Question about Philips Magnavox 51MP392H Rear Projection Television
Can't get the tv to move from the cable mode
I can't get the tv to move from the cable mode.  Need instruction on how to program tv.  My e-mail is hlthomas@bellsouth.net
    Scholar:
  • 33 Answers
Wondering if this is what your asking about, I cant find reference to Cable only mode...
- Line 7 : “CHANNEL BLOCKED”
Indicates that all channels are locked except the selected channel.
The following complaints may be generated due to locked channels:
- TV cannot be switched on from standby with the local keyboard buttons.
- “CH+” and “CH-“ buttons on local keyboard do not function.
To disable the LOCK feature:
Select ”FEATURE” menu (with the Remote Control).
Select “LOCK” (with the Remote Control).
Set to “OFF”
Posted on Nov 20, 2008
Heed to know how to program My player to my TV.
U may want a new cable , HDMI are notoriously sensitive and internally will break connection, even from modest bending , cheaper ones from Walmart are the most notorious , buy a nice one and u lessen this
Nov 08, 2015 | Audio Players & Recorders
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
Accidentally pressed a button on the remote which has returned our 26' dynex rc701da hdtv to setup mode cannot get it set up again despite following instructions always ends up "plse run channel auto...
Hi:
The unit is telling you to run autoprogram to program in your channels, make sure also the TV is in cable mode and not TV mode which is for local channels, If you have cable do a autoprogram so the set can program in channels. Auto Scan is the same as autoprogram.
Mar 17, 2011 | Televison & Video
Moved, no longer have cable and not getting any channels via attenna. Is it just bad reception or do I need a digital converter because of the change to digital stations?
Could be bad reception and or make sure the tv which was in the cable mode when you had cable now needs to be in air or antenna mode. IF you have another tv that works ok then you will know the channels just need to be reprogrammed for over the air signal. Go into the menu of tv and find program channels and switch to air or it might say antenna..
Oct 17, 2010 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Need codes to program remote
most universal remotes have a auto program mode or coad if you can't find a coad to match your brand
Apr 27, 2009 | Televison & Video
How to import Outlook Express mails to Windows
Open Outlook Express go to File then Export and proceed to what you want to export. Follow the instructions from there. You will need a flash drive or CD to save the files and move them.
Next go to Windows Mail, go to File then "Import".
Follow the instructions and you should be good!
Mar 20, 2009 | Microsoft Windows Vista Ultimate Edition
VCR/Cable TV Connection
I guess you are using the cable TV feed looped through the VCR to the TV set.
Make sure you did not confuse the in and out loop of the VCR.
In the VCR menu, or on the remote there is usually a button called TV/VCR (Video). Make sure it is in the TV mode to watch the cable. In the VCR (Video) mode, the TV must be on the VCR's designated channel to watch the VCR, and the VCR tuner is used to watch the cable channels.
Jerry G.
May 24, 2008 | Televison & Video
Unable to get cable channel programmed into set
Access the customer menu, select cable vs. ant then go to auto programming and let it do it's magic.
Bill
Apr 23, 2008 | Mitsubishi WS-55807 TV
Need help to re-program Toshiba remote that came with MW20FM1
Check out Toshiba Customer Support. They e-mailed me the instructions to reset the V-Chip.
customer_support@tacp.com
Oct 15, 2007 | Toshiba MW20FM1 20 in. Combo
Polaroid HD flat screen TV with DirecTV
I have Polaroid TV Monitor HDMI LCD 15.4" no power light on TV, blank screen, the power adaptor is Ok 12VDC supply. I need suggestion; in any possible problem or parts busted?
Sep 09, 2007 | Televison & Video
Philips Magnavox 51MP392H Rear Projection Television Logo
448 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
