Question about Clarion DB245 CD Player
The counter hi, the time is displayed as long as the radio is off. i want the time displayed with the radio on. there is some kind of counter displayed where the time should be displayed. thanks joey
Hi, yes, problem is solved thanks to fixya. i used the solution that you posted to set the clock and it fixed my problem too.
thank you
joey
Posted on Aug 20, 2008
Hi I have a kenwood ts 440s the radio turns on ok but the frequency counter display does not come on
Wow, what a nice radio! Very complicated controls, here is a link to the operating manual. I suspect the radio is showing a memory channel number instead of the frequency. It should be easy to fix, but long manual. If you cannot find it in the manual, erase or "clear" all memory entries.
http://www.manualslib.com/manual/86439/Kenwood-Ts-440s.html?page=7#manual
Oct 11, 2015 | Kenwood Radio Communications
How do I stop the frequency counter board in a DX-959 from loosing contact and making the display stop working?
You may have what we call a bad solder joint or a problem with the connection point from the counter to the radio. You need the expertise of a CB radio repairman.
Dec 08, 2014 | Galaxy Radios DX-959 40-Channels Base CB...
Printing error
hi jerome,.
what kind of full that u said? "ink absorber is nearly full",.?
if is that,.?
try to reset your purge counter,
press stop button to back to normal the display of the printer,
press menu, mono, 4 times up arrow button
then 80 in the keypad
then press the up arrow button to search the purge, you see the purge counter is half a thousand, I think that is PURGE:05###,.
then press 2783 to back to zero PURGE:00000
then press STOP button then 99 to restart your printer
Apr 15, 2014 | Brother MFCJ220 All-In-One InkJet Printer
Galaxy 88hl frequency display only has decimal point, channel readout fine
on the face plate is a button for the counter ,try pushing it several times to see if the dot moves. As long as the channel display is reading the correct channel you should be ok but you want to correct this problem . If you can't correct it contact Galaxy and they will have a tech talk to you.
Nov 03, 2012 | Galaxy Radios DX- 88HL Base CB Radio
Changing colors on a Galaxy 88 or DX-88HL or DX88
  • There are no white ones at this time. Only Red, Green and Blue on the frequency displays. If you have any other questions please feel free to ask.
Oct 20, 2011 | Galaxy Radios DX- 88HL Base CB Radio
Freq. display not correct but radio is on the write freq.
This of no surprise because it is just that a display not a counter.
There must be an alignment pot for the meter display although there will be some doubt if you just align it with out using a frequency counter.
http://cbtricks.com/radios/rflimited/index.htm
you might find more alignment info under the S45 omegaforce as they have similar boards.
hope this helps...goodluck!!!!
Aug 06, 2011 | Magnum 257 CB Radio
How do you set the clock on a milwaukee radio
turn the radio on, push the MEM button display window will flash turn the tuning knob clockwise to set hours and counter clockwise to set minutes push the MEM button and hold 5 seconds to set time. Hope this helps, if I have solved your problem would you please vote accordingly and thank you.
Jun 10, 2011 | Milwaukee Tool Milwaukee 49 24 0280 Radio...
Hi, I have a 1998 95 Saab and the battery was
pull the radio get the ser# model# date code it might not be from the same year as your car unless you bought it brand new and call an authorized saab parts or service counter/dept.. and what kind of mechanics try either saab dealership or a car audio shop
Mar 16, 2010 | Car Audio & Video
Change drum soon warning will not go away. Changed drum and toner
You may need to reset some sort of timer or counter. This kind of information can be found in the owners manual (aka users guide).
1 Wait until the time, date, and answering mode appear on
the display. Then press the Select Function key.
2 Press the 7/Counter Display One-Touch key. The display
shows DRUM COUNT.
3 Press the Yes § key to clear the image drum unit counter.
4 Press the Select Function key to finish.
Feb 05, 2010 | OKIFAX 5650 Plain Paper LED Fax
Blue LED display too bright
TRY........with radio on and set on "AM", hold "Clock" button about 7 seconds and let up - bringing a setup menu. Using tuning knob,scroll to "Hardware". Press tuning knob in, bringing up contrast menu. Press tuning knob in, bringing up "contrast level". Turn tuning knob counter-clockwise to "00". Brightness, dimming level should be "170". Turn radio off to exit, then adjust "Dim" button to your liking.
Nov 02, 2008 | Boston Acoustics Recepter Clock Radio
Clarion DB245 CD Player Logo
80 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
