Question about Bose 023795 LCD Touchscreen Remote Control
Lifestyle 50 "No Response"
I've tried to reconnect the interface according to the instructions in the manual, but after holding down the mute button and getting the first beep, the remote will not beep again after waiting the required 10 seconds. What's up?
  • moriley Oct 14, 2008
    I spoke with the technical center yesterday, and for the minor sum of $53.75, Bose will fix the unit, if I send them the personal music center (the remote) and the MRI (the thing with all the wires in the back). Guess that's my only choice, but it beats buying a new system.
  • mattbecca4 Nov 15, 2008
    My remote lights up but continues to post the No Response message. Holding don the mute button doesn't seem to help either.
The remote problem is same with me and need to repair.
I gots information from Bose Service Center, PCB transmitter and receiver not working well.
maybe this information helpful for you.
tq.
Posted on Oct 14, 2008
My lifestyle 50 M1 interface is displaying "No response". I have tried all the standard reboot options but apparently I need to replace the capacitors. Can anyone tell me the values of these?
Terry,
I have had the same issue with LS50 for some time and stumble last night on the blog: https://blogteramod.wordpress.com/2015/05/18/lifestyle-50-no-response-quick-repair/
It is written in German though the detail worked perfectly for me this morning.
Bottom line is that they suggest you replace on the P1 unit 4 x caps (C9- 47uF 16V, C10-47uF 16V, C17-10uF 25V, C18-10uF 35V).
I did the work on my unit this morning and all is good - remote now connects immediately to P1 (as it did when new).
Hope that's useful.
Glen
Jan 27, 2016 | Bose LifeStyle 50 System
Bose system (Lifestyle 50)
Did you try leaving it unplugged for a few hours?
Feb 24, 2008 | Bose LifeStyle 50 System
Remote shows no response
I have just had a major problem trying to get the handheld (touch screen) music centre to communicate with the multi room interface. It took over a week to sort out by trial and error, but here is the solution :
1. Disconnect everything from the multi room interface apart from Room A and the CD player (blue connector).
2. Turn off the electricity supply at the wall (turning off any in line extension lead is not good enough - it needs to be at the wall socket). Leave turned off for at least 2/3 hours.
3. Turn back on and then leave it again for 2/3 hours.
4. Touch the music centre and you should find that it has now registered with the interface unit.
5. Connect the other rooms and input sources with the power switched on (contrary to instruction manual which advises you connect everything before powering up).
6. Test each input systematically as you connect them.
Hope this helps. I was on the verge of buying another multi room interface (I have 2 music centres and neither worked so assumed in was the interface at fault), at a cost of £200, so now glad I persevered with resetting the system !
Mar 03, 2014 | Bose LifeStyle 50 System
Lifestyle 50 not responding
Reconnect the Bose link connection at the Multi room interface and at the Acoustimass Module.If this doesn't help,change the remote control batteries.If the it still display "no response",it means either the interface or remote is bad
Jul 28, 2013 | Bose Lifestyle 40/50 Music Center Used...
BOSE LIFESTYLE 50 REMOTE CONTROL NOT WORKING
FOR THE BOSE LIFESTYLE 50 SYSTEM (Model P1 - Personal Music Center remote)
You can re-calibrate the remote first by following the steps below:
1. press and hold down on the display screen in the top middle area of the remote
2. After a few seconds the word CAL will appear in the middle and the word SOURCE will appear in the top left area of the remote.
3. Press the SOURCE button.
4. The word KEYPAD will appear in the top right area of the remote
5. Press the KEYPAD button and a small circle will appear in the bottom right of the remote.
6. Press the Circle
This should've recalibrated the remote.
If you need to relink the remote to the system, HOLD down the mute button while having the remote as close as possible to the unit. You will hear a beep . Release the button, after a pause , you will hear the remote beep twice.
This re-links the remote to your system
If the backlight is not working, your options are
1. Spend $349 and get a new one from Bose Or
2.Spend $220 and get a used one on E-bayOR
3. Use your remote with the lights on so that you can see the display :-)...the cheapest way OR Invest in an LED Book light that you can clamp on the remote and use that for your light ($9.99)
Sep 10, 2012 | Bose LifeStyle 50 System
Remote control codes for bose
The DirectTV Website has a page to find remote control codes, and it lists lists four different remote controls to choose from. Find it here:
http://www.directv.com/DTVAPP/global/contentPage.jsp?assetId=3580003&
I fired "Bose Lifestyle" into the first choice and it gave me the numbers
31229
here are the instructions from that page:
Setup Instructions
  • Set the "Mode Switch" to AV 2.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Try your new code and tell us how it worked!
  • I hope that helped.
    Sep 19, 2009 | Bose Lifestyle 48 System
    Projection lamp timer reset
    I called 1800 211 PANA and they walked me through resetting lamp.
    press recall and Volume- till solid screen shows, then hit recall till you see codes on top left, then hold volume- and mute(same time) till all codes return to 000000000000, then hit exit. turn off tv and check to see if it works
    Jan 21, 2008 | Panasonic PT-50DL54 50" Rear Projection...
    Bose 023795 LCD Touchscreen Remote Control Logo
    2,305 people viewed this question
    Top Bose Televison & Video Experts
    George Scott
    George Scott
    Level 1 Expert
    Jerry Greenberg
    Jerry Greenberg
    Are you a Bose Televison and Video Expert? Answer questions, earn points and help others
