Notebook
Having problems shutting and installing
My system does not shut down. it also closes windows task manager automatically anytime i open it. pls i need your help urgently
  • 876 Answers
Do a major clean up o your computer
A virus and spyware update and scan
a Disc Cleaning
Delete all your cookies
Run your registry cleaner if you have one.
let me know if you do not know how to do any of this and I will provide more info.
You probably have either a virus or spyware. If you do not have virus control go to www.trendmicro.com/housecall and run a free virus scan and then follow their instructions to remove anything that they can't.
Posted on Aug 18, 2008
How to restart a pro line Intel sv.701
If you have Windows
Left-click START or the round blue Windows icon at bottom left of screen.
Or press the Windows key at bottom row of keyboard.
Left-click the white right-arrow symbol next to "Shut down".
This drops down a choice menu.
Left-click "Restart".
Now sit back and watch the magic happen.
Otherwise to shut down click the Shut down bar in Start window.
Or in case the PC freezes / hangs press "Power" button.
If an application hangs, stopping your computer, you can also try close down the app in "Task Manager".
Press Ctrl+Alt+Del
Wait until the Task Manager options window pops up on screen.
Left-click "Start task Manager"
Left-click "Applications"
Shut down the app then exit TM.
Reboot to refresh memory.
Dec 04, 2017 | Intel Computers & Internet
Tip
How to make the taskbar reappear when it disappears in Windows
Sometimes on a computer running Windows, an application will crash or an unstable process will lock up the system, and out of nowhere the taskbar that runs across the bottom of the screen will disappear. The rest of the desktop and all of your icons will probably still be visible -- it's only the taskbar that is gone. Without the taskbar, you can't access the Start menu or view the open programs in your system notification tray.
To get your taskbar and Start menu back without shutting down your computer, hit <CTRL><ALT><Delete> and then (depending on the version of Windows that you are running) choose the appropriate option to open the Task Manager. (In Windows XP Professional, for example, there is a button labeled "Task Manager".) When the Task Manager window appears, select File from the menu bar and then from the drop down menu click on "New Task (Run)". Type "explorer.exe" into the text bar and hit <Enter>. Windows will sort of "reset" itself, and the taskbar and Start button will reappear. (This may take a minute.)
Whatever caused the system to become unstable in the first place could easily happen again, so at this point it's a good idea to save any unsaved data, close all open applications, and then shut down and reboot your computer. If the same problem happens again, make a note of which programs you were running when it occurred, as it may be a resource conflict or compatibility issue that's causing the problem.
on May 27, 2010 | Computers & Internet
Tip
Disable XP Shutdown
There may be times when you want to make sure that XP can't be inadvertently shut down. You can use a Registry hack to disable the normal Shut Down. Run the Registry Editor and go to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer. Create a new DWORD value named NoClose with a data value of 1. Exit the Registry and reboot in order for the change to take effect. You won't be able to shut down Windows in the normal manner from now on; you'll have to run Task Manager by pressing Ctrl-Alt-Delete or right-clicking on the Toolbar, choosing Task Manager, and then using the Task Manager's Shut Down menu to close Windows. If you want to reenable normal shutdowns, delete the NoClose value.
on Mar 17, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
How can I shut down my computer?
The setting is in the APM (Advance Power Management) in BIOS. Select the correct power management in BIOS
Sep 05, 2014 | Microsoft Windows 7 Home Premium 64BIT...
When I go to START and SHUTDOWN instead of shutting down like it use to do, I get a message instead that announces the programs that are still open. I would just like for it to shut down like it use to do.
you are getting the message because probably you did not close opened programs or web page before you attempt shutting down.
Check your task bar and make sure all opened programs/application are closed before you shut down your computer.
This is all you need to do for your computer to shut-down in its normal way.
Also to be sure all programs are closed, press Ctrl + Alt + Delete on your keyboard and task manager icon will pop-out. Then you can close any opened program from there.
Take care.
Apr 04, 2010 | Computers & Internet
MS word won't close
Click in the Word document window, then Press ALT F4. If that does not work, use CTRL ALT DEL (If a small window offers you to shut down, etc. Click on button Task manager.
When Task manager open click Tab Processes. Click on the top of the column where the names of the programs appear (this will order manes alphabetically in ascending or descending order) scroll down the list and look for Word.exe. Select it and click End process, Click Yes, and close Task manager.
Do not end any other process.
Hope it helps.
Sep 07, 2009 | Microsoft Windows XP Professional for PC
Ourmicrosoft word 2007 did not get to access
When an application hangs like that, there are a couple of options you have to shut down the system. The safest is to open the task manager, if you have mouse control, by right clicking on the task bar and choosing task manager. In the menu bar across the top of the task manager you'll see an option to shut down the computer, which if chosen will probably prompt you to end the program that's hanging. There's also an applications tab, which will allow you to select the problem program and end the task, which will sometimes enable you to free up the system without shutting down. This option should be used judiciously, however, and only when you have already tried other conventional means to end a program from within the program app itself. If you can't access task manager from the taskbar, you can also press ctrl + alt + del at the same time, and the task manager windows should come up...
Finally, you have the option to perform a hard shutdown by holding the start button down until the system closes itself down. This should only be used in dire circumstances, when you've given the system a chance to finish whatever it's processing and other means aren't working. A shutdown like this doesn't give the system a chance to save its settings and you risk losing your work and otherwise confusing the workings of things, so it's best to save this for when all else fails.
Once you get the system to start normally, you can use the built-in windows event viewer to look at what warnings or errors were encountered when the system froze up, and try to diagnose the cause and correct the problem....
If there's a problem with file corruption, for example, this may be found and or corrected by running checkdisk on the system...etc.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Fin
Jul 02, 2009 | Microsoft Office Word 2007 Full Version...
Laptop does not shutdown it hangs while shutdowning what is solution why does it happen
Hi
You need to remove the battery and then place it back , it will surely work .
You can also download easy shutdown from this link
http://www.tucows.com/preview/337660
Thanks
Rylee
Jan 08, 2009 | Acer Aspire 5315 Notebook
Ctrl+Alt+Del doesn't display task manager
hi!
welcome to Fixya,
you have a virus that name brontox if I'm not mistaken.
update or upgrade your anti virus. and free upgraded anti virus can help, like AVG 8.0
but your have big problem because when the anti virus trigger the dos mode it will automatically shut down your PC. like when you open your task manager or run the command prompt. so try this thing out and what happen.
Dec 05, 2008 | Microsoft Windows XP Professional
I am 56 years old computers are not my generation. just got a new computer. and am trying to close it but it would not close . what I did is close the the monitor. and then pressed the button off of the...
You have to click the Start button and choose "Shut Down " and click the mouse on that. If that does not work, try pressing Ctrl + Alt+ delete simultaneously. What they call the task manager will come up. choose Shut down and click on it. It should shut down
Nov 08, 2008 | Acer Computers & Internet
Acer Aspire 3690-2196 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
