Garmin nuvi 265 Car GPS Receiver Logo
Anonymous Posted on May 04, 2017
My Garmin nuvi 265 was working fine until 2 weeks ago. We got a screen message saying that the XM traffic was not supported, and then noticed that the unit no longer could be charged using the car charger. Other items work when plugged into the 12V car outlet, so the problem is not with the car. The unit charges up fine when attached to the computer so it probably isn't the unit itself. We tried replacing the fuse in the car charger cord, but the Garmin still won't charge and the traffic function doesn't work. Any other ideas?
Michael Grimes
Level 2:
Scholar:
  • Garmin Expert 195 Answers
  • Posted on May 10, 2017
Michael Grimes
Garmin Expert
Level 2:
Scholar:
Answers
195
Questions
0
Helped
38719
Points
395
The traffic receiver is in the car charger cable. The charger should have a red light on if it is getting power. If the light is on and the unit is not charging and you have no traffic, the charger cable is bad. If the light is off, then either the fuse did not fix the problem, blew again, or is somehow not sitting properly in the charger. Another thing you can check is by using the unit in another vehicle. If it works fine there, then the charger is not making good contact with your vehicle outlet for some reason. You will probably have to buy a new traffic receiver charging cable.
5 Related Answers
Anonymous
  • Posted on Jan 12, 2008
SOURCE: Garmin Nuvi 350 Traffic Receiver connection
You have to power the unit via the mount by either using the cigar charger in the car or snap off the mount from the ball and socket and power it via the mains adapter.
Anonymous
  • Posted on Mar 06, 2009
SOURCE: nuvi 205w will not power on when car charger is attached
Would you be willing to sell your unit. If so please contact me at [email protected]
Thanks
Anonymous
  • Posted on Mar 26, 2009
SOURCE: Garnin NUVI 680
Needed to change the fuse
Anonymous
  • Posted on Apr 08, 2009
SOURCE: Garmin nuvi 265 WT CAN'T PAIR BLUE TOOTH WITH SAMSUNG CELL PHONE
I had the same problem but I think I fixed it by NOT sharing my phonebook.
John Morganti
  • 864 Answers
  • Posted on May 28, 2009
SOURCE: I need an instruction manual for a Garmin Nuvi 265 WT GPS
Manual and Quick start are available at:
http://www.retrevo.com/support/Garmin-265WT-GPS-manual/id/23123bh336/t/2/
I have a Garmin Nuvi 755T. I noticed that the unit was not charging via the car charger. I checked the charger and noticed that the green light was on. I also pulled the fuse and checked it and it is...
found female jack on the 755 mount where the car charger pluges into the GPS was not securely soldered onto ckt bd so after multiple times pulg in or unpluging the unit or just stressing the connection the fine wire conncetions (about 12) tend to break forcing the unit to operate on battery mode untill battery is discharged. you an purchase a replacement GPCCradle Holder compatible with Garmin Nuvi on Amazon GPS Cradle Holder Compatible with Garmin Nuvi for about $20
1helpful
Lifetime traffic feature no longer showing on screen.
If you have noticed this in your area and your 12v cigarette lighter plug in powered and charging the unit then unit may need a firmware update, do this using garmins WebUpdater Software. Also traffic is not covered in all areas so if your travelling you may be in an ara where this feature is not supported.
Hope this helps!
My 265WTS says to subscibe to the traffic reportsI have to file the unit's I.D number. Where do I do that?
your nuvi will receive its traffic updates through an FM channel that requires no subscriptions. The receiver is located in the 12v power cable so aslong as you are powered you should receive updates.
Hope this helps!
2answers
I bought a Garmin /Nuvi 265wt do I need to suscribe to receive traffic reports
Many Garmin nuvi GPS units that are traffic capable come with a complimentary 1 (or more) month trial of the service. After that period is over, a subscription must be obtained to continue to receive traffic reports. The GPS will continue to provide routing and mapping without a traffic subscription however. Only the real-time data will be missing without a subscription.
Pay close attention to which traffic service you get. The MSN traffic service will be going away in the next year or two. The FM traffic service appears to continue to grow. Phone a Garmin Customer Service Rep to discuss your traffic subscription options and possibly active your choice with them over the phone.
Please rate this reply - good luck!
1helpful
My Garmin Nuvi 200 has a message that says No detailed maps found that support routing. The nuvi cannot be used without them. I just used this garmin a few hours ago, and it was fine. Now I can't get...
You need to call garmin to have them help you unlock your unit. It sometimes requires the 25 digit unlock code which they have on hand. 1-800-800-1020 I believe.
My 265 wt was working fine until 2 days ago
I can help you reset and fix your Garmin Nuvi 265WT.
Erratic behavior is an indication that the firmware / system software inside your GPS has been corrupted.
Satellite reception is one of the issues addressed in Garmin Nuvi 265WT firmware updates.
There are three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265WT Manuals here.
1helpful
2answers
Garmin Nuvi 265 W 'system software missing' message
The system bootloader software got scrambled when you did the update. You can escalate it to a software tech and they may be able to give you the bootloader image file. If not, you'll have to get an RMA and send it back for a unit swap.
3helpful
Garmin nuvi says, "no detailed maps found to support routing."
I am very sorry to hear that you are having problems with the unit. You
may need to switch the unit on and press and hold the centre of the
screen until the message ?No detailed maps? message disappears.
If your map detail is missing, then the map information may have been
disabled. To check to see if the mapping has been disabled, follow the
steps below:
From the Where to? and View Map page, touch the Spanner icon, settings
(Tools).
Touch Map.
Touch Map Info.
The unit should display the name of the map that is loaded to the unit.
The box in front of the map name should have a tick in it. If it does
not, touch the box to place a tick in it.
Then please test by searching for an address.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
