Question about Canon PIXMA MP150 All-In-One InkJet Printer
Blinking E / 3 - string fell in the paper feed and jammed. Now what?
Hello, the other night I went to print from the MP 150, and low and behold there was a string cat toy in the paper feed.  It jammed.  I had to cut some and pull with pliers, but I think I got most if not all out.  Still, the paper will not print and I am getting the blinking "E / 3" message.  I do not see how to get into the area where the string fell other than to take apart the whole machine, and I fear that repair from a professional shop would cost more than the printer.  Any help? Thank you very much in advance! p
  • Anonymous Aug 19, 2008
    e/3 blinking how do you reset the printer
  • shooter1979p Aug 21, 2008
    Did not work...
    Scholar:
  • 49 Answers
To reset MP 150
1,power off, hold stop/reset ,power on;
2,hold power,release stop/reset, push stop/reset twice;
3,wait untill Led show "0",push stop/reset four times;
4,push power twice.
finish
Posted on Aug 19, 2008
SOURCE:
Paper jam
Duplo and Karagatan were early forms of Philippine drama.The Duplo was a poetic debate by trained men and women in the ninth night, which is the last night of the mourning period for the dead. The Karagatan was also a poetic debate like the Duplo, except its participants were amateurs. Both were held in homes and their theme was about a ring that fell into the sea.
Jul 13, 2013 | Brother MFC-J410W Wireless Compact...
My canon i850 is blinking 3 orange lights at me and refusing to print. any ideas. tried turning on and off. removing print driver and re-installing thanks!
3 blinks is a line feed error, something stopping the platen roller from turning, look inside where the paper goes and see if something fell in like an ink pen, paper clip, just something that doesn't belong. The platen roller is the gray roller behind the carriage and sometimes you can see thru under the white plastic guides something jammed.
Nov 25, 2009 | Canon i850 InkJet Photo Printer
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I Have a problem with my canon MP 150 Printer
From Canon Support: "Please be advised that if the MP 150 is displaying the letter E followed by number 3, this would indicate a paper jam. "
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=16981
Jan 17, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have canon PIXMA MP
E3 error on the MP150 is a paper jam error. Make sure that there is nothing obstructing the paper going into the printer and that the feed mechanism doesn't have anyhting in it. Also run a roller cleaning from the printer software.
Nov 23, 2008 | Canon Office Equipment & Supplies
Error 391: paper jam
See below for Error 391:
CLEANING THE FEED ROLLER AND THE PAD
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Pad
Apr 04, 2008 | OKI C5200n Laser Printer
Paper completely jammed
check if there is a little paper that stuck on it that causes a paper jam
Mar 09, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Paper LED Blinking
Did you see http://www.fixya.com/support/r310860-lights_indicate
The Paper LED is flashing.
papereroor2.gif Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, click here.
Clean drum unit:
The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Jan 04, 2008 | Brother HL-2040 Laser Printer
Printer not responding after a jam
http://files.oce.com/nl/download/printers/PP20D%20Operation%20Guide%20(Engelstalig).pdf Here is the link to the pdf manual for the printer. They show some light sequences and mention something about the old toner cartridge may need to be emptied/replaced. I'll let you know if I think of anything else. Tim
Jan 29, 2007 | Kyocera Mita FS-1020D Laser Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
117 people viewed this question
Clive
Clive
old marine
old marine
Ekse
