I can't locate an AVG cable for a FDP1500 Gateway monitor. I need one that will adapt the monitor to work on an Emachine PC tower.
  • 13,433 Answers
Vga cable.. You require a VGA Male to Male cable if I understood you correctly.. Click here
see if that one above fits your needs.
Posted on Aug 18, 2008
  • Ekse Aug 18, 2008
    Connects PC or laptop to the projector, LCD monitor, and other video display system
How to change monitor from dvi to avg
It is not avg , its VGA Cable ,, u will get a cable were the monitor port has dvi and the system tower has a VGA port, the cable adapter u need to go for will be a DVI male to VGA cable adapter .
Dec 15, 2014 | Computers & Internet
What type of pc tower is compatible with an older gateway monitor model fpd1750
Try typing in, "compatible PC towers for gateway model fpd1750" on Google.
Jun 13, 2014 | Gateway FPD 1750 17" Flat Panel LCD...
Gateway a computer desktop has power but nothing on screen the computer doesn't have a tower
1) Computer doesn't have a tower? Means it is a 'pancake style' of desktop computer. A flat model.
2) No signal on monitor screen?
Good.
At least we know the monitor is good.
Problem is monitor cable, IF separate cable; or computer.
Computer isn't sending a video signal.
No Signal, Power Saver Mode, etc.
If an older CRT type monitor, (Looks like a small TV), and monitor cable is not detachable; use a known to be working monitor, and monitor cable.
If a separate monitor cable, use a monitor cable from a working computer, for a temporary test unit.
Put it back when deemed monitor cable is the problem.
Logic at this point, would deem something is wrong with the graphics chipset.
Whether mounted directly to motherboard, (Integrated), or a separate graphics adapter card. (Graphics/Video Card)
However, computer could be dirty inside, or have a bad Power Supply.
LED's (lights) light up? Maybe fans spin?
Means nothing.
1) If ALL of the Light Emitting Diodes were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use from 51 to 130 Watts of power.
Just depends on what Processor it is.
Older desktop computer?
Ummm, 35 to 40 Watts.
That is why LED's can light, and maybe fans spin, but no computer.
NOT enough power to turn the Processor on.
Computer needs to be CLEAN on the inside. Inside of Power Supply too, as well as possible.
Proper method to do this procedure, post back in Comment if you need guidance.
Also remove ALL Ram Memory modules, and clean gold plated contact pins on bottom; with pencil eraser.
Reinstall. Make SURE they are seated in tight, and Lock 'ears' are locked in place.
Post in a Comment, as to the model number.
Example, DX4300-05. Should be on back of computer.
Regards,
joecoolvette
Mar 22, 2013 | Gateway Computers & Internet
What cord do I need to connect my 1810 gateway monitor to my tower
Your either going to need VGA or DVI. You need to check the back of your computer and monitor to see which type of connection you have. Then plug in the appropriate cable.
Pic of VGA cable: http://www.ccrzone.com/attachments/Image/VGA_M-M_6_.jpg
Pic of DVI cable: http://farm4.static.flickr.com/3216/2995518986_9deb622bff_o.jpg
Jul 19, 2011 | Gateway FPD1810 18.1" LCD Monitor
My emachine desktop monitor keeps cutting on and off by itself. What should I do?...it's really aggravating.
There are three possible reasons for the issue:
1. Monitor power cable is loose
2. Video Adapter is faulty
3. Monitor capacitor is gone bad
Please try the below steps to diagnose the issue:
1. Check the power cable on the back on Monitor, if connected properly, like connect the power cord on a different Wall outlet
2. Unplug the signal cable from the video adapter and replug it. Also, check a different monitor (if any) on the Tower.
3. If the above steps fails, then the issue is with the monitor, it is going for repair.
Thanks and regards,
Jitha
Nov 23, 2010 | Computers & Internet
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
My emachine will turn on and run without doing anything. The monitor states no signal.
Either the VGA cable (cable from your monitor to computer) or VGA port on your computer is faulty. Try connecting another monitor to your computer to determine the problem. If the other monitor works, then your VGA cable is faulty. If the other monitor doesn't work, the VGA port is faulty. Hope that helps.
Aug 03, 2009 | Gateway Computers & Internet
PC STARTS BUT NO VIDEO SIGNAL IS PRESENT AT THE MONITOR
No don't flash the bios, this job is not for the faint hearted !!
Contact me for support at http://www.motherboardsrus.co.uk
where you will find an email address.
You may also like to look at the pages entitled "emachine and Advent support pages" these pages relate the shop built pc's such as yours and emachine,advent,medion,gateway,packard bell etc.
Contact me on my direct email address
Chris
May 31, 2009 | Gateway 310 S PC Desktop
Weird blink problem...
That's definitely a hardware (incompatiblity) problem. Download the most updated driver for the graphics card. Also see if there is a monitor driver for the monitor.
I understand it worked seamlessly for the emachine but you should switch it back for a day or two to rule out the monitor just screwing up.
Mar 11, 2008 | E-Machines eMachines Monitor E15T4
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
