Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Battery problem???? Laptab shuts off if unplugged and the charging light turns off a few seconds after the computer is plugged in. The computer also when shuts off on AC power
  • eianakova Aug 18, 2008
    The computer shuts off if unplugged and the charging light turns off a few seconds
    after the computer is plugged in. The computer also shuts off when on AC
    power. Please advise
Please see Solution #1 that I just posted on another thread (link below). Hope this helps. From what I understand of your problem, I've experienced it twice, and this works for me (so far, ha ha). Get a new AC adapter - preferably, NOT one made by Lenovo.
http://www.fixya.com/support/t771569-lenovo_3000_n100_power_up
Cheers and Best of Luck
Posted on Sep 02, 2008
    Problem Solver:
  • 16 Answers
Check the power plan of your operating system!
blow a can of air into the fan and sink assembly if you think its a problem due to over heating..
Take out the battery and clean its terminals on the battery and the in the laptop too..
If its restarting automatically then go to My computer>right click> properties> advanced> repair/recovery > uncheck the box for automatic restart and do a clean boot..
regards,
Ronald
Posted on Aug 21, 2008
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
Battery not recognised/not charging
Turn the computer off, unplug it, take the battery out. Then hold the power button down for 10 - 15 seconds. Plug the ac adapter back in, but do not put the battery in yet. Boot the computer, then shut it back down. Put the battery back in then boot it again. It should recognize the system now.
Jul 31, 2014 | Sony VAIO VPCEA36FM/W Laptop
Problem charging toshiiba qosmio x305
Remove battery...plug in charger and boot/Turn on computer.Then shut computer down.Unplug charger..hold the on/off button down for 30 seconds.Replace battery and turn on.
Apr 15, 2014 | Computers & Internet
When I turn on my laptop the power lights up and shuts off after a few seconds
either a bad battery, or charge port. even if the battery was fully charged it will still keep the light on, try this. plug it in, and power it on, then remove the battery completly, the computer should stay on, as its running off the plug power cord. if this port is a bad one the pc will shut off immeadatly. and if it stays running then it will be the battery.
Jan 06, 2011 | Gateway M-6843 Notebook
Hp pavilion dv-7-1245dx --keep shutting down after a few seconds
If the computer's battery is bad it won't stay on. If the fan is plugged up and over heats quickly, then the computer will shut itself down. I would start with those. Wouldn't be bad to check that your memory chips are in securely as well.
Jan 06, 2011 | HP Pavilion dv6000z Notebook
My toshiba satellite laptop won't turn on. If I hold down the power button sometimes it will turn on for a few seconds, but then shuts off. About a week before this it would shut off without warning when...
I might just be the battery.
Look at your AC adapter and see if the light on it comes on when plugged in. If so then that should be good.
I could also be a dead battery that will not accept a charge. Replacing the battery could fix it.
If it happens again after the new battery discharges then it could be the connection on your motherboard is not charging the battery.
Apr 19, 2010 | Computers & Internet
Toshiba satellite A210 11-P crashes when i disconnect the power lead
From Toshiba, try step-charging the battery or Battery conditioning procedures:
Batteries don't last forever. All types of batteries gradually lose their ability to hold an electrical charge as they age. Eventually, the computer's battery charge indicator may show that the battery contains less than a full charge, even though the battery has just been fully charged. The computer will then not run for as long a time from the battery as when the battery was brand new.
You may prefer to simply replace the battery if this happens, but you may also wish to try 'step-charging' the existing battery per the following instructions.
This procedure should work for the battery in any Toshiba notebook. Follow it only when you find that the computer will run from the battery for just a short while.
Check the User's Guide for more specific information about charging the battery in your computer .
Procedure
Step-charging the computer's battery
  1. Unplug the AC adapter from the computer, and turn ithe computer on. Let the computer run from battery power until the computer turns off, indicating that the battery is fully discharged. Time this interval, but not with a software clock running on the same computer.
  2. Remove the battery pack from the computer.
  3. Unplug the AC adapter from the computer.
  4. Wait at least 30 seconds. The first time through this procedure, use a soft cloth to wipe the battery pack's contacts and the AC adapter's plug.
  5. Re-insert the battery pack.
  6. Plug into the AC adapter into the computer again and check the fit of its plug in the wall outlet, making sure the connection is secure.
  7. With the computer turned off, let the battery charge until the battery status light or icon glows green, or otherwise indicates a full charge.
  8. Unplug the AC adapter from the computer.
  9. Remove the battery.
  10. Wait at least 30 seconds, then re-insert the battery.
  11. Plug the AC adapter back into the computer.
  12. Let the battery charge again until the battery status light turns green or otherwise indicates a full charge, again.
Repeat this procedure, starting from step 1, at least three times. Each time, check to see if the computer runs longer from its battery than the previous time.
Battery Conditioning:
IMPORTANT!!
Interruptions in the charging cycle can be responsible for an issue called "memory effect" which may reduce the battery's charging capacity. Whenever you suspect the battery performance is not at it's optimum you should try using the following "Battery Conditioning" procedure.
Before you start: Turn off your battery saving features temporarily.
***IMPORTANT*** Repeat the following steps 2-3 times!
  1. Unplug the power cord from the computer
  2. Turn the computer on and let it run until it shuts itself off.
    Note: Using the CD-ROM to play an Audio CD will speed the discharge.
  3. Plug in the power cord (While the system is off) charge the battery until the battery light changes from flashing green to solid green
  4. Remove the battery for 30 seconds and then replace it.
    Note: If the battery light isn't lit, wait a few moments, if it still does not light check your power connections.
  5. Continue charging the battery until the battery light turns solid green once again.
    **REPEAT THIS PROCEDURE 3 TIMES**
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 04, 2008 | Computers & Internet
Battery recognized but wont charge
it may be that you have a bad battery and you laptop may be reading it wrong since the battery may be bad. I recommend calling your pc manufactuer, and have the battery replace
or
you may go to www.circuitcity.com or www.radioshack.com
for a look up on a new battery.
Hope this solves the problem
Nov 12, 2007 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
95 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
