Question about Canon PowerShot G3 Digital Camera
Canon PowerShot G3 shutter button stuck
My Canon PowerShot G3 shutter button is stuck. Is there any way for me to try to repair myself? Any service manuals online anywhere? I figure it's probably not worth paying for the cost of a repair since I can get one on ebay for the about the same price. Thanks.
  • Anonymous Feb 24, 2009
    I have the same problem and I would like to fix by my self because is to expensive do fix, and is better to by a new camera.
SOURCE:
  • 2985 Answers
SOURCE: canon powershot g3 no image on lcd
Assuming you are recording images on to the memory card[are you?]. Is is a 'peer through the screen to take model or can you use a normal viewfinder? If the latter I would learn to live without looking at the images ,until yo can see them on the screen[computer or TV] at home. Otherwise at this age it will be new camera time I feel, But do get onto Canon webs site technical support there may be a simple solution.
Posted on May 28, 2007
a common problem is with the 'optical unit' shutter control part.
have to replace the 'optical unit'
Posted on Jan 31, 2008
SOURCE: Canon Powershot SX10 lens error
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards iversh
if you felt i've spent my time for u... a very helpful rating is appreciated...
Posted on Aug 30, 2009
  • 59 Answers
SOURCE: I have a canon powershot g3. It turns on and
the G3 was sort of a protype of thew G4, try tapping the camera lightly, not fixable, you can get a used g9 at great prices, or g10 ,g11
Posted on Oct 21, 2009
SOURCE: User Manual for Canon Powershot SX100 IS
Hey I have the whole manual in pdf in english if you want it email me at coastal)[email protected]
Ill send it to you
Posted on May 05, 2010
MY CANON G10 DOES NOT SHOW AN IMAGE ON THE SCREEN ON THE BACK OF THE CAMERA?
Known issue!
G10 => Dead Black Sceen ! (only on screen infos): Canon PowerShot ...
https://www.dpreview.com/forums/thread/2639340
  1. Cached
Aug 13, 2009 - 11 posts - ‎4 authors My G10 is dead a few days ago, in a middle of a trip... (can't explain my ... Does the camera take pictures and can you download them to your computer? Then your sensor is OK and ... No cover on lens, and tried every display mode, you can trust me. ... (and even on, I will not have a permanent black screen). PowerShots can't do purple!?: Canon PowerShot Talk Forum ... 29 Dec 2013 G11 Date & Time Issue: Canon PowerShot Talk Forum: Digital ... 31 Jan 2010 G10's LCD dims when held in vertical position: Canon PowerShot ... 16 Nov 2008 G10 Can we adjust in camera parameters like sharpness for JPG ... 16 Nov 2008 More results from www.dpreview.com
A Simple Fix for a Stuck Shutter 'Do It Yourself Digital Camera Repair
camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
  1. Cached
  2. Similar
May 30, 2009 - Would not recommend trying to open your cameras to repair this ... Also turn off the LCD screen (press the DISP or DISPLAY button). ... For many Canon cameras this will be shutter priority (Tv) mode (for .... I got the image back in about 5 tries. .... My Cannon S2 IS had a black picture and I fixed it from your ...
Canon G10 screen is black
www.lionebra.com/canon...g10_digital_camera/q1947687-canon_g10_screen_black
  1. Cached
Canon PowerShot G10 Digital Camera - Canon G10 screen is black- ... with the menu,changed something and now the screen does not show image of anything. ... has problem in CCD Imager and this part will be replaced to get back picture. ... E18 my canon powershot A150, got the whole E18 problem, it turns on with the ...
Canon Powershot G10 image quality problems... I have had my Canon ...
www.lionebra.com/canon...g10...camera/q4217842-canon_powershot_g10_image_q...
  1. Cached
Canon PowerShot G10 Digital Camera - Canon Powershot G10 image quality ... They are not coming back with a completely blank screen as I can see the ...
Digital camera repair - Digicamhelp
www.digicamhelp.com > Digital camera care > Digital camera repair
  1. Cached
  2. Similar
Digital camera repairs can be expensive if not covered under warranty or a service advisory. ... When a sensor goes bad, images may exhibit some or all of the following: ... Hard reset for Canon compact cameras: this has worked for some Canon ... a blank LCD screen, a stuck lens or sensor or other problem that can't be ...
S2 IS "black screen *****" problem: a SOLUTION! ' Canon PowerShot ...
https://www.flickr.com/groups/[email protected]/discuss/72157606903408401/
  1. Cached
  2. Similar
Aug 23, 2008 - My 1st Canon (film) camera was a TL and I'd probably still have it but ... The "change the batteries" problem: Does any S2IS *not* have the ... A couple of weeks ago i turned on my dear S2 IS and.. no image!! i could only see the menus .... Actually, I had to do it 3 times before the screen got back the image.
Nov 24, 2016 | Canon PowerShot G10 Digital Camera
My Canon S2 IS Powershot camera LCD screen turned black
A stuck shutter is another common failure mode for digital cameras, ESPECIALLY for the S2 IS (you should actually complain to Canon at 1-800-OK-CANON. If it is indeed a sticky shutter, they have been fixing this for free). The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Hope this saved you $99.
Apr 29, 2010 | Canon PowerShot S2 IS Digital Camera
I was taking pictures (and had just taken a movie for the first time) with my beloved Canon g3 and it just stopped working with the lens stuck out. It wont turn on. Battery is fine and tried plugging it in...
Unfortunately when this happens this can be a difficult issue to resolve without seeking a service repair as the likely cause is a jam in the lens gearing mechanism.
However, there are a few potential resolutions you can try yourself which can often work to avoid a service repair.
For more information please click here to see my FixYa Tip on this very subject and please do leave a vote for the solution if it helps.
Thanks.
Mar 21, 2010 | Canon PowerShot G3 Digital Camera
The problem I am having with my Canon PowerShot S2 IS is the iris is staying closed. No matter what I do it just stays closed. What could have caused this? How would I fix this problem?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
As you own an S2, if you live in the US, recommend contacting Canon first as mentioned in the link. Although it's highly likely that you can quickly fix your camera with the techniques shown in the article, why not get professional free repair from Canon if it's offered? The Canon repair may help prevent this from happening again.
Jan 24, 2010 | Canon PowerShot S2 IS Digital Camera
I have a canon powershot g3. It turns on and seems to be taking pictures, but I don't think the shutter is opening, as all the pictures are coming out black.
Oct 21, 2009 | Canon PowerShot G3 Digital Camera
Canon Powershot S2IS black screen can't take pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). Not sure what causes this issue, but some say it's heat, others say it's dust.
But anyways, to confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 24, 2009 | Canon PowerShot S1 IS Digital Camera
Canon S51S power shot ... shutter stuck won't open . Help .
Either do a manual repair or take it in to a local servicer. Could just be some moisture built up inside.
Jan 04, 2009 | Canon PowerShot S2 IS Digital Camera
Shutter won't open on Canon Powershot s31s
Your camera has the know issue of Stuck shutter, whichhappens after some time (weeks or months) thata camera is notused.
Unfortunately the repair of it requires a complete disassembly of the camera, including the lens, fix it, and then put back together everything.
Definitely requires th skills, tools and experience to do it, so it's recommended that a professional camera repair center is performing this type of repair.
If you look for a reliable and low cost repair service for it, you can look in ebay for such repair services.
Example, look for seller ID Great_items_2004 or with the keywords "Shutter black S3".
Best regards,
Jun 06, 2008 | Canon PowerShot S3 IS Digital Camera
Canon G3 irresponsive Shutter & non-see through viewfinder
optical view finder. this seams odd as it is only a lens. Was the camera dropped at some point? that may explain both issues. if not then I need to know a little more prior to offering an opinion.
Jul 08, 2007 | Canon PowerShot G3 Digital Camera
Canon powershot g3
Apr 16, 2007 | Canon PowerShot G3 Digital Camera
Canon PowerShot G3 Digital Camera Logo
216 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
